#1 | Link |
C64
BYTE - avisynth.h
Maybe two dumb question:
1) When and why was unsigned char pixel_type; changed to BYTE pixel_type; and 2) where gets BYTE defined because when I try to compile a plugin which uses a newer avisynth.h which contains BYTE this type is not recognised (VC++6.0) |
#5 | Link |
I was wondering how BYTE slipped into the avisynth.h also. I don't include windows.h. It is not nesessary except for that one define. I never worked with Visual anything, but I assume that windows.h is included automatically. Not having the define would make avisynth progamming more accessible to those of us who have to create our progamming environments with batch files.
In other word, don't we want avisynth filters to be programmable with any windows c++ compiler? I use Microsoft's cl.exe and link.exe, literally the minimum requirements. Well, also ml.exe. It works fine after the BYTEs are replaced and ASSERTE is defined to void. Any experienced programmer should know how to deal with it, but still, it is mildly worrying. What if something truly incompatible slipped through? Stephen |
#6 | Link |
developer wannabe
When I split up the code for 2.0, some parts used BYTE and others 'unsigned char'. I decided to standardize on BYTE since it was clearer and easier to type -- perhaps a typedef to 'Pixel8' or something would be even clearer, but I doubt anyone's confused at this point...
ASSERTE has been around much longer still. If you don't want to include <windef.h> (though I can't see what advantage there is to excluding it), you should still paste in the definition IMHO -- it's quite a useful macro for debug-builds. |
#7 | Link |
Richard -
I don't know the advantages of including windef.h. My point is if it needs to be there, it should already be included with an include statement like this: Code:
#include windef.h When I added a define BYTE statement in avisynth.h I got an error saying that BYTE is defined twice. If I did not add it I got an error saying BYTE is not defined. So either I needed to figure out which windows header I needed to include that was not included already (and I could not decide which one) or replace every instance of BYTE with unsigned char (don't forget to check match case). unsigned char is c++ code, BYTE is not, therefore using unsigned char (albeit with more to type) keeps the avisynth include file compatible with as many development environments as possible. So the issue for me is whether it is a priority to make compiling filters as accessible to newbies as possible or not. BYTE is fine with me as long as the definition is included by default. I know it does not make any difference to the final dll, but I would prefer it not to be there since defs can create problems that show up in some programming environments and not in others. Stephen |
#8 | Link |
developer wannabe
Yes, I agree it would be cleaner still to do the necessary #defines ourselves. However, that will generate spurious warnings for people who do have <windef.h> included. As Donald noted earlier, this task is currently delegated to internal.h instead of avisynth.h. Now that we're making the latter the "official" Avisynth interface (releasing it with a different license, etc.), moving all necessary inclusions to there may be worth examining.
In my mind the issue this actually raises is the total lack of a plugin SDK beyond the original version 0.xxx doc on BenRG's site. I've only compiled external plugins once or twice, but if someone more familiar with it wants to write up a guide then I'd fully support that being a major goal for v2.5 (though we should wait until the interface is finalized in the beta). |
#9 | Link |
When I wrote a filter that displays 75% color bars in YUY2 and now YV12, I ran into difficulties trying to remove IClip as an argument. With only Ben's site to go on, there is no model for writing any source filter except the 281002 source.cpp, which by the way everyone should consult when they have questions. Dividee had my back this time, he seemed to understand the problems someone will have when faced with this problem for the first time. I needed to add this line in the class descritption at the top:
vi.audio_samples_per_second = 0; As a principle, I still say avoid things like BYTE, because it is not an official c++ keyword. unsigned char is unambiguously defined already. Stephen |
#10 | Link |
C64
1) What's 281002 source.cpp ?
2) Some SDK and/or some template filters would indeed be good. The program is really complicated (because of the C++ interface,...) You have to learn: - using the compiler - nearly the complete C++ functionality - an nearly undocumented interface (to AviSynth) - struggle with many defines, similar names,... which for me (I'm no programming newbie, although just - being forced by AviSynth - starting to explore C++)- debug a DLL (much more difficult than a standalone prog) - understand the used formats (video, audio) I'm sure it could be good for the AviSynth future if the possibility of developing filters is easier (would be a feature that is not available to "alternative products"). And getting 2.5 to the masses will need MUCH propulsion power - the advantages so far (a little more speed, a color format more to learn, complicated audio handling) are not convincing (not meaning to me of course but to the everday user) [edit] and those dual version DLL thingie from the other thread is an absolute MUST for 2.5 Last edited by WarpEnterprises; 13th December 2002 at 23:08. |
#11 | Link | |
Go to the AviSynth 2.5 alpha page and download the sources link just below the dll and header link. Right now, I am trying to write a series of very simple, short filter that can serve as an example of every aspect of filter writing, starting with playing with the YV12 color space, converting to YUY2 both with and without interpolation, RGB, greyscale, color bars in YV12 and YUY2 instead of RGB, and next I'll try a single purpose BOB, of course aimed at avoiding the shimmering effect. Today I linked an object file from c and from masm. I think that is better than using __asm. The point being that eventually I might put together an SDK based on many more options than Invert supplies or at least explain how to do more. The third point is that you can make dlls that work for both 2.0 and 2.5: eventually 2.5 will be the only version of AviSynth that exists. I am concentrating on the long term in case my AviSynth progamming skills are not up to snuff until 2.0 is just a memory anyway. This switch to YV12 is coming at a time when there are plenty of programmers who understand color space. It is not any harder to program for 2.5 than 2.0 to someone new to AviSynth programming. Gradually everyone will find compelling reasons to switch to 2.5. Anyway, I am banking on 2.5 being the only version available sometime in the future. On the other hand, the transition period is probably long enough to justify the effort to learn how to pack both versions in one dll. It is certainly a neat trick that might have other applications anyway. Stephen |
#12 | Link | |
Super Moderator
![]() Join Date: Nov 2001
#13 | Link | |
developer wannabe
#define BYTE unsigned char typedef BYTE unsigned char In truth, we don't have to worry much about platforms where sizeof(short) == sizeof(int), since they're all really old, and the code where >32-bit registers may come into use is already mostly in assembly. (Pointers are another matter, though -- you can't assume sizeof(void*) == sizeof(int)!) And in this particular case, char is a bit unique in that it's fixed at 8 bits in the C++ spec. Nevertheless, given how much video code depends on fixed-width chunks of memory, it's a really good idea to abstract away from primitive types. |
#14 | Link | ||
@Richard
In the AviSynth source code as a whole, Richard, using BYTE is not a problem. The difference is that all the needed headers and their definitions get pulled in when the AviSynth dll is compiled. But by itself, there is an undefined token floating around in avisynth.h that does not belong there. Newbies get told to get the avisynth header and an example program and compiler them together, but it will not compile, and that is not fair to newbies. None of the explanations of what to do about it explains why it is there. At the top of the page, there where two questions, neither of which have been answered by anybody: Quote:
Theses are actual problems that can and should be fixed by changing avisynth.h. Stephen PS, the question 'when was it added' got my attention and when I realized that no one was going to answer it, then I jumped in. Last edited by scmccarthy; 14th December 2002 at 17:31. |
#15 | Link |
developer wannabe
Like I said above, I did it sometime during last summer's reorganization. Before, different parts of the code used different types, and standardizing things seemed like a relatively easy way to improve the readability of what was then a very messy codebase. We've still got a long way to go in that department, but consider that I wasn't much more than a newbie at the time, so believe me the various names scattered everywhere was more confusing.
If you disagree with the reasons I gave for picking 'BYTE' then so be it, but don't say there's "no justification" right after I list several. It should be clear from what I've written that I support (1) making avisynth.h directly compilable (2) creating better documentation for new developers, so I can't imagine what the conflict is. With any luck I'll have some time this weekend to help out myself. |
#16 | Link |
C64
Thanks, for me the two questions are answered sufficiantly.
Maybe it should read more clearly somewhere in a filter SDK "learn the C++ basics first" which I'm doing now and which is much better than dumbly trying to compile CPPs if it only were easier... |
#17 | Link |
Simply me
Pennies worth from a thicko
As a "dumb" C++ programmer, I'd just like to add the comment that if the gods themselves - Avery and Ben had not
a) Made it easy to "dumb" programme with their simple SDK's and simple examples (which at the time seemed very, very complicated) and b) Not assisted idiots like myself (and others not so thick) in learning C/C++ basics then the whole shebang of VirtualDub and Avisynth filter writing would not have taken off. I haven't a clue what you guys are on about (Well maybe a little bit) but us not so clever ones just would like the new 2.5 to be compiled with VC++, so we can do our include Avisynth.h for y = 0 to h for x= 0 to w pixel = some wonderful brilliant idea f(Pixel) next x next y filters and then convert it to SSEX III (or whatever) at a later stage when we've had the brain transplant regards Simon
http://www.geocities.com/siwalters_uk/fnews.html |
#19 | Link |
Yes, your right, I am picking at this.
Ben's clever use of C++ object oriented abstraction made it very easy to write filters for AviSynth. I actually get this stuff @Sh0dan - It seems I must add: Code:
#include <windef.h> Stephen |
#20 | Link | |
However I'm also one of those programmers you've probably heard of who just doesn't think object oriented that way, and probably never will as a native language, so I have sort of a read-only understanding of how all that works. I have to puzzle through it again each time, but I still appreciate it. ![]() - Tom |
| Display Modes | |
