Old 6th February 2003, 04:20   #1  |  Link
cjaar
cjaar's Avatar
Want to hv both ver of avisynth 2.07 & 2.5, but how???
@all..
I want to retain the old ver 2.07 for my normal encodes, but also want to try the new 2.5. Everytime i hv to replace the avisynth.dll in systen32 dir.
placing 2.07 in vdub and 2.5 in vdmod doesnt work, i get the error.
how can i hv both dlls.
thanks
cj
cjaar is offline   Reply With Quote
Old 6th February 2003, 08:37   #2  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Use "search" - someone posted a script for this a short while ago.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 6th February 2003, 09:51   #3  |  Link
N_F
Do you find me... pretty?
N_F's Avatar
You have one or two suggestions here
Though I personally did this:
1. Install 2.07.
2. Go to c:\windows\system32 and rename avisynth.dll to avisynth_207.dll
3. Install 2.50
4. Go to c:\windows\system32 and rename avisynth.dll to avisynth_250.dll
5. Create a file named Avisynth207.bat which should contain the following:
copy /y c:\windows\system32\avisynth_207.dll c:\windows\system32\avisynth.dll
6. Create a file named Avisynth250.bat which should contain the following:
copy /y c:\windows\system32\avisynth_250.dll c:\windows\system32\avisynth.dll
Just run the bat file with the version you want each time you want to make the switch.
Edit: Realised I could make the batch files even easier.
N_F is offline   Reply With Quote
