Old 13th October 2004, 03:36   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Kill Playback on Titles using PgcEdit
HTML guide hosted by r0lZ.
10/11/2004: PgcEdit v.0.3.5 used at this time.
10/12/2004: Additional disclaimer not documented with guide: If you have any of these present below in your Pre Commands after Kill Playback, the Title's cell(s) will still play.
  • LinkTopCell
  • LinkNextCell
  • LinkPrevCell
  • LinkCN
  • LinkPGN
  • LinkPTT
10/15/2004: Another disclaimer not documented with guide: If you have any of these present below in your Post Commands, you may experience endless playback (looping) on your Title after Kill Playback.
  • LinkTopPGC
  • LinkPGCN (Link to same PGC)
  • JumpVTS_TT
2COOL
Old 13th October 2004, 03:51   #2  |  Link
jeanl
jeanl's Avatar
2COOL, that's pretty neat!
Could you possibly remind me why it's a good idea to leave the postcommand there (even though, supposedly, playback will never occur)?
Jeanl
jeanl is offline   Reply With Quote
Old 13th October 2004, 05:02   #3  |  Link
jeanl
jeanl's Avatar
@2COOL
Never mind, I found your explanation:
http://forum.doom9.org/showthread.ph...0&pagenumber=5
Jeanl
Old 13th October 2004, 05:39   #4  |  Link
2COOL
2COOL's Avatar
There are more disclaimers to Kill Playback.
If you have any of these present in your Pre Commands after Kill Playback, the Title's cell(s) will still play.
  • LinkTopCell
    LinkNextCell
    LinkCN
    LinkPGN
    LinkPTT
2COOL
Old 13th October 2004, 05:51   #5  |  Link
jeanl
jeanl's Avatar
Yes, I realized that when I read your post!
What do you think we should do in such cases? replace the link by a goto?
Jeanl
Old 13th October 2004, 06:17   #6  |  Link
2COOL
2COOL's Avatar
That's what jsoto was thinking about in this thread.
2COOL
Old 13th October 2004, 06:19   #7  |  Link
jeanl
jeanl's Avatar
OK I see. I haven't seen a single case of that happening, but then again I haven't backed up that many DVDs...
Jeanl
Old 15th October 2004, 00:23   #8  |  Link
blutach
Country Member
blutach's Avatar
Killng Playback
Folks,
I am not convinced that Killing Playback (or as jsoto/2COOL say, changing post in pre commands) is wholly a good thing.
As jeannl has pointed out - in several of her posts - if playback is killed, the GP Registers may not be correct. This would be especially true if BREAKs are converted to GOTOs.
I have had this experience recently - I blanked a lotta rubbish from the VMGM domain using VOBBlanker. The menu came up OK but the DVD didn't play.
Tried again, without having pre commands turned into posts and it worked beautifully. Of course, the (now blank) VOBs played (for 1/2 second), but big deal.
I think this is the big feature of VOBBlanker - the ability to blank cells, without affecting either the disk's structure or GP registers. Maybe VOBBlanker should have it disabled by default.
Comments?
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 15th October 2004, 00:37   #9  |  Link
jsoto
Just a Member
Each DVD has its own tricks...
I agree there are some cases where the final DVD does not work (or does not work properly), but I'm still convinced the defaults in VobBlanker are the right ones (the most common).
jsoto
Web sites with my tools
http://download.videohelp.com/jsoto
http://jsoto.posunplugged.com/
jsoto is offline   Reply With Quote
Old 15th October 2004, 00:39   #10  |  Link
jeanl
jeanl's Avatar
@Blutach,
wait wait, I'm not sure I ever said that! I think I have said that if you skip playback on a PGC entirely (i.e. skipping precommands, postcommands, and cell commands, for example using a jump) then you might miss some register initializations.
However, what vobblanker and pgcedit do is different. They convert the postcommands into precommands, and change breaks to goto. The result is that in the absence of cell commands, the pgc does exactly what it did before: the same commands are executed in the same order. The difference is the PGC "exits" (goes where it normally would) before any video is played back. I think the whole idea is due to 2COOL, kudos to him, that's very clever .
Now, if there are cell commands, that's different because these won't be executed (because no playback -> no cell command). Also, if there are link commands in the precommands, playback might actually not be killed (but that's not what's happening in your case).
However, vobblanker is smart about cell commands and it gives you a choice to kill or not kill if there are cell commands. In your case, I would definitely check whether the PGC that you killed had cell commands. If not, this would mean that there's something broken with vobblanker's kill playback. Also, I would definitely try to do the same kill playback using pgcedit. If that works, then there's a problem in vobblanker.
2COOL, can you confirm that? If there are no postcommands, killed or not killed playback should leave GPRMS, SPRMS in exactly the same state, right?
Jean
P.S. I'm a he, jean is a male name where I come from
Old 15th October 2004, 00:44   #11  |  Link
jsoto
Just a Member
@Blutach
Please check and give me the conclusions.
jsoto
PS
I'm a he...
I was going to ask... We have not many girls here, I think.
Old 15th October 2004, 00:50   #12  |  Link
blutach
Country Member
blutach's Avatar
Cell commands
My apologies Jean - I didn't suspect a French name (I just saw California, ).
I will have to have a look at the burned disk and see if there are cell commands. But I guess that is the point - if no BREAK, then no cell commands can execute, possibly screwing up the GPRMs.
Les
Old 15th October 2004, 00:53   #13  |  Link
jeanl
jeanl's Avatar
or the entire navigation if it's a link...
Jeanl
Old 15th October 2004, 01:12   #14  |  Link
blutach
Country Member
blutach's Avatar
@jsoto and jeanl
I've looked at the cell commands in VMGM and each cell only has a LinkTail PGC, which simply links to the Post commands.
@jsoto - Are the Post Commands still present under VOBBlanker (a la PGCEdit?) If so, I'm not sure what went wrong.
Regards
Les
Old 15th October 2004, 01:16   #15  |  Link
jsoto
Just a Member
They should be there, but changed into precommands.
jsoto
Old 15th October 2004, 01:18   #16  |  Link
jeanl
jeanl's Avatar
@blutach,
You should definitely get to the bottom of that. You're the second user who's encountered a problem of this nature (I'm trying to find the post), and I'm pretty sure things should definitely be OK in the case you describe. I'm pretty sure vobblanker leaves the postcommand there anyway (but in any case that's only useful if there's a link in the precommands and playback isn't actually killed).
Here's what you could do:
- Check that indeed playback is broken, narrow that down to 1 PGC being killed and breaking the DVD.
- Then post back the precommand/postcommand/cellcommand from pgcedit in the original PGC and the killed PGC.
We should be able to figure out what went wrong!
I know it's a bit of work (including burning if playback only breaks on your standalone) but it's worth it .
Jeanl
Old 15th October 2004, 01:30   #17  |  Link
blutach
Country Member
blutach's Avatar
@jsoto
The Posts changing into Pre commands is one thing, but if, for some reason, the cell plays and there are no post commands left, then problems may occur.
In PGCEdit, r0lZ essentially COPIES the post commands to the pre command section leaving the post commands untouched (He also converts BREAKs to GOTOs). That is, the post commands are still there as post commands (even though they may never be executed) after the PGCEdit Kill Playback routine. I have never had a problem with this idea.
But as 2COOL and others have pointed out, the cell may still execute and if there are no post commands to execute, then we may have an error situation.
I will look at the disk again and report back.
Regards
Les
Old 15th October 2004, 01:34   #18  |  Link
blutach
Country Member
blutach's Avatar
I do suspect we ought to transfer this discussion to the VOBBlanker thread
Les
Old 15th October 2004, 01:44   #19  |  Link
blutach
Country Member
blutach's Avatar
@jeanl
(Tongue in cheek)
If we had a nice trace function in PGCEdit, it would be very easy to track down
@r0lZ
I know you're working on this, so, please don't take offence. I just mention it because I know Jean has wanted this for some time
Les
Old 15th October 2004, 02:32   #20  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
It's coming... Some more patience, please...
BTW, you may not kill playback on a menu with buttons. Have you checked that?
r0lZ
