Old 7th March 2005, 19:02   #81  |  Link
Kyle_Katarn
VTB v1.2.3.73 [07/03/2005]
# Web codecs providers (Moviecodec.com instead of MovieCodecs.com)
http://www.kcsoftwares.com/?vtb
KC Softwares
Kyle_Katarn is offline   Reply With Quote
Old 4th April 2005, 17:46   #82  |  Link
Kyle_Katarn
VTB v1.3.0.75 [04/04/2005]
+ Command Line Support
KC Softwares
Old 4th May 2005, 14:22   #83  |  Link
Kyle_Katarn
VTB v1.4.0.78 [04/05/2005]
+ "Submit statistics" button
KC Softwares
Old 8th May 2005, 22:25   #84  |  Link
Kyle_Katarn
VTB v1.4.1.80 [08/05/2005]
+ "View" button
+ Now uses KC Softwares Online Codec Database by default
# [AVI] Bug with Windows's RLE encoded Clock.avi
KC Softwares
Old 11th May 2005, 17:39   #85  |  Link
Bro
Hi
I found the video bitrate reported by Video Insepctor on most avi files to be too high compared to gspot, virtualDub and media info...
Video Insepctor lies about 5-10 kbit over the others...
Are you aware of this?
Bro is offline   Reply With Quote
Old 11th May 2005, 18:58   #86  |  Link
Kyle_Katarn
Known bug due to computation method... Will be fixed soon !
KC Softwares
Old 11th May 2005, 22:00   #87  |  Link
Bro
hi
while you're here...
Can you tell me how you calculate the duration on MPEG1/2 files?
reading the time from the last GOP does work but you need to find it first...which takes alot of time....
Is that how you do it? (is it the only way?)
Old 16th May 2005, 23:39   #88  |  Link
Kyle_Katarn
MPEG support is still experimental... Will be improved soon thanks to MediaInfo
KC Softwares
Old 16th May 2005, 23:39   #89  |  Link
Kyle_Katarn
VTB v1.4.2.81 [19/05/2005]
@ Tooltip added for file name
@ New codec database (Video:442 Audio:195)
KC Softwares
Old 6th June 2005, 23:19   #90  |  Link
Kyle_Katarn
VTB v1.5.0.83 [06/06/2005]
+ AviBitRate Grapher
+ AutoSubmit statistics
@ New codec database (Video:444 Audio:197)
KC Softwares
Old 27th June 2005, 18:34   #91  |  Link
Kyle_Katarn
VTB v1.5.1.84 [27/06/2005]
@ New codec database (Video:460 Audio:204)
# Fixed stats button display glitch
KC Softwares
Old 29th July 2005, 17:23   #92  |  Link
Kyle_Katarn
VTB v1.6.0.85 [27/07/2005]
+ FourCC Editor (AVI files Only)
@ New codec database (Video:465 Audio:205)
@ Internal Core code
KC Softwares
Old 23rd August 2005, 19:48   #93  |  Link
Kyle_Katarn
VTB v1.6.1.87 [23/08/2005]
@ New codec database (Video:475 Audio:222)
@ [AVI] : Improved FourCC identification (using Stream Header instead of Stream Format)
VideoInspector : http://www.kcsoftwares.com/?vtb
KC Softwares
Old 10th September 2005, 16:06   #94  |  Link
Kyle_Katarn
VTB v1.7.0.88 [10/09/2005]
+ Aspect Ratio
@ New codec database (Video:484 Audio:223)
@ GUI
KC Softwares
Old 10th September 2005, 16:45   #95  |  Link
iradic
is it possible to read display h/w in Matroska?
is it possible to see 2 audio streams in your prog (dont have files to check sorry)?
if not will you implement it please ... thanks
iradic is offline   Reply With Quote
Old 10th September 2005, 16:48   #96  |  Link
Kyle_Katarn
Supports single stream only.
Multiple stream support planned to v2
KC Softwares
Old 14th September 2005, 08:54   #97  |  Link
masken
uhm... ?
A CLi-interface would be really nice and useful, so that you could programmatically export extracted data, like:
VideoInspector.exe "C:\myVideofile.avi" /silent /export:"C:\myVideofile.csv" /settings:"C:\VIexportsettings.ini"
You state that there's CLi-support, but where is it? Nothing when running VideoInspector.exe /? for example...
masken is offline   Reply With Quote
Old 14th September 2005, 12:34   #98  |  Link
Kyle_Katarn
Here it comes : http://www.kcsoftwares.com/forum/ind...?showtopic=111
KC Softwares
Old 15th September 2005, 15:50   #99  |  Link
masken
uhm... ?
hmm... I didn't get that one working. Ran:
videoinspector.exe c:\1\test.txt
The test.txt contains:
C:\3\1.avi
It didn't produce any output file.
v.1.7.0.88
Also, just as a side-note, accelerator indicators would be nice (Alt+C for Codecs, Alt+B for Browse etc) Also hitting Escape to close any sub/informational windows would also be very nice
Old 15th September 2005, 15:53   #100  |  Link
Kyle_Katarn
Are all paths ok ?
KC Softwares
