Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 16th May 2004, 21:51   #1  |  Link
spaeter
Auto Gordian Knot: EXCEPTION: Open avi failed.
Hallo!!!
I've tried to use autogk to encoding a dvd into divx/xvid, but I always have the same error. Here is the end of the log file.
12/05/04 19.02.21] Input dir: C:\*******\VIDEO_TS
[12/05/04 19.02.21] Output file: C:\******\VIDEO_TS\gk_tmp\*****.avi
[12/05/04 19.02.21] Audio: Italiano
[12/05/04 19.02.21] Subtitles: none
[12/05/04 19.02.21] Codec: XviD
[12/05/04 19.02.21] Target size: 1400Mb
[12/05/04 19.02.21] Started encoding.
[12/05/04 19.02.21] Demuxing and indexing.
[12/05/04 19.07.56] Analyzing source.
[12/05/04 19.20.03] Source is considered to be progressive.
[12/05/04 19.20.03] Found 196160 frames
[12/05/04 19.20.04] Audio size: 376,627,200 bytes (359.18 Mb)
[12/05/04 19.20.04] Overhead: 1,307,776 bytes (1.25 Mb)
[12/05/04 19.20.04] Video size: 1,090,071,424 bytes (1039.57 Mb)
[12/05/04 19.20.04] Running compressibility test.
[12/05/04 19.33.01] Duration was: 12 minutes 57 seconds
[12/05/04 19.33.01] Speed was: 12,62 fps.
[12/05/04 19.33.02] Job finished.
I've tried to use some different versions of autogk (from 1.0 to 1.22), but always with the same problem.
The fact is that, using other softwares (for example xmpeg5 or gordian knot 0.28) I finish the job without problems.
Can you help me? What is the problem? what can I do to solve it?
Thanks!!!
spaeter is offline   Reply With Quote
Old 17th May 2004, 13:18   #2  |  Link
len0x
I'm afraid we've to stop
len0x's Avatar
which OS are you using ?
Gordian Knot Family:
Gordian Knot: website, download
Auto Gordian Knot: Website and download, tutorial, FAQ
len0x is offline   Reply With Quote
Old 17th May 2004, 14:01   #3  |  Link
spaeter
Windows XP Pro SP1
Processor is Pentium IV 3Ghz
Codec divx 5.1.1
codec XviD 1.0.0 RC4
Old 17th May 2004, 14:05   #4  |  Link
len0x
len0x's Avatar
Tough one. Can you properly play *name*_comptest.avi from gk_tmp directory in WMP?
It looks to me like your windows cannot properly open avi files (may be because you're using ffdshow or something)...
Old 17th May 2004, 14:16   #5  |  Link
spaeter
I try to do this at home tonight...
I'm at work now...
bye!
Old 17th May 2004, 18:00   #6  |  Link
spaeter
Yes I can...
File *name*_comptest.avi from gk_tmp directory play with Windows Media Player 9 without problems.
No sound and the video is divided in some different frames (6 minutes for a film of about 2 hours).
Old 17th May 2004, 18:07   #7  |  Link
len0x
len0x's Avatar
can you post rendering path from GSpot 2.21 please (just in case).
Old 17th May 2004, 18:21   #8  |  Link
spaeter
The information you ask me are these?
Video Path: (S) --> AVI Splitter --> XviD MPEG-4 Video Decoder --> (R)
Video Src Type: 4cc: DX50
Details:
DirectShow claims to be able to play the file. The following combination of filters were used:
{C:\******\VIDEO_TS\gk_tmp\****_comptest.avi} (Video Source)
{AVI Splitter} (Video Pre-processor)
{XviD MPEG-4 Video Decoder} (Video Decoder)
{Video Renderer} (Video Renderer)
Old 17th May 2004, 18:24   #9  |  Link
len0x
len0x's Avatar
what puzzles me here is how come when using XviD you end up with DX50 4cc?
Old 17th May 2004, 19:31   #10  |  Link
spaeter
Sorry!!!
I make test with both dvix and xvid...
These are the informations of the file made with xvid codec..
Video Src Type: 4cc: XVID
Details:
{C:\MATRIX\VIDEO_TS\gk_tmp\Matrix_comptest.avi} (Video Source)
Old 18th May 2004, 16:18   #11  |  Link
len0x
len0x's Avatar
which XviD version are you using (you might wanna try latest final 1.0)? I have no idea why this is a problem though.
(you can also try installing xvid without support for other 4cc and then doing DivX test so that it gets decoded by divx filter - this might eliminate case when your xvid DShow filter is at fault).
Old 18th May 2004, 21:04   #12  |  Link
spaeter
try as suggest by you:
- before i used codec XviD 1.0.0 RC4
- uninstall xvid codec 1.0.0 rc4
- install xvid 1.0.0 final (without support for other 4cc) with new version of autogk 1.24b
- run autogk with divx but always the same problem.
is it possible that i do something wrong during the 4 step of configuring autogk?
p.s.: the preview runs correctly
Old 19th May 2004, 14:23   #13  |  Link
len0x
len0x's Avatar
Let me tell you what's the error is all about.
After comp test AutoGK tries to open AVI via windows avifil32.dll to get the resolution of it and hence AR to get resize step correctly. Since it fails to do so this means:
- either file cannot be opened via that dll due to codec/filter problem
- file is still in use (unlikely but its worth checking if you can delete or copy that file straight after error occured)
I have no idea what can cause that and without having this problem on the PC where I can run debugger its kinda impossible to solve.
Old 19th May 2004, 14:43   #14  |  Link
spaeter
I try to delete the file avifil32.dll now (no autogk or other similar program in use).
I cannot delete it because "it's still in use".
i think this is the problem...
Old 19th May 2004, 14:45   #15  |  Link
len0x
len0x's Avatar
wow - I never said to detele that file!
I asked to try to detele comp test AVI...
Old 19th May 2004, 14:53   #16  |  Link
spaeter
oops... sorry
i run another time autogk this evening and then i try to delete comp test AVI...
bye
Old 25th May 2004, 21:37   #17  |  Link
darkCapricorn
The same thing happened to me after installing an application that deleted all of the registry settings under HKEY_CLASSES_ROOT\avifile\Compressors, HKEY_CLASSES_ROOT\avifile\Extensions, and HKEY_CLASSES_ROOT\avifile\RIFFHandlers.
Simply checking for and adding (if missing) the following registry keys fixed it for me (valid for XP SP1):
[HKEY_CLASSES_ROOT\AVIfile\Compressors\auds]
@="{0002000F-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\AVIfile\Compressors\vids]
@="{00020001-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\AVIfile\Extensions\AU]
@="{00020003-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\AVIfile\Extensions\AVI]
@="{00020000-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\AVIfile\Extensions\WAV]
[HKEY_CLASSES_ROOT\AVIfile\RIFFHandlers\AVI]
[HKEY_CLASSES_ROOT\AVIfile\RIFFHandlers\WAVE]
darkCapricorn is offline   Reply With Quote
Old 25th May 2004, 22:23   #18  |  Link
spaeter
Check the registry settings. I find all the registry keys you indicate, except these:
@="{00020000-0000-0000-C000-000000000046}" was missing. Add a new one.
Here i find another one: "{894288e0-0948-11d2-8109-004845000eb5}": is this to delete or to leave?
thanks for all!
Old 25th May 2004, 23:46   #19  |  Link
darkCapricorn
thanks for all!
AH!HA! rather than adding those entries that i previously mentioned, go into the folder C:\Program Files\AutoGK\VDubMod\aviproxy and merge the file proxyoff.reg
then you should be good to go.
Old 26th May 2004, 10:52   #20  |  Link
len0x
len0x's Avatar
If this is always working then GREAT! I'll add this to the FAQ.
