Go Back   Doom9's Forum > Capturing and Editing Video > DV
Old 15th August 2006, 17:22   #41  |  Link
henryho_hk
@WorBry, AviSynth does not know DV 4:2:0. It always takes it as MPEG2 4:2:0. Indeed, it does not know whether it is progressive or interlaced (which IMO is not equivalent to "field-based"). And I think AviSynth 2.56 will throw an error if you run ConvertToYV12(Interlaced=xxx) on an DV 4:2:0 source.
henryho_hk is offline   Reply With Quote
Old 15th August 2006, 20:37   #42  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
No it won't throw an error.
It simply doesn't know the difference between MPEG2 YV12 and DV YV12, because both are transferred to AVISynth using the YV12 FOURCC.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 15th August 2006, 21:00   #43  |  Link
WorBry
Actually, no it doesnt - I've just double-checked.
Cedocida set to 'forced YV12 (DV sampling)' output with
avisource("C:\DV Type II.avi")
ConvertToYV12(interlaced=true)
opens just fine in VdubMod. File Info gives 'DivX 6.2.5 YV12 Decoder' as the (stream) decompressor.
Edit: Sorry Scharfis, you got there before me.
WorBry is offline   Reply With Quote
Old 16th August 2006, 00:15   #44  |  Link
henryho_hk
Thanks for correcting me, scharfis_brain & WorBry.
Old 12th January 2007, 22:46   #45  |  Link
aabxx
This thread is confusing.
So did anyone come to any conclusions about what to use and what not to use?
aabxx is offline   Reply With Quote
Old 15th January 2007, 08:34   #46  |  Link
swiego
I'm wondering too.
I'm glad to have found this (I think), as I'd assumed that DV decoders wouldn't make a difference. Of course maybe that is the case after all... are the differences significant?
swiego is offline   Reply With Quote
Old 18th January 2007, 00:17   #47  |  Link
henryho_hk
See the screen caps here:
http://forum.doom9.org/showthread.ph...216#post733216
Old 19th January 2007, 17:27   #48  |  Link
aabxx
After studying this thread cedocida seems to be the best option.
To swiego:
The differences are significant. At least to a fairly experienced video encoder. For the casual observer they are probably only minor and in fact the added sharpness of some decoders only makes the stuff look better to them :P Chroma bugs can be noticeable on some material while on other they can be difficult to observe [under normal playback that is].
Old 27th January 2007, 10:01   #49  |  Link
lilhobo
Latest version:
0.1.7 (Nov 22, 2006)
Main tool site and mirror download site:
Main tool site - 150KB
Mirror download - 150KB
lilhobo is offline   Reply With Quote
Old 8th February 2007, 09:12   #50  |  Link
swiego
So, what decoder ships with Windows Vista? I installed Vista Ultimate and was able to play all my DV files out-of-the-box. I was wondering if this is one of the decoders described and tested in this thread, or something new. (I played the files with both windows home premium and windows ultimate.)
Just curious.
Old 14th February 2007, 18:07   #51  |  Link
vlada
I believe it is still the same:
5) MS DV codec (directshow codec) for W2K
vlada is offline   Reply With Quote
Old 14th February 2007, 23:05   #52  |  Link
Chipstra
Just curious.
Swiego:
try: http://www.raadsbesluit200.nl/test/m...dv-capture.rar
4 sec. 12mb
Chipstra is offline   Reply With Quote
Old 5th March 2007, 10:39   #53  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I've been trying Cedocida, but I've had to disable it because vdub can't playback in real time with it. Anyone else had this problem?
David
wonkey_monkey is offline   Reply With Quote
Old 5th March 2007, 21:55   #54  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
yes, it is slow
Old 6th March 2007, 01:23   #55  |  Link
wonkey_monkey
Thanks Fizick... someone in another thread said it was fast, hence my confusion
David
Old 27th October 2007, 23:42   #56  |  Link
FredThompson
FredThompson's Avatar
Originally Posted by henryho_hk View Post
These are missing. Would you please repost them?
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
