#1641 | Link | |
Formerly davidh*****
![]() Join Date: Jan 2004
Perhaps I should get clang... |
#1642 | Link |
Mmm. MSYS2 nasm shouldn't be issue because when I type in the ucrt64 shell "where nasm" I get "C:\msys64\ucrt64\bin\nasm.exe". You need "mingw-w64-ucrt-x86_64-nasm".
If you didn't see the other edits from my previous post I updated the script to be more friendly. Also you can use vcpkg to build ffmpeg with MSVC much more easily. Edit: for vcpkg you can see an example here. Last edited by StvG; 31st January 2025 at 23:08. |
#1643 | Link |
Yup, that's the same result I get from "where nasm". But I haven't done anything to tell Visual Studio/cl.exe to use nasm when it finds inline assembler, if that can even be done...
I tried with the new version of script, with these changes: Code:
compiler="cl" cmake_path="/c/Program Files/CMake/bin/cmake" dav1d_cross_file="/c/msys64/home/David/dav1d_cross.txt" |
#1645 | Link | |
#1646 | Link |
Thanks. Found the issue (I thought modifying mingw header was only necessary clang-cl). Use this script https://pastebin.com/gJTFMdzd
#1647 | Link | |
I was getting a few instances of this: Code:
Cannot open include file: 'stdalign.h' Code:
Compiler lacks support for C11 static assertions |
#1648 | Link |
I have it - https://i.ibb.co/VcyPrtKQ/Untitled.png. Try to install the latest Windows SDK or reinstall the one you have.
#1649 | Link | |
I'll try running the script again tomorrow to see if I still get the same C11 static error. |
#1651 | Link | |
Okay, that all seems to have worked!
So now I need to: Quote:
What are the files that L-SMASH Works will be looking for in "DCMAKE_PREFIX_PATH="path_to_folder_where_are_include/lib_directories" when I get that far?
#1652 | Link | ||
#1653 | Link | |
FFmpeg include files/libraries, external libs/include files, liblsmash include file/lib, obuparse include file/lib... |
#1654 | Link |
Okay... for obuparse, since it doesn't have a configure script, I edited the Makefile and just changed the first line to
PREFIX ?= ~/deps/x64-release For l-smash, I did Code:
./configure --prefix="~/deps/x64-release" --extra-cflags=-I/home/david/deps/x64-Release/include --extra-ldflags=-L/home/david/deps/x64-Release/lib --includedir=~/deps/x64-Release/include --libdir=~/deps/x64-Release/lib make/make install put .h and .a files in the x64-Release/include and x64-Release/lib directories. Next: Code:
cmake -B build_folder -DCMAKE_PREFIX_PATH="C:\msys64\home\David\deps\x64-Release" -DENABLE_VPX=OFF Trying to build the created .sln resulted in four unresolved externals: Code:
__mingw_fprintf __mingw_sprintf ___chkstk_ms __mingw_vfprintf Last edited by wonkey_monkey; 2nd February 2025 at 00:03. |
#1655 | Link |
Actually I build obuparse with created VS solution files and manually copy "obuparse.h" and the lib in "deps\x64-Release\relevant_dirs". Also I modified lsmash VS solution files to work correctly with vimeo version and again manually copy "lsmash.h" and "liblsmash.lib" to "deps\x64-Release\relevant_dirs". If you prefer VS solution files, I can share them so you can build them with VS.
#1656 | Link | |
Edit: Oh, for obuparse and liblsmash I guess you didn't explicitly used cl instead GCC. You can do in the shell: "export CC=cl". Last edited by StvG; 2nd February 2025 at 00:19. |
#1657 | Link |
It's not necessary to specify --includedir= or --libdir= if you've set --prefix. Those are automatically populated by whatever the prefix is, and you only really want to change them if you deliberately want them somewhere else.
And the extra-{cflags,ldflags} arguments can understand $HOME, e.g., --extra-cflags=-I$HOME/deps/x64-Release/include. Not finding Git or pkgconf sounds like you haven't added MSys2's /usr/bin to the %PATH% (or alternatively, launched MSys2 from within the VS Command Prompt so the MSys2 environment can see MSVC). |
#1659 | Link | |
Here are the VS solution files for obuparse and l-smash. Extract them in the root of the relevant folders and build the libs from there. Edit: Copy "obuparse.h" in the root of l-smash folder. Last edited by StvG; 2nd February 2025 at 00:56. |
#1660 | Link | |
