29th March 2005, 02:49 | #1 | Link |
Professional Code Monkey
New plugin for using freeframe filters in avisynth
This is a plugin that allows freeframe filters (mostly effects) to be used directly in avisynth. It comes with a simple gui made in delphi to help with the otherwise completely cryptic arguments the filters take.
You can get the filter with source from here and filters to try it with from the official freeframe page. Note that the latest version is a C plugin and also is an example of how to use delphi to write avisynth plugins.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 26th September 2017 at 15:09. Reason: Updated link |
29th March 2005, 08:46 | #2 | Link |
Nice one!! Thanks
I'm trying the MotionMatte plugin from this site right now and find it fast and usable (duron 900). The convertion to RGB24 or RGB32 is a drawback, but should not be a problem when used for mask creation only. Very nice thing with the direct display of the script-command at the bottom of the options window. After I get my current work done, I will play around with this thingy quite a bit! JD |
26th April 2005, 13:50 | #3 | Link |
How the GUI is activated.
If I pass "true" as argument the AVSEdit crash. Is the GUI working separately?? I tested all the free available freeframe plugins and a lot of them are nice. Some can be replicated with some work in AviSynth and some not. I think that extension of AviSynth capabilities worth more advertising. |
26th April 2005, 15:27 | #4 | Link | |
I moved freeframeconf.dll to somewhere in the path (eg. C:\WINDOWS\SYSTEM32\). Then GUI worked. |
26th April 2005, 21:20 | #5 | Link |
Apparently I forgot to test it without the gui dll present and I still have no idea how that string stuff works in c++. The new version can be gotten from here and it should fix the problems.
The original path issue remains because it's more than one file but I have no idea what to do about it.
21st May 2008, 14:53 | #7 | Link |
Thought this is a very old thread I would just like to mention that FreeFrame 1.5 is out.
DVD slideshow GUI(Freeware). |
21st May 2008, 16:48 | #8 | Link |
Does anyone still use it? is there a demand for freeframe 1.5 plugin support? Exactly what changed?
I don't think I ever clearly mentioned it but the last and most working version of my plugin was reduced to a sample which is a part of http://ivtc.org/new/avisynth_pascal_v5.rar
21st May 2008, 18:57 | #9 | Link |
Well, I'm using it in DVD slideshow GUI for loading freeframe-metaplugins for slideshow motion backgrounds. Never had a problem with it . Check out the videoplayer linked at my sig for videos.
I guess there aren't much use right now for the 1.5 version, however the new FreeFrame OpenGl abilities might be interesting for avisynth usage - what do you think?
9th October 2009, 22:01 | #10 | Link | |
This look very nice. Is it still work ? I downloaded http://ivtc.org/new/avisynth_pascal_v5.rar, but freeframe.dll isn't an avisynth plugin. Others .rar links in this topic are broken. Some freeframe filters interest me. Is it now freeframe 1.5 support ? Where can I find the plugin for previous freeframe version ? ( or better for 1.5 ) Thank you.
---- just a french , please forgive my english ---- |
10th October 2009, 07:52 | #11 | Link |
The freeframe.dll works correct here. Are you using it correctly?
Ex. Code:
colorbars() LoadPlugin("freeframe.dll") converttorgb24() Freeframe("PeteRadialBlur.dll",false) converttoyv12() Check out http://ffrend.sourceforge.net/ for making up new Freeframe plugins out of old ones found at http://freeframe.sourceforge.net/
12th October 2009, 00:22 | #12 | Link | |
16th October 2010, 07:45 | #13 | Link |
Now there is an openFrameworks addon for creating FFGL (FreeFrameGL 1.5) plugins. To easily convert openFrameworks apps to FFGL plugins look here: http://code.google.com/p/ofxffglplugin/
And slowly the number of FFGL plugins is growing:http://community.freeframe.org/plugindatabase So would it be possible to update the avs freeframe plugin to 1.5 without too much trouble? Btw. most of the above links are dead, but here's a link to the old Avisynth FreeFrame 1.0 plugin: http://avisynth.org/warpenterprises/...l_20050426.zip
DVD slideshow GUI(Freeware). Last edited by tin3tin; 16th October 2010 at 07:49. |
16th October 2010, 07:56 | #14 | Link |
The link has been updated to the last version in case anyone still cares. I have no intention of updating it as I don't care and don't have the time. If someone does rewrite it it would be nice if it was done as pure C++ plugin though...
6th September 2011, 07:21 | #15 | Link |
Just did a quick videotutorial on how to use the freeframe plugin to change posteffects/plugins in DVD slideshow GUI.
http://www.youtube.com/watch?v=fJzL7SeMxhg (There was a request on how to use it.) Your freeframe plugin is great! Thanks again.
12th February 2016, 13:51 | #16 | Link | ||
47.952fps@71.928Hz
AsciiArt2 arguments?
I just found this.
And been looking at this too: http://forum.doom9.org/showthread.ph...31#post1391431 Quote:
(click images to to view on Imgur then click again to view in full resolution) orig AA using example in tin3tin's script. (upscaling to 4K first) without upscaling to 4K first Script I used: Quote:
I supposed I could have played with the... size and spacing arguments? (5 and 6). I tried random values for the 4th argument and they gave random results. Th eonly thing I know is the range is 0.0-1.0 and no idea how it affects anything. The download zip on the vjam site (camart site cannot be found) doesn't give any docs on what the values would mean. I guess the best thing would be to download their GUI and give it a run to see if it has any Help or anything? I tried up to 3 decimal places from .001 to .999 (and 1.0) and all sorts and never found a distinct pattern how it decided when there's color or just the text. Found an article shared on facebook about "World's oldest (rule 6) being shared" where someone converted The Matrix with ACSII art all over. The process he did was custom patches of the aalib on Linux. Looking at the pictures and the process, I wanted to see if there's been anything done for avisynth or anyhing else. There's a custom patch that's been requested to be put in FFMPEG that does similar thing with aalib, but have not been able to find it implimented yet. I found this and the other thread so gave it a dry run on a picture then decided to dig through my bluray collection and found the perfect candidate. Anyone got any insight on the arguments for... the one right after true/false?
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
14th February 2016, 03:59 | #17 | Link | |
FreeFrame("AsciiArt2.dll", true, 0, 0, 0) |
18th January 2017, 04:05 | #19 | Link |
Looks interesting, going to try it out
And by the way, links are dead but google to the rescue:
http://www.avisynth.nl/users/warpent...l_20050426.zip http://ivtc.vapoursynth.com/avisynth..._pascal_v5.rar They worked as of 18 jan 2017 |
19th January 2017, 11:55 | #20 | Link |
First post updated. Ignore all other links.
