#2541 | Link |
MKVToolNix author
Cannot reproduce:
http://www.bunkus.org/misc/mmg-670-win81-chlo%C3%A9.png Edit: changed IMG tag to normal URL as the screenshot is rather large.
Latest MKVToolNix is v101.0 If I ever ask you to upload something, please use my file server. |
#2542 | Link |
Strange. I can consistently reproduce the working/non-working of mmg just by switching between the two new fresh windows users I created (one accentuated and one non-accentuated name being the only thing differing between them).
By the way, in version 6.7.0 it now gives this error screen on both 64 bit and 32bit portable versions, and the debug version that you posted two pages ago. I will use the same image link as the previous user that got this window: ![]() Here the contents of the mkvtoolnix-debug.log: Code:
2014-01-15 19:34:24 +0ms Current file & line: src/mmg/mmg.cpp:331 2014-01-15 19:34:24 +1ms Current file & line: src/mmg/mmg.cpp:333 2014-01-15 19:34:24 +2ms Current file & line: src/mmg/mmg.cpp:335 2014-01-15 19:34:24 +5ms Current file & line: src/mmg/mmg.cpp:205 2014-01-15 19:34:24 +12ms Current file & line: src/mmg/mmg.cpp:210 2014-01-15 19:34:24 +13ms Current file & line: src/mmg/mmg.cpp:217 2014-01-15 19:34:25 +1244ms Current file & line: src/mmg/mmg.cpp:337 |
#2543 | Link |
MKVToolNix author
Already fixed. Read https://trac.bunkus.org/wiki/Troubleshooting.
About the issue with mmg not starting: no idea what's wrong, and without being able to reproduce it I don't stand a chance of debugging it - not to mention fixing it.
#2544 | Link |
I tried the builds linked at that troubleshooting link and still get the same "***Caught unhandled unknown exception; terminating" error on both 32 and 64bit, portable and installer. There is no new debuging build that can see where it hangs on my computer, because I can reproduce here.
#2545 | Link |
MKVToolNix author
I somewhat doubt that you're really executing the correct mkvmerge.exe executable and not some older version. I cannot reproduce the exceptions with either of the four builds linked in the troubleshooting article on my Windows 8.1. With the release builds I was able to reproduce them quickly and deterministically.
Anyway. Things I cannot reproduce remain impossible to diagnose, so I'm sorry but I cannot help you at the moment.
#2547 | Link |
MKVToolNix author
Yes, that is normal. Attachments don't have to be stored at the very end of the file. Instead they can be stored anywhere within it. mkvmerge stored them after the track headers before the first cluster. mkvpropedit will only overwrite them with an EbmlVoid element if they're not located at the end.
#2549 | Link |
I've finally gotten around to archiving some TV recordings (1080i/25 AVC) from the past couple of months after being lax about it. However, every single MKV file that I've made so far has dodgy timestamps and thus doesn't play back correctly in many places (MadVR shows frame drops, EVR shows graph oddities). I've tried changing everything I can think of to find where the problem lies:
- Happens with both MadVR and EVR in MPC-HC - Happens with both MPC-HC and MediaPortal - Happens with LAV Filters 0.60.1 and 0.58.2 - Happens using DXVA2 Native and ffmpeg decoding - Happens using both MKVToolNix 6.0.0 and MKVToolNix 6.7.0 - Happens when muxing the original TS file as well as the cut TS file created by TS-Doctor The original TS files play back perfectly whether cut or not. Can anyone identify what the problem might be? I can't imagine the broadcast stream format has changed over the last couple of months since that'd probably break lots of hardware out there. Here's a sample: TS file | Dodgy MKV file
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
#2550 | Link |
@DragonQ: You might try VLC 2.1.2 or K-Lite Mega those two has worked great for me on problematic streams. For cutting of *.ts stream, Avidemux 2.6.7 works great for me as the MKV produced by it is fine, BUT I re-mux again using latest MKVTools, "just in case"..
#2551 | Link |
Thanks for the suggestions but VLC does not play the MKV files correctly either (same issue: timestamps incorrect in places). TS-Doctor is surely not the problem as the issue happens with uncut files too. In any case, AVIDemux insta-crashes when I install it on Windows 8.1 x64.
#2552 | Link | |
You can also process the files via commandline using latest ffmpeg or libav... |
#2553 | Link | |
EDIT: If I use the following command on the sample TS file: Code:
ffmpeg -i test.ts -c copy -map 0 test.mkv
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 18th January 2014 at 02:09. |
#2554 | Link |
@DragonQ: I usually just use Avidemux and snip the ends and then sometimes simply extract the main video and audio streams using ffmpeg, the reason is *.ts files can contain alot of "junk/filler" streams that just waste space. When all else fails I use VideoRedo TV Suite which has an excellent stream fixer and GOP slicer that I used in the old MPEG-1/2 days... but it is a commercial program and can fix many uncooperative files, including newer H.264/AAC/AC-3 files. You may give it a try, they have a trial version, but I recommend testing all new software in a virtual machine, as I use to always have to restore my system from an image backup when I start testing ALOT of trialware and some will screw everything up... I usually use/love ffmpeg as I can batch process a hundred files in a few hours without user intervention....
#2555 | Link | |
If you think it might be the muxing, you might try the mkv muxer by Haali. I prefer mmg, but when I run into weird streams I try another muxer to see if it's the software or the video. |
#2556 | Link |
My C drive has only 20gb free. I just installed mkvtoolnix 6.7.0 64bit and it now muxes to my system drive instead of the target drive.
How can I disable this? v6.6.0 didn't do that. Took my half an hour to fix my computer after it completely filled my drive. I don't see anything in Options. It stored the file in: C:\Program Files (x86)\MKVToolNix\j |
#2557 | Link |
MKVToolNix author
mkvmerge writes to where you tell it to write; in mmg you set this via the output file name. That output file name is suggested automatically by mmg based on the settings of the default output directory in the preferences.
I've just re-tested with 6.7.0 64bit and it writes exactly where I tell it to, be it a second hard drive, a USB flash drive or a connected network share.
#2558 | Link | |
Thanks for the tip, I just tried muxing it with Haali's MKV Muxer (dsmux.x64.exe) and the resulting MKV plays perfectly! It must be a bug with how MKVToolnix handles these TS files then. Can you look into this please Mosu using the sample I provided above?
#2559 | Link |
MKVToolNix author
Not in the next two or three weeks; I currently have other priorities, sorry.
#2560 | Link |
My bad. I tried to target the j:\ drive but missed the colon, so instead it targeted a subdirectory j in the program directory. The cascade of computer errors and the fact that I had just installed the new version led me to think it was a temporary location. Sorry.
