Old 1st December 2002, 13:19   #1  |  Link
ivan_alias
H.264 is the Future
ivan_alias's Avatar
filters filters everywhere!
I have installed and removed so many codecs and directshow filters over the years my system is becomming a mess.
Is there any easy to use tools that will list all the filters and codecs I have installed on my system and let me remove the ones I want with ease?
Anything like this out there?
ivan_alias is offline   Reply With Quote
Old 1st December 2002, 21:43   #2  |  Link
Arky
yes there is - I have it but have never bothered using it. It's called erm...
I'll edit this post when I remember the name (arghh!!!).
Short answer - "yes, there IS!"
Arky ;o)...I think it;s called something like "gejsrv32...."
Arky is offline   Reply With Quote
Old 1st December 2002, 22:20   #3  |  Link
ivan_alias
H.264 is the Future
ivan_alias's Avatar
I appreciate your humor, but I genuinely would like a tool that can list and remove the installed filters.
I don't think you can do that with regsvr32 unless I'm mistaken.
Old 2nd December 2002, 00:20   #4  |  Link
[Toff]
You can try GSpot to list installed codec :
http://www.headbands.com/gspot/
There is no direct easy uninstall function but at least it will give you the associated .dll or .ax so you can try a regsvr32 /u
Regards [Toff]
[Toff] is offline   Reply With Quote
Old 2nd December 2002, 00:40   #5  |  Link
TheWEF
Gordian Mod.
TheWEF's Avatar
have a look into your windows device manager...
wef.
TheWEF is offline   Reply With Quote
Old 2nd December 2002, 01:37   #6  |  Link
celtic_druid
celtic_druid's Avatar
Could try SysEnum which comes with Graphedit... Doesn't have a feature to uninstall them though.
celtic_druid is offline   Reply With Quote
Old 2nd December 2002, 10:29   #7  |  Link
BlackSun
CoreCodec
BlackSun's Avatar
Yes there is one... Can't remember the name
Let's try to google a bit...
(googling, googling...)
(about to give up)
Sorry can't find I just remember there is a 'X' in the name
BlackSun
The Concentric Circles of Audio and Video
BlackSun is offline   Reply With Quote
Old 8th December 2002, 09:12   #8  |  Link
ivan_alias
H.264 is the Future
ivan_alias's Avatar
dammit zoom player does it !
Fantastic tool
Old 9th December 2002, 16:34   #9  |  Link
mikeathome
Gej's super register tool does the trick, right click an .ax .dll and you'll get a choise to register or un-register. Great tool from the patcher of the WMA MPEG-4 Codec (Divx...
Save the following as RegShExt.inf and Install it.
; RegSvr32 Shell Extension
; Registriere DLL, OCX, EXE per Rechtsklick
; Win 9x, NT4 & 2k
; Release 1.0
; By Gej 03.03.2000
[Version]
signature="$chicago$"
[DefaultInstall]
CopyFiles=Files.inf
AddReg=Reg.Add,Reg.Uninstall
[DefaultInstall.ntx86]
CopyFiles=Files.inf
AddReg=Reg.Add,Reg.Uninstall.NT
[DefaultUninstall]
DelFiles=Files.inf
DelReg=Reg.Add,Reg.Uninstall,Reg.Uninstall.NT,Reg.Remove,
[SourceDisksNames]
1="%01%",,1
[Reg.Uninstall]
HKLM,%UnInstallPath%,DisplayName,,%UninstallDispName%
HKLM,%UnInstallPath%,UninstallString,,"%10%\rundll.exe setupx.dll,InstallHinfSection DefaultUninstall 132 %17%\%InfFile%"
[Reg.Uninstall.NT]
HKLM,%UnInstallPath%,UninstallString,,"%11%\rundll32.exe setupapi,InstallHinfSection DefaultUninstall 132 %17%\%InfFile%"
[Reg.Add]
HKCR,.ocx\shell\RegOCX,,,Register
HKCR,.ocx\shell\RegOCX\command,,,"regsvr32 %1"
HKCR,.ocx\shell\UnRegOCX,,,UnRegister
HKCR,.ocx\shell\UnRegOCX\command,,,"regsvr32 /u %1"
HKCR,.ax\shell\RegAX,,,"Register Filter"
HKCR,.ax\shell\RegAX\command,,,"regsvr32 %1"
HKCR,.ax\shell\UnRegAX,,,"UnRegister Filter"
HKCR,.ax\shell\UnRegAX\command,,,"regsvr32 /u %1"
HKCR,dllfile\shell\RegDLL,,,Register
HKCR,dllfile\shell\RegDLL\command,,,"regsvr32 %1"
HKCR,dllfile\shell\UnRegDLL,,,UnRegister
HKCR,dllfile\shell\UnRegDLL\command,,,"regsvr32 /u %1"
HKCR,exefile\shell\RegEXE,,,"Register Server"
HKCR,exefile\shell\RegEXE\command,,,"%1 /regserver"
HKCR,exefile\shell\UnRegEXE,,,"UnRegister Server"
HKCR,exefile\shell\UnRegEXE\command,,,"%1 /unregserver"
[Reg.Remove]
[Strings]
InfFile="RegShExt.inf"
SetupRegPath="Software\Microsoft\Windows\CurrentVersion\Setup"
UninstallDispName="RegSvr32 Shell Extension"
UnInstallPath="Software\Microsoft\Windows\CurrentVersion\Uninstall\RegSvr32ShellExtension"
[DestinationDirs]
Files.Inf=17
[Files.Inf]
RegShExt.inf
mike
mikeathome is offline   Reply With Quote
Old 11th December 2002, 21:05   #10  |  Link
birdy
@ mikeathome,
Thanx a lot for this real great tip man.
I was using regsvr32.exe till now.
birdy is offline   Reply With Quote
Old 12th December 2002, 09:47   #11  |  Link
mikeathome
Originally posted by birdy
@ mikeathome,
You're welcome !
mike
