#1 | Link |
HowTo correctly avoid resampling problems with Nero AAC encoder in Besweet/Oagmachine
IMPORTANT UPDATE:
thanks to great DSPGuru all the info posted in this thread is now used by besweet (since bsn.dll version 0.21) to automatically set the SSRC resampling values (no need to change that by hand anymore) now lets hope that the ahead devs dont change any of these values ![]() as i very often read some posts which claimed that you have to always resample to 44.1khz when using the nero aac encoder dlls with besweet/oagmachine, i wanted to make clear that this is not correct! you will get borked output in many cases if you do so! this thread aims to tell you how to correctly use the ssrc resampling option in besweet/oagmachine to avoid resampling problems: a) how the nero dlls work (according to menno) 1) the nero encoder dlls themselves dont do any resampling 2) the resampling is done by an own nero resampling plugin 3) the user chooses a bitrate and the encoder requests a specific sampling rate as input for this bitrate 4) now the resampling plugin would normally resample to this specific sampling rate 5) but nencoder and besweet ignore this request, therefore the encoder dlls dont get the requested input sampling rate example: a user chooses 80kbps lc-aac as output in the nero encoder. the encoder requests 32khz for that bitrate, but besweet gives him 48khz or 44.1khz (or whatever other, from 32khz different, setting the user choose to resample to in besweet) -> the output is borked b) conclusion you have to feed the nero encoder with the sampling rate he needs for a specific bitrate, otherwise you will get a wrong output which means in besweet you have to set the correct sampling rate by using ssrc! i now tested all possible sampling rates at specific bitrates with the following results: Code:
bitrate samplerate profile samplerate CBR VBR HE-AAC HE-AAC mono stereo 5.1 stereo 5.1 8 24000 16 24000 40 24000 Tape 44100 Tape 44100 10 24000 20 24000 48 24000 Radio 44100 Radio 44100 12 32000 24 32000 64 32000 Internet 44100 Internet 44100 14 32000 28 32000 80 32000 Streaming 44100 Streaming 44100 16 44100 32 44100 96 44100 20 44100 40 44100 112 44100 24 44100 48 44100 128 44100 28 44100 56 44100 144 44100 32 44100 64 44100 160 44100 40 44100 80 44100 192 44100 48 44100 96 44100 LC-AAC LC-AAC mono stereo 5.1 stereo 5.1 8 8000 16 8000 40 8000 Tape 24000 Tape 24000 12 11025 20 8000 48 11025 Radio 32000 Radio 32000 16 16000 24 11025 64 16000 Internet 44100 Internet 44100 20 16000 28 11025 80 16000 Streaming 44100 Streaming 44100 24 22050 32 16000 96 22050 Normal 44100 Normal 44100 28 24000 40 22050 128 24000 Extreme 44100 Extreme 44100 32 32000 48 22050 160 32000 Audiophile 44100 Audiophile 44100 40 32000 56 24000 192 32000 Transcoding 44100 Transcoding 44100 56 44100 64 32000 225 32000 64 44100 80 32000 256 44100 80 44100 96 32000 288 44100 96 44100 112 44100 320 44100 112 44100 128 44100 384 44100 128 44100 144 44100 480 44100 160 44100 160 44100 512 44100 192 44100 256 44100 you want to encode multichannel, vbr, with he-aac and the streaming preset: you have to set the sampling rate in besweet under ssrc to 44100 you want to encode stereo, cbr, with lc-aac at 96kbps: you have to set the sampling rate in besweet under ssrc to 32000
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 6th January 2004 at 23:31. |
#2 | Link |
Nice work bond! Thanks for performing these tests. AAC FAQ #19 updated with this info.
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ |
#4 | Link | |
this is true for every tool that is based on the nencoder tool, ie besweet (with gui), oagmachine or all tools that use the nencoder commandline tool directly its nencoders fault that it ignores the request from the encoder plugin for a specific samplerate foobars foo_nero plugin doesnt use nencoder and handles this request fine already, read more about it here!
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 2nd January 2004 at 18:16. |
#6 | Link |
according to menno it isnt (perhaps it was in the beginning)
but plz discuss foobar issues in the foobar thread
#8 | Link |
I'm back! :D
Thanks bond, this is what i was expecting for ages. I have already done similar tests a while ago, but could not conclude anything.(Though the test was not detailed as you did). And mikeson and I did pointed DSPguru to give a clarification on this phenomenon. But as Dg has no time he could not reply. And for the time I put resampling to 44 in faq like doom9 did in Oagmachine guide. Thanks for clarfying.
Thanks for the detailed table too. Now if an algorithm is made on these table, I think BeSweet also can properly encode at every sampled sound. For the time being we could manually use this table. btw I have a doubt, only LC CBR profile (stereo and 5.1) doesn't allow 48khz encoding, mono and VBR can do it perfectly. btw2, bond if you can again contact menno, can you ask the bitrate distribution question for LC AAC. (2x128+64+1=321kbps) vs (2x96+48+1=241kbps). I still doubt it. Thanks
My Blog |
#9 | Link | ||
i now deleted the 48khz marks as i checked it again and it seems, although the encoder can handle 48khz in some cases when accessed through buring rom, that when used with besweet it doesnt handle 48khz input at all Quote:
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 2nd January 2004 at 20:53. |
#11 | Link | |
I'm back! :D
So I think instead of using 128, the bitrate should be 96kbps. That is all. I have already PMed menno with this doubt. Hope he will visit doom9 soon and we could get an explanation.
My Blog |
#12 | Link |
BeSweet Author
thank you bond for your research and posting this informative thread, but the bug had been fixed now (due to tip from menno), and the best way to avoid resampling problems now is just to work with the latest BeSweet binaries.
FAQs : BeSweet, Audio :readfaq: Homepage : DSPguru's Webpage http://dspguru.notrace.dk/cs.gif Guides : Multilingual Guides of my tools http://dspguru.notrace.dk/1zhelp.gif |
#14 | Link |
great thanks a lot dspguru!
#15 | Link | |
I'm back! :D
![]() Thanks.
My Blog Last edited by Tuning; 7th January 2004 at 06:36. |
| Display Modes | |
