30th January 2017, 10:43 | #261 | Link | ||
Almost Silent Member
From NNEDI3 OpenCL thread:
Rethinking the "Why?" chromosome. |
30th January 2017, 16:50 | #262 | Link | |
I'm infected with poor sources. |
6th February 2017, 17:26 | #263 | Link |
See My Avisynth Stuff |
9th February 2017, 10:01 | #264 | Link |
See My Avisynth Stuff Last edited by real.finder; 21st April 2017 at 08:30. |
11th February 2017, 19:43 | #266 | Link |
yes you must have SMDegrain too if you didn't set tv_range=false, don't remember if the original mod by dogway work here or not, you should use v3.1.2.87s or up
28th February 2017, 15:12 | #267 | Link |
Eurobeat Fan
It seems that last QTGMC version causes problems on all sanimebob versions for me (the last of which is this one, that requires new parameters introduced in QTGMC).
Source is PAL, loaded through a DGIndex 1.5.8 .d2v file. Code:
sanimebob(1) #using QTGMC-3.33s Code:
sanimebob(1) #using QTGMC-3.354s (bad) |
28th February 2017, 16:27 | #268 | Link |
can you upload sample? I think this because your source is full range
28th February 2017, 22:20 | #270 | Link | |
1st March 2017, 13:15 | #271 | Link |
Eurobeat Fan
You are right, it went back to normal with TV_range=false. (What does this parameter do?)
I have this version of SMDegrain: Code:
### v3.1.2d (Dogway's mod) - 21 July 2015 ### ### mod in 2016-01-24 to fix subpixel=3 and add Prefilter auto 16 (lsb) support ### ### and yuy2 support in avs 2.6 with masktools 2.6 ### Thanks for your help. |
1st March 2017, 17:40 | #272 | Link | |
8th March 2017, 06:28 | #273 | Link |
just port qtgmc for high bit depth in avs+ http://pastebin.com/raw/JuhpFSgV but it's not work well (big difference from 8 bit)
test with QTGMC(SLMode=0,tv_range=false) and compare 3.353s or 3.354s SLMode=0 cuz I get the unsupported colour format same as old alpha masktools2 (bug somewhere?) tv_range=false to not need SMDegrain (I already update it for high bit depth but to not increase the confusion)
See My Avisynth Stuff Last edited by real.finder; 8th March 2017 at 08:49. |
19th March 2017, 21:17 | #274 | Link |
hey real.finder, first thanks for all your efforts with qtgmc!
just wondering are you already moving more of the processing to 16bit in avs+ or are you just adding the avs+ conversion functions? super excited if full 16 bit support is already close. |
19th March 2017, 22:52 | #275 | Link |
no conversion will done, so not all settings will work in high bit now cuz there are others plugins not support high bit yet
27th March 2017, 19:00 | #276 | Link |
good news for QTGMC users with anime source, it seems ghosting will be less as you using more bit depth, also less halos with Sharpness > 0
30th March 2017, 22:33 | #277 | Link |
Since you seem to use functions of SMDegrain more often in recent versions, shouldn't it be documented in the list of "core plugins", or at least "additional plugins"?
I was told that a simple QTGMC(preset="Slow") already requires SMDegrain 3.1.2d now (for Dither_Luma_Rebuild). Last edited by LigH; 30th March 2017 at 22:43. |
31st March 2017, 13:29 | #278 | Link | |
2nd April 2017, 08:49 | #279 | Link | ||
just tried QTGMC 3.357 from the pastebin link with Avisynth 2.6 MT and got:
SetMemoryMax(768) SetMTMode(5,8) # change MT mode LoadPlugin("G:\Hybrid\AVISYN~1\LoadDll.dll") LoadPlugin("G:\Hybrid\AVISYN~1\AddGrainC.dll") LoadPlugin("G:\Hybrid\AVISYN~1\dfttest.dll") LoadPlugin("G:\Hybrid\AVISYN~1\EEDI2.dll") LoadPlugin("G:\Hybrid\AVISYN~1\eedi3.dll") LoadPlugin("G:\Hybrid\AVISYN~1\FFT3DFilter.dll") LoadPlugin("G:\Hybrid\AVISYN~1\mt_masktools-26.dll") LoadPlugin("G:\Hybrid\AVISYN~1\mvtools2.dll") LoadPlugin("G:\Hybrid\AVISYN~1\nnedi.dll") LoadPlugin("G:\Hybrid\AVISYN~1\nnedi2.dll") LoadPlugin("G:\Hybrid\AVISYN~1\SSE2Tools.dll") LoadPlugin("G:\Hybrid\AVISYN~1\TDeint.dll") LoadPlugin("G:\Hybrid\AVISYN~1\VerticalCleanerSSE2.dll") LoadPlugin("G:\Hybrid\AVISYN~1\PlanarTools.dll") LoadPlugin("G:\Hybrid\AVISYN~1\nnedi3.dll") LoadPlugin("G:\Hybrid\AVISYN~1\RgTools.dll") LoadCPlugin("G:\Hybrid\AVISYN~1\yadif.dll") LoadDll("G:\Hybrid\AVISYN~1\fftw3.dll") LoadDll("G:\Hybrid\AVISYN~1\LIBFFT~1.DLL") Import("G:\Hybrid\avisynthPlugins\QTGMC.avsi") Import("G:\Hybrid\avisynthPlugins\SMDegrain v.3.1.2d.avsi") LoadCPlugin("G:\Hybrid\AVISYN~1\ffms2.dll") # loading source: C:\Users\Selur\Desktop\source.avi # input luminance scale tv FFVideoSource("C:\Users\Selur\Desktop\source.avi",cachefile="H:\Temp\avi_3ed4c33894e101eeafef5c603ca7faab_491_1_0.ffindex",fpsnum=30000,fpsden=1001) # current resolution: 720x480 # deinterlacing ConvertToYUY2(interlaced=true) SetMTMode(2) # change MT mode AssumeBFF() QTGMC(Preset="Fast", ediThreads=2) # filtering return last Quote:
Cu Selur |
2nd April 2017, 09:33 | #280 | Link |
It's a function in AnimeIVTC().
Groucho's Avisynth Stuff Last edited by Groucho2004; 2nd April 2017 at 09:35. |
