Old 4th January 2020, 13:07   #2561  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by kedautinh12 View Post
I see megui offer some .ts file use DGIndex but video encoded audio don't sync with video, same error with L-Smash...
Please don't cross posts.
Like the questions are related with MeGUI please read that thread:
https://forum.doom9.org/showthread.p...77#post1894677
(I leave the post here because the links are broken in the other thread)
Old 6th January 2020, 10:16   #2562  |  Link
LigH
I shot my foot with sugar
LigH's Avatar
DGMPGDec is just as "too old" as MPEG-2 video
New German Gleitz board
Old 14th January 2020, 07:49   #2563  |  Link
manolito
manolito's Avatar
Originally Posted by l33tmeatwad View Post
Compiled the last official stable release with FFMPEG 4.2.2 libs, figured a few people may be interested in having it so here it is:
Just tested this build using some HEVC sources, but it has a bad regression concerning HEVC seeking.
The build I use normally is from STvG from Nov 2019, and HEVC seeking works with this build. The meatwad build does not include the fix for seeking, it is unusable for HEVC sources.
Old 15th January 2020, 11:00   #2564  |  Link
lansing
Non utf-8 file path support with DGIndex after all these years seems to be a good reason to hop onto another train.
Old 15th January 2020, 16:30   #2565  |  Link
LigH
LigH's Avatar
If just any other "train" supported playlists like d2v indexing across a set of VOB segments ... but neither FFMS2 nor L-SMASH Works do. So you need to extract a PGC as continuous file (e.g. using PGCDemux or any DVD ripper with "PGC VOB" output or M2V video demux).
Old 16th January 2020, 04:28   #2566  |  Link
kedautinh12
that why i like source filters continued update
Old 16th January 2020, 18:32   #2567  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Does D2V Witch support non-utf8 file paths?
l33tmeatwad is offline   Reply With Quote
Old 16th January 2020, 18:39   #2568  |  Link
videoh
Useful n00b
There's no reason that can't be updated as per DGDecNV. I'll try to find time for it.
Old 26th January 2020, 04:00   #2569  |  Link
Matias
Is it possible to repair error like this?
https://i.imgur.com/F9Bn5JC.png
Matias is offline   Reply With Quote
Old 26th January 2020, 11:53   #2570  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Only by cutting away the bits with a different format.
I'll probably implement it in BestAudioSource some day.
Myrsloik is offline   Reply With Quote
Old 8th February 2020, 10:23   #2571  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Hey people! Is there any news about an official release for FFMS2?
I see 202 commits after the latest release in GitHub.
gpower2 is offline   Reply With Quote
Old 14th February 2020, 11:24   #2572  |  Link
Nico8583
Hi ! Same question than gpower2, is there a new version for FFMS2 ? Thank you !
Nico8583 is offline   Reply With Quote
Old 4th April 2020, 20:16   #2573  |  Link
gpower2
gpower2's Avatar
FFMS2 latest x64 build
Hey people, since no one seems to have the time for providing a new build for our beloved FFMS2 lib, I decided to make the best out of the COVID quarantine and try to have a go for it.
It was not easy, especially for someone who doesn't compile C/C++ open source cross platform projects often, like me. :P
But at last I managed to have a fully working (and quite a speedy one) x64 build!
ffms2-0628fe6-win64-20200404.7z
I only needed a x64 one, if I manage to find the time I'll provide with a x86 one, but this is one time expensive process, so don't get your hopes up.
Enjoy people!
Build details for the next one who tries to do that:
FFMpeg
branch master, commit: a6e56d12a413013d3a4b39f670e5495805965a67
April 3, 2020
Build tools:
  • MSYS2 x86_64 20190524
  • Latest MSYS2 packages (pacman -S make pkg-config diffutils nasm)
  • VS 2019 16.5.2 Community Edition
Build instructions:
  1. Download latest MSYS2 from http://msys2.github.io/
  2. Open Visual C++ command prompt with environment set for 64-bit MSVC compilation. In my case it is called "x64 Native Tools Command Prompt for VS 2019".
  3. Now open MSYS console from within the MSVC command prompt:
    C:\msys64\msys2_shell.cmd -use-full-path
    NOTE: You must specify "-use-full-path" in order for the MSYS2 console to know the PATH from the VS command prompt
  4. Use "pacman" in MSYS2 console to install the packages needed for building FFMpeg
  5. Configure FFmpeg - run following command in MSYS console:
    ./configure --arch=x86_64 --target-os=win64 --toolchain=msvc
  6. Build the binaries - run following command in MSYS console:
    make
  7. Install the binaries - run following command in MSYS console:
    make install
    NOTE: By default they should end up in C:\msys64\usr\local
ZLib
branch master, commit: cacf7f1d4e3d44d871b605da3b647f07d718623f
Jan 15, 2017 (zlib 1.2.11)
Build tools:
  • Build from contrib\vstudio\vc14\zlibvc.sln in VS 2019 16.5.2 Community Edition in Release x64 configuration
  • Used the contrib\vstudio\vc14\x64\ZlibStatRelease\zlibstat.lib
FFMS2
branch master, commit: 0628fe69f014c398d1c5d15d99934a88a4a65c3b
Mar 30, 2020
Build tools:
  • Build from build-msvc\ffms2.sln in VS 2019 16.5.2 Community Edition in Release x64 configuration
MSVC Project changes:
  • WindowsTargetPlatformVersion: 10.0.16299.0 => 10.0
  • PlatformToolset: v141 => v142
  • Added "../../zlib" in IncludePath
  • Added "../../zlib/contrib/vstudio/vc14/x64/ZlibStatRelease" in LibraryPath
  • Added "bcrypt.lib" in Linker AdditionalDependencies
  • Changed "zlib.lib" to "zlibstat.lib" in Linker AdditionalDependencies
  • Added "../../zlib/contrib/vstudio/vc14/x64/ZlibStatRelease;../../ffmpeg64/lib" in Linker AdditionalLibraryDirectories
Links that helped me fill the blanks:
http://ffmpeg.org/platform.html#Windows
https://ffmpeg.zeranoe.com/forum/vie...php?f=5&t=7497
Old 4th April 2020, 20:32   #2574  |  Link
tolias63
Oh, nice work! Thanks, Gpower2!
tolias63 is offline   Reply With Quote
Old 4th April 2020, 21:34   #2575  |  Link
filler56789
SuperVirus
filler56789's Avatar
and
filler56789 is offline   Reply With Quote
Old 5th April 2020, 04:01   #2576  |  Link
Stereodude
Is ffms2 supposed to be frame accurate when seeking?
Stereodude is offline   Reply With Quote
Old 5th April 2020, 07:31   #2577  |  Link
StvG
Another ffms2 update:
- ffms2@bda9eeb;
- ffmpeg n4.3@72be5d4661;
- zlib 1.2.11;
- dav1d 0.6.0.
StvG is offline   Reply With Quote
Old 5th April 2020, 10:20   #2578  |  Link
Myrsloik
Myrsloik's Avatar
Yes, except when it's not. It mostly depends on the container and a bit on the codec.
Old 5th April 2020, 15:37   #2579  |  Link
Or to put it another way,
No, except when it is.
Old 11th April 2020, 02:27   #2580  |  Link
kedautinh12
same error with StvG ver
video test: https://drive.google.com/file/d/1Gze...ew?usp=sharing
log:
-[Information] Versions
--[Information] MeGUI: 2913 x64
--[Information] MeGUI Debug Data: available
--[Information] Update Check: development update server
-[Information] Operating System: Windows 10 Pro 1909 x64 (10.0.18363.720)
-[Information] .NET Framework: 4.0 (4.0.0.0)
-[Information] .NET Framework: 4.8 (4.8.03752)
-[Information] Microsoft Visual C++ 2005 x64: 8.0.61000
-[Information] Microsoft Visual C++ 2005 x86: 8.0.61001
-[Information] Microsoft Visual C++ 2010 x64: 10.0.40219
-[Information] Microsoft Visual C++ 2010 x86: 10.0.40219
-[Information] Microsoft Visual C++ 2012 x64: 11.0.61030
-[Information] Microsoft Visual C++ 2012 x86: 11.0.61030
-[Information] Microsoft Visual C++ 2013 x64: 12.0.40664
-[Information] Microsoft Visual C++ 2013 x86: 12.0.40664
-[Information] Microsoft Visual C++ 2015-2019 x64: 14.24.28127
-[Information] Microsoft Visual C++ 2015-2019 x86: 14.24.28127
-[Information] Redistributables
-[Information] DPI: 100% (96/96)
-[Information] Resolution: 1366x768
-[Information] Primary Screen: True
-[Information] Monitor 1
--[Information] System Information
-[Information] Update detection
-[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
-[Information] Haali DSS2: 2.0.0.13 (01-01-2019)
-[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
-[Information] MediaInfo: 18.05.0.0 (08-05-2018)
-[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
-[Information] 7z: 9.20 (18-11-2010)
--[Information] Component Information
-[Information] Version: 1.0.2847.0
-[Information] Date: 06-05-2018
-[Information] Interface: 3
-[Information] AviSynth Wrapper
-[Information] AviSynth Status: ignored as portable build is forced
--[Information] [4/11/2020 8:02:09 AM] Cannot use update server http://megui.org/auto/. Reason: Update server is not available
--[Information] [4/11/2020 8:02:09 AM] Cannot use update server http://megui.tmebi.de/test/. Reason: Update server is not available
--[Information] [4/11/2020 8:02:09 AM] Using cached update config and server: http://megui.tmebi.de/test/
--[Information] [4/11/2020 8:02:09 AM] No package requires an update
-[Information] File Version: 3.5
-[Information] File Date: 02-04-2020
-[Information] File Name: AviSynth+ 3.5 (r3106, 3.5, x86_64)
-[Information] File Path: e:\megui-2913-64\avisynth.dll
-[Information] AviSynth Version: AviSynth+ 3.5 (r3106, 3.5, x86_64)
-[Information] AviSynth+: true
-[Information] AviSynth MT: true
-[Information] AviSynth Status: active
-[Information] AviSynth portable
--[Information] AviSynth Information
-[Information] FileIndexer
--[Information] [4/11/2020 8:02:25 AM] MediaInfo
---[Information] File: C:\Users\84945\Downloads\Video for test\Hikoutei - King Gnu.ts
-[Information] Format: MPEG-TS
-[Information] FileSize: 147849216
-[Information] PlayTime: 00:04:22.912
---[Information] General
-[Information] ID: 4352
-[Information] StreamOrder: 0-0
-[Information] CodecID: 27
-[Information] Format: AVC
-[Information] FormatInfo: Advanced Video Codec
-[Information] Width: 1440
-[Information] Height: 1080
-[Information] FrameCount: 7852
-[Information] FrameRate: 29.970
-[Information] Duration: 00:04:21.995
-[Information] ScanType: Interlaced
-[Information] Bits Depth: 8
-[Information] AspectRatio: 1.778
-[Information] AspectRatioString: 16:9
-[Information] PixelAspectRatio: 1.333
-[Information] Delay: 1079.911
---[Information] Video
-[Information] ID: 4353
-[Information] StreamOrder: 0-1
-[Information] CodecID: 15
-[Information] Format: AAC
-[Information] FormatVersion: Version 2
-[Information] FormatInfo: Advanced Audio Codec
-[Information] FormatProfile: LC
-[Information] Muxing Mode: ADTS
-[Information] SamplingRate: 48000
-[Information] SamplingRateString: 48.0 kHz
-[Information] Channels: 2
-[Information] ChannelsString: 2 channels
-[Information] ChannelPositionsString2: 2/0/0
-[Information] BitRateMode: VBR
-[Information] [4/11/2020 8:02:26 AM] The language information is not available for this track. The default MeGUI language has been selected.
---[Information] Audio
-[Information] Log for job1 (idx, Hikoutei - King Gnu.ts -> Hikoutei - King Gnu.ts.ffindex)
--[Information] [4/11/2020 8:02:28 AM] Started handling job
--[Information] [4/11/2020 8:02:28 AM] Preprocessing
--[Information] [4/11/2020 8:02:28 AM] Job command line: "E:\MeGUI-2913-64\tools\ffms\ffmsindex.exe" -t -1 -f "C:\Users\84945\Downloads\Video for test\Hikoutei - King Gnu.ts" "C:\Users\84945\Downloads\Video for test\Hikoutei - King Gnu.ts.ffindex"
--[Information] [4/11/2020 8:02:28 AM] Process started
--[Information] [4/11/2020 8:02:28 AM] Standard output stream
--[Information] [4/11/2020 8:02:28 AM] Standard error stream
---[Information] [4/11/2020 8:02:31 AM] Writing index... done.
--[Information] [4/11/2020 8:02:35 AM] MediaInfo
---[Information] File: C:\Users\84945\Downloads\Video for test\Hikoutei - King Gnu.ts.ffindex
-[Information] FileSize: 85117
--[Information] [4/11/2020 8:02:35 AM] Postprocessing
---[Information] [4/11/2020 8:02:40 AM] Deleting intermediate files
--[Information] [4/11/2020 8:02:40 AM] Job completed
-[Information] AVS Script Creator
--[Warning] [4/11/2020 8:02:40 AM] Could not read frame: FFVideoSource: Out of bounds frame requested
--[Warning] [4/11/2020 8:02:41 AM] Could not read frame: FFVideoSource: Out of bounds frame requested
