#3561 | Link |
MKVToolNix author
1. Sounds like a bug. I'll have to investigate.
2. No, because there's such functionality already: »start muxing«. »Add to job queue« will always add them with status »start manually« and »start muxing« will always add them with status »start automatically«. See this explanation of how the queue works. 3. I won't spend any time on the outdated and abandoned technology HD-DVD. Sorry. 4. Windows can handle both / and \ in paths just fine. Therefore I haven't bothered to adjust the code to make sure that the usual path separator is used everywhere. It's not just a compile time switch, it's code changes in every place a path is output for the user to see. As Windows has no problems with / in paths I won't spend any time on this any time soon either.
Latest MKVToolNix is v101.0 If I ever ask you to upload something, please use my file server. |
#3562 | Link |
MKVToolNix author
About the output directory setting: I can reproduce such behavior, but only if I edit the output name manually. If, however, I use the »browse« functionality next to it then the new location is remembered just as I expect it to be. I'll fix the handling of manual changes to the output file name.
#3563 | Link |
Can I save the image as the first frame of the container matroska? Is there a hidden function?
![]() Can I import and cut a timestamp for Sony XAVC NonRealTimeMeta? Code:
Media Info: Language "und (und)" - Type "meta:rtmd" - 240 samples
Unknown Metadata Stream
RFC6381 Codec Parameters: rtmd
All samples are sync
#3564 | Link |
MKVToolNix author
Uhm… What now? I'm sorry, but I completely fail to understand your questions.
#3565 | Link |
MKVToolNix author
No to the first question. As for the second question: if you could embed such data in Matroska I'm certain your Sony couldn't read them. No as well here.
#3566 | Link |
Thanks for your reply. All understandable. More and more is the Sony camcorder in the world so think that the theme is coming back for some time.
![]() https://www.youtube.com/watch?v=ZpWI-7DAC4s Last edited by Jamaika; 24th August 2015 at 12:47. |
#3567 | Link |
Hi Mosu, I'm either doing something wrong, or I discovered an issue in the mkvtoolnix GUI chapter editor. After loading a chapter file, selecting "Additional modifications -> Shift start and end timecodes by the following amount" on a chapter entry in the editor, does not seem to do anything.
For example, loading a txt file with this content in the chapter editor, and then trying to shift the first chapter by "-00:01:41.518" or "00:01:41.518" does nothing, the chapter start and end timestamps in the editor remain unchanged: Code:
CHAPTER01=00:00:00.000 CHAPTER01NAME=Chapter 01 CHAPTER02=00:01:41.518 CHAPTER02NAME=Chapter 02 CHAPTER03=00:08:50.905 CHAPTER03NAME=Chapter 03 CHAPTER04=00:11:49.291 CHAPTER04NAME=Chapter 04 CHAPTER05=00:20:46.203
#3568 | Link |
MKVToolNix author
All those modifications only work on the children of the selected node. Shifting only a single chapter entry is therefore not possible.
Having multi-selection enabled for chapters is not currently on my TODO list as it's quite a lot of work to get right. Sorry.
#3570 | Link |
MKVToolNix author
Huh… You're right, it doesn't work at the moment. That's obviously a bug. I'll fix it.
#3572 | Link |
MKVToolNix author
Should be fixed in pre-builds 884 & 885. I'd appreciate some testing.
Yes, it's supposed to work on the edition, too (well, it doesn't change the edition but its direct children, of course). And thanks for the report. I know exactly when this got broken: back in April even before release 7.9.0. Seems you're the first user to actually give this function a try
#3573 | Link |
Just tried build 885 on Windows, and it seems to work ok for me.
![]() As a suggestion, maybe it makes sense to change the description of the feature from "Shift start and end timecodes by the following amount" to "Shift start and end timecodes of child chapters by the following amount". It might help those that misunderstand the feature, like I did. |
#3574 | Link |
MKVToolNix author
The very first line in that dialog already states what the actions apply to. So no, I don't want to add the same verbiage to each of those options.
However, it shows that I remembered incorrectly: the shifting is indeed applied to the selected element, too, not just to its children.
#3575 | Link |
BUG in header editor with french tracks
There's a bug in the header editor in version 8.3 (probably the same happens when loading a file in the muxer):
A track (audio, subtitles, video) with language "fra" is not detected as French. When clicking on "save" in the header editor, all tracks with language "fra" are changed automatically to "und" undetermined. To avoid this, all tracks must be changed manually to "fre", otherwise the language information is lost after saving. This didn't happen with the old gui. FYI, all the french tracks written with Makemkv for my bluray backups have "fra" for French, so this is rather annoying. Thanks in advance for fixing this. |
#3576 | Link |
It's a feature of the old header editor to work around bugs like the one in makemkv. I suggest you also report the problem to them.
http://www.matroska.org/technical/sp...html#languages |
#3577 | Link |
MKVToolNix author
Thanks for reporting this. I'll implement a similar fix for the new header editor.
The correct code to use is indeed »fre« and not »fra«. Matroska uses the bibliographic ISO 639-2 codes (»fre«; also called ISO 639-2/B), not the terminology ones (»fra«). This goes back to when Matroska started; I think at that time the terminology ones weren't favored yet – or something like that.
#3578 | Link | |
fre and fra are both correct according to ISO-639-2. So, this is indeed a bug of the new gui and has nothing to do with makemkv. |
#3580 | Link | ||
According to wikipedia "In practice, ISO 639-2 has largely been superseded by ISO 639-3 (2007)", and 639-3 uses only "fra" and not both as ISO 639-2. This means, if only should be used it should be "fra", so this is a problem with the matroska spec that is not compliant with the standard used today. Fortunately this never was a problem since all the players are using both. So yes, mkvtoolnix also using both as you are proposing seems to be the best (or perhaps if you want to 100% stick to the mkv spec, you could automatically convert fra to fre instead of removing the tag as it is now). Thanks. |
