22nd October 2014, 23:47 | #21681 | Link | |
23rd October 2014, 05:10 | #21682 | Link | |
23rd October 2014, 14:22 | #21683 | Link |
when using batch backup, i end up with an error at the end of the first rebuild: after clicking on "ok", BDRB is closed. same behavior with other rips. Code:
[09:17:17] BEGIN - BATCH SEQUENCE ========================== ----------------------- [09:17:17] PROCESSING BATCH FILE [1] ---------------------- [10/23/14] BD Rebuilder v0.49.05 (beta) [09:17:18] Source: MANHATTAN_3D_ES_00799 - Input BD size: 40,94 GB - Approximate total content: [01:54:50.675] - Target BD size: 48,83 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [09:17:19] PHASE ONE, Encoding - [09:17:19] Processing: VID_00800 (1 of 1) - [09:17:19] Extracting A/V streams [VID_00800] - [10:00:04] Reencoding video [VID_00800] - [10:00:04] Keeping original video (no reencode) - [10:00:04] Processing audio tracks - Track 4354 (fra): Keeping original audio [10:00:04]PHASE ONE complete [10:00:04]PHASE TWO - Rebuild Started - [10:00:04] Rebuilding BD-3D file Structure [10:23:19] - Encode and Rebuild complete [10:23:20] JOB: MANHATTAN_3D_ES finished. |
23rd October 2014, 14:37 | #21685 | Link | |
27th October 2014, 16:52 | #21689 | Link |
Again you fail to provide any useful information that might mean something. No title of the source. No log. No INSPECT report. No settings. Either post the information needed to attempt to find the error, or stop posting useless comments.
You have a history of incendiary postings. I will not tolerate it again. If you start posting nonsense and arguments again you will receive an immediate strike and your argumentative posts will be deleted. Be warned. Last edited by jdobbs; 27th October 2014 at 16:54. |
27th October 2014, 18:33 | #21690 | Link |
some news. when rebuilding only one br (not in batch mode), i've got an error on the first try. if i press a second time on the "backup" button, it works fine. Code:
[10/27/14] BD Rebuilder v0.49.05 (beta) [18:21:28] Source: LES_IMMORTELS_3D_00001 - Input BD size: 25,40 GB - Approximate total content: [01:50:47.724] - Target BD size: 48,83 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:21:28] PHASE ONE, Encoding - [18:21:28] Processing: VID_00002 (1 of 1) - [18:21:28] Extracting A/V streams [VID_00002] - [18:21:28] ExtractAudioSubs() 00055 1601 [18:21:29] - Failed to retrieve audio, aborted ---------------------- [10/27/14] BD Rebuilder v0.49.05 (beta) [18:21:34] Source: LES_IMMORTELS_3D_00001 - Input BD size: 25,40 GB - Approximate total content: [01:50:47.724] - Target BD size: 48,83 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:21:35] PHASE ONE, Encoding - [18:21:35] Processing: VID_00002 (1 of 1) - [18:21:35] Extracting A/V streams [VID_00002] ... |
27th October 2014, 19:00 | #21691 | Link |
@brunchto
That error is the same as your previous post, "File already open". I've looked through the code, but I can't find any reason why I'd get that error. I'll keep looking. Just wondering, why doesn't the time in the message match that of the log? Last edited by jdobbs; 27th October 2014 at 19:07. |
27th October 2014, 20:12 | #21694 | Link |
Omega, some people just don't explore the features of the message posting interface.
Toilet, instead of 'attaching' your information, you can just paste in your text into the reply. I'd suggest using the 'code block' method, where you tap the '#' button (above the text entry area) and you can then past your text in between the 'code' tags. For instance, I'll put the next sentence in a 'code block'. Code:
The next sentence. Last edited by RobertM; 27th October 2014 at 21:56. |
27th October 2014, 21:06 | #21695 | Link |
It was a useless attachment anyway (see below). He posted a RAR that contained nothing more than the contents of his previous post and renamed it "BDREBUILDER.INI". Failed to follow moderator instructions -- strike issued.
BDRB-49.05 ? error error ... CreateAVS(),00000 ... system error right...!?! wrong !?!!! Because... BDRB-47.07 ? Encode and/or BATch encode from A to B to ZZZzzz Succesfull and video/audio in sync !! End LOG.... -_- Last edited by jdobbs; 27th October 2014 at 21:17. |
27th October 2014, 21:45 | #21696 | Link | |
Sorry i made the capture this afternoon and the copy of the log later |
27th October 2014, 22:08 | #21698 | Link | |
Could this be happening? |
28th October 2014, 05:24 | #21700 | Link |
Hello. BD-RB made the MKV fine, it seemed. I played it through my HDTV...and as it plays I see a video glitch where it seems the parts are joined and the audio becomes out of sync. I then burned it to a BD-25 RW for my LG 590 to play. Same thing happens. BD-RB Imported...all shows going well. So, I think.."Make a BD from Imported." Well, as you'll see it's attempting to rerender the video even with FORCE_NOENCODE=1. I also changed the output to BD-50 without that option. BD-RB is detecting a challenge because everything shows the resolution is correct, including BD-RB. When played via MPC Home Cinema it plays fine...which I expected.
I have processed Toy Story 3, and some others and they're playing correctly via HDTV. For this, DTS, and English for everything is kept, even multiple streams(tracks). I usually rerender DTS to AC-3, but.. The Import rerendering is what I notice most. I'm still testing. The logs don't indicate anything..and I'm checking the Work directory, as I'm able, for clues. This is the extended version. Playlist 838. Thanks. Code:
[10/27/14] BD Rebuilder v0.49.04 (beta) [00:18:03] Source: NOW_YOU_SEE_ME_00838 - Input BD size: 26.03 GB - Approximate total content: [02:04:48.146] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [00:18:04] PHASE ONE, Encoding - [00:18:04] Processing: VID_00863 (1 of 42) - [00:18:04] Extracting A/V streams [VID_00863] - [00:22:34] Reencoding video [VID_00863] - [00:22:34] Keeping original video (no reencode) - [00:22:34] Processing audio tracks - Track 4352 (eng): Keeping original audio [Redundancy removed] - [00:30:09] Processing: VID_00835 (41 of 42) - [00:30:09] Extracting A/V streams [VID_00835] - [00:30:18] Reencoding video [VID_00835] - [00:30:18] Keeping original video (no reencode) - [00:30:18] Processing: VID_00817 (42 of 42) - [00:30:18] Extracting A/V streams [VID_00817] - [00:30:41] Reencoding video [VID_00817] - [00:30:41] Keeping original video (no reencode) [00:30:41]PHASE ONE complete [00:30:41]PHASE TWO - Rebuild Started - [00:30:41] Building ALTERNATE OUTPUT Structure [00:40:16] - Encode and Rebuild complete [00:40:16] JOB: NOW_YOU_SEE_ME finished. ---------------------- [12:21:22] Importing MKV: NOW_YOU_SEE_ME_01 - Collecting audio/video streams from source... - Building pseudo-BD source structure... [12:26:52] Video import completed successfully. ---------------------- [10/27/14] BD Rebuilder v0.49.04 (beta) [12:30:25] Source: NOW_YOU_SEE_ME_01_00000 - Input BD size: 21.02 GB - Approximate total content: [02:04:48.147] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [12:30:31] PHASE ONE, Encoding - [12:30:31] Processing: VID_00000 (1 of 1) - [12:30:31] Extracting A/V streams [VID_00000] - [12:34:24] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 179,536 frames - Bitrate: 23,660 Kbs - [12:34:24] Reencoding: VID_00000, Pass 1 of 2 [12:57:33]PHASE ONE aborted by user request
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
