2nd June 2009, 15:22 | #8141 | Link | |
MPC-HC Project Manager
http://forum.doom9.org/showthread.ph...931#post678931 Cutting and uploading samples can be found here: http://mpc-hc.wiki.sourceforge.net/T...ing+guidelines |
2nd June 2009, 15:30 | #8142 | Link | |
2nd June 2009, 15:57 | #8143 | Link |
Anime Otaku
Ok, I hope I did it right:
Media info log: Code:
General [57E6D6CF].mkv Format : Matroska File size : 342 MiB Duration : 23mn 0s Overall bit rate : 2 081 Kbps Encoded date : UTC 2009-06-02 00:06:18 Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 26 2007 15:16:15 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Cover : Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 9 frames Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Duration : 22mn 58s Bit rate : 1 910 Kbps Nominal bit rate : 1 964 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.086 Stream size : 314 MiB (92%) Title : Video (H.264) Writing library : x264 core 67 r1153M 7b6ce6a Encoding settings : cabac=1 / ref=9 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=300 / keyint_min=30 / scenecut=40 / rc=2pass / bitrate=1964 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60 Audio ID : 2 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 23mn 0s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Stream size : 21.1 MiB (6%) Title : Japanese Audio (2ch LC-AAC) Writing library : Lancer b5 (UTC 2006-11-10) Language : Japanese Text ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Title : ASS Language : English Menu 00:00:00.000 : :OP 00:01:10.028 : :Part A 00:10:57.990 : :Part B 00:21:50.015 : :ED 00:22:49.950 : :Preview
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit Last edited by cca; 2nd June 2009 at 16:09. |
2nd June 2009, 16:13 | #8144 | Link |
Could you try remuxing the file with the newest build of mkvmerge found here:
http://forum.doom9.org/showthread.ph...74#post1291874 (just load the mkv, change the output name and click the remux button) |
2nd June 2009, 16:16 | #8145 | Link |
Anime Otaku
I can try but not immediately, currently I 'm working, I'll tell you the result in about 3 hours.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
2nd June 2009, 16:24 | #8146 | Link |
Yes. Here is the main file (first 1 minute of it)
http://sharebee.com/b7036b25 Here is the linked one http://sharebee.com/5fa3325d Linked file is called immediately from the main file and it starts playing first. |
2nd June 2009, 16:30 | #8147 | Link | |
It's a million to one chance, but it could possibly work .... Code:
--- MatroskaSplitter.cpp.svn 2009-06-02 17:19:08.885292800 +0200 +++ MatroskaSplitter.cpp.allak 2009-06-02 17:23:57.152780800 +0200 @@ -299,13 +299,36 @@ } else if(CodecID == "V_MPEG2") { + // The CodecPrivate Matroska field shoud contain a copy of the first MPEG2 Sequence header BYTE* seqhdr = pTE->CodecPrivate.GetData(); DWORD len = pTE->CodecPrivate.GetCount(); int w = pTE->v.PixelWidth; int h = pTE->v.PixelHeight; - if(MakeMPEG2MediaType(mt, seqhdr, len, w, h)) - mts.Add(mt); + bool flag = MakeMPEG2MediaType(mt, seqhdr, len, w, h); + + if (! flag) + { + // Here we try a workaround if the seqhdr is missing or malformed + mt.majortype = MEDIATYPE_Video; + mt.subtype = MEDIASUBTYPE_MPEG2_VIDEO; + mt.formattype = FORMAT_MPEG2Video; + + MPEG2VIDEOINFO* vih = (MPEG2VIDEOINFO*)mt.AllocFormatBuffer(sizeof(MPEG2VIDEOINFO)); + memset(mt.Format(), 0, mt.FormatLength()); + vih->hdr.bmiHeader.biSize = sizeof(vih->hdr.bmiHeader); + vih->hdr.bmiHeader.biWidth = w; + vih->hdr.bmiHeader.biHeight = h; + + // We do not have any information, so we leave this blank + // We do hope that this case is handled gracefully downstream + // As far as I can tell, at least that those values are always + // checked for sanity + vih->dwSequenceHeader = NULL; + vih->cbSequenceHeader = 0; + } + + mts.Add(mt); } else if(CodecID == "V_THEORA") { |
2nd June 2009, 16:34 | #8148 | Link | |
2nd June 2009, 16:42 | #8149 | Link |
BTW, it would be much better to do as suggested by Mosu, i.e., try to get the first sequence header from the MPEG2 stream and use it here.
But that would mean that we should put in the Matroska splitter the knowledge to parse an MPEG2 stream, which is non obvious to me and in any case would be clearly overkill. |
2nd June 2009, 16:48 | #8150 | Link |
I can confirm the playback stuttering with DXVA enabled for H.264 videos.
Here's my infamous Tiesto Blu-ray sample: http://stfcc.org/misc/00000.cut.m2ts The crackling audio upon seek is still there by the way. |
2nd June 2009, 18:39 | #8151 | Link |
I want to report another bug when playing linked files.
When linked file is called by the main file video becomes broken on some occasions. Like this: http://img151.imageshack.us/my.php?i...senki01dvd.png It stays broken as long as linked file is playing. When the main file starts playing agian video becomes normal. First I thought it should be haali bug. But when i'm using ffdshow (both ffmpeg and libavcodec) or coreavc (with x86 version of MPC-HC) it plays without issues. Main file (first 4 minutes of it): http://sharebee.com/91c1a2ea Linked file: http://sharebee.com/09e647f1 Linked file is called at 1:54. This sample is SD video encode with 16 Reframes for both main and linked files. MPC-HC cannot use DXVA. I have another HD encode (1080p) with 9 Reframes for both linked and main files. MPC-HC uses DXVA and there is the same issue. If i use internal ffmpeg video becomes broken when playing linked file. If i use ffdshow or coreavc it plays normally. |
2nd June 2009, 19:16 | #8152 | Link | |
Anime Otaku
2nd June 2009, 19:31 | #8153 | Link | |
I could move between the 2 windows without any crashes, but the screen did hang often(for a few seconds) and redrawing was slow. Still the no crashes part is the most important for me. Secondly switching from windowed to fullscreen mode using F11 works fine, but sometimes when i doubleclick the titlebar to change between fullscreen-windowed and 100%zoom-windowed mplayerc will still crash. ------------ @Everyone: There appears to be a regression in the DXVA decoder, we will have to wait for Casimir to login and check those samples. Last edited by tetsuo55; 2nd June 2009 at 21:27. |
2nd June 2009, 19:36 | #8154 | Link |
the hedgehog
on XP and rev1141 the sample you provided presents stuttering, older frames are repeated during playback, and then video freezes arround 00:15 .
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
2nd June 2009, 21:28 | #8156 | Link |
Another bug. Here is the sample:
http://sharebee.com/64d25812 I use ffmpeg internal decoder. I start with window mode. It plays nicely. When I switch to full screen mode video becomes broken (thick green line at the bottom and other video artifacts). Switching back to window mode, video stays broken. No problem with DXVA, ffdshow or coreavc. Also there is a linked opening here: http://www.megaupload.com/?d=R8W8V9PT When I use ffmpeg internal decoder, same issues appear. There is no problem if I play opening separately using DXVA. If I play the main file using DXVA (it calls the opening first), there is very high GPU utilization with all resizers. Video stutters. |
2nd June 2009, 22:20 | #8157 | Link |
Guys, just trying to sort out my list of bugs, and making note of the final 1 or 2 bugs and feature requests I want to make.
Does anyone know if mpc-hc is expected to add files to the playlist when multiple files are opened. If this isn't the current behaviour would anyone object to me adding this as a feature request. I would have expected opening a list of say 6 tv show episodes, to play each in order one after another. |
2nd June 2009, 22:27 | #8158 | Link |
I have submitted a fix for a hang when you move between monitors, but I'm not sure what aspect ratio changes you are talking about when moving between monitors. Do we have a bug for this with sample and which renderer/settings?
MPC-HC with EVR Custom patches |
2nd June 2009, 22:39 | #8159 | Link | |
That specific AR bug can be found here: https://sourceforge.net/tracker/?fun...61&atid=854651 However the original submitter did not post a sample. He does mention that it only occurs with the .avi container and that h264 files are affected more often than other video formats. |
2nd June 2009, 23:57 | #8160 | Link | |
DXVA decoder completely broken starting from 1141
To Casimir and Aleksoid:
Starting with 1141 the internal DXVA decoder is completely broken. All h264 and vc-1 BD m2ts i tried show only every second frame and jump between frames. 1137 works perfectly. I have Wait For GPU Flush enabled and it shows insane amounts of wait for gpu times. System: XP SP3, ATI 2600 Pro AGP, VMR9 rl, VSYNC all off, Wait for GPU & Flush before Vsync enabled. Same error with Wait for GPU and Flush before Vsync disabled. Using the Cyberlink DXVA H264 decoder works. So it must be the changes to the internal MPC DXVA decoder. Quote:
