Old 26th July 2004, 00:15   #1  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
BlendBob 1.2: smartbobbed-field matching and de-rainbowing filter
Okay, some here may actually remember my BlendBob script that I've posted a bit about here - even though not a single person posted in that thread; was everybody totally stunned by it's greatness?
Well, to make a long story short: I've made a new and improved version of it, but this time as an AviSynth plugin (currently at version 1.2).
It does approximately the same job that Telecide has, but instead of trying to directly match fields and then deinterlace what slipped through it does it the other way around by using a smart bobber (well, I've only tested it with KernelDeint, but you could probably use anything a bit smarter than Bob()) to produce a frame from each field and then blends every other frame with the neighbouring frame that closer matches it (and which also brings the framerate back to what it started at); if the smart bobber did it's job right then no combs should be able to slip through (except for a special case I'll explain further down...).
It's advantage over Telecide is that you really needn't worry about finding a threshold for comb elimination; the smart bobber takes care of that. The blending of 2 smart bobbed frames means you'll get full resolution in still areas and damn close to full resolution in moving areas.
The derainbowing code I've added takes the chroma from the 2 frames it's chosen for blending, subtracts them and builds a mask of all pixels where the chroma difference exceeds a threshold. This mask is then used to replace the rainbowed chroma in the blended frame with a blurred version that has less to no rainbows.
Of course, you'll still need to use Decimate() on the result (unless I start working on my own plugin for that... ).
Here's the readme that comes with it:
BlendBob 1.2 by Kurt Bernhard Pruenner
This filter takes a bobbed video stream and halves it's framerate by blending
every other frame with the adjacent frame that matches it best.
Additionally, it tries to fix badly telecined frames, and offers derainbowing
options for 24 and 30FPS material.
Parameters
c ............... Clip to blend
show ............ If true show the following framematching metrics:
                  * The first line shows the current frame number and the
                    action that is used for this frame
                  * The next line shows the following metrics:
                    - Difference between previous & current frame
                    - Difference between current & next frame
                    - Difference between previous & next frame
                    - The difference used for determining the action
                    - The average used metric for the last 7 frames
                    - The frame's brightness (used to normalize differences)
                  * The last line shows two metrics that measure the similarity
                    of the current resulting frame and the previous and next one.
                    If a badly telecined frame is found that has a small enough
                    difference to one of these neighbours it is replaced with
                    it, otherwise a blend of the previous and next source frame
                    is passed through, which has somewhat less vertical
                    resolution  depending on the bobber that was used.
                  (default false)
pnThresh ........ Threshold for bad telecine detection; the smaller one of the
                  prev/curr and curr/next differences minus the averaged used
                  values must be pnThresh times larger than the prev/next
                  difference for the frame to be detected as badly telecined.
                  Set to 0.0 or very high to turn this off.
                  (default 2.5)
diffBias ........ Weight bias for difference weights:
                    0.0 gives a sine curve from -pi to pi
                    0.0 to -1.0 moves the end value towards 0
                    0.0 to 1.0 moves the start value towards 0
                  Set this to below zero if your source is noisy.
                  (default 0.0)
diffScale ....... The weights calculated using diffBias are values between 0.0 and
                  1.0, which are then multiplied by this value - adjust this if your
                  setting for diffBias produces too small results
                  (default 16.0)
forceMatch ...... Force a match in case you want to derainbow progressive material
                    0 - automatic matching
                    1 - force curr/next matches
                    2 - force prev/curr matches
                  (default 0)
derainbow ....... 0 - Turn rainbow elimination off
                  1 - Turn rainbow elimination on
                  2 - Mark rainbows red
                  3 - Replace luma with gray and only show rainbows in chroma
                  4 - Show rainbow mask
                  NOTE: derainbowing will only work on 24 or 30FPS material where
                  the rainbows change with every new field.
                  (default 0)
rainbowThresh ... Color difference threshold for detecting rainbows, higher
                  values detect less rainbows
                  (default 32)
rainbowRadius ... Blur radius in pixels (1-8) that is used for nuking rainbows
                  (a (2*r-1)^2 pixel area with the current pixel in the center is
                  being averaged, so 1 really doesn't do anything)
                  (default 4)
badFrames ....... 0 - Replace bad frames
                  1 - Pass bad frames through
                  2 - Pass bad frames through with their frame number in the top
                      right corner, skip up to 100 good frames per requested frame
                  (default 0)
dupeThresh ...... Threshold for duplicate detection; if a bad frame is detected and
                  the dupe difference of either the next or previous frame is lower
                  than this vale then the bad frame is replaced with it.
                  (default 500)
dupeBias ........ Weight bias for duplicate detection difference weights
                  (default 0.0)
dupeScale ....... The weights calculated using dupeBias are values between 0.0 and
                  setting for dupeBias produces too small results
                  (default 16.0)
coring .......... Set to true if input luma range is TV range (16-235); used for
                  frame brightness calculation
                  (default true)
forceCPU ........ Force the filter to only use specific optimizations
                    0 ... autodetect
                    1 ... C++ code only
                    2 ... Use MMX code where available
                    3 ... Use MMX & Integer SSE code where available
                    4 ... Use MMX & SSE code where available
                    5 ... Use MMX & SSE & SSE2 code where available
                  (default 0)
Version history
25.07.2004   Version 1.0
             * First Release - still missing de-rainbowing
28.07.2004   Version 1.1
             * First implementation of de-rainbowing using spatial nuking
               (pure C only, though)
28.07.2004   Version 1.1a
             * D'oh - SSE frameblending code was disabled
31.07.2004   Version 1.2
             * Main part of de-rainbowing now also implemented with MMX
             * Fixed memory allocation bug where I used rainbowThresh instead of
               rainbowRadius; this could crash if rainbowThresh wasn't at least
               2 times as big as rainbowRadius - and it wasted memory as well
The script used for the following examples is:
MPEG2Source("test.d2v",cpu=4,moderate_h=30,moderate_v=60,iPP=true,idct=6)
KernelBob(1,8,false)
BlendBob(show=true,badFrames=0)
and it ran at ~35 FPS on my 2.4GHz P4. (And yes, I've lifted the text output functions from Decomb, but everything else is written from scratch; I hope Don doesn't mind it... )
Example 1:
Bad frame passed through (badFrames=1):
vs.
Bad frame fixed (badFrames=0):
Example 2:
vs.
(notice that this time the frame wasn't replaced with one of it's neighbours as the background is moving slowly in this scene; if it had been replaced there would have been a stutter in the video)
To better illustrate the problem, here's the original frames around the first example:
(as you can see, the second and third frame are identical and can't be matched, but using a neighbouring frame instead works nicely)
Download BlendBob 1.2 (including the source)
np: A Grape Dope - Am Nasty (Immediate Action comp.)
Leak is offline   Reply With Quote
Old 26th July 2004, 05:29   #2  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
Glad to see that script is being made into a plugin. I didn't post into the other thread because I didn't have any problems with it when I used it.
I'll gladly run some tests once I have an empty job queue again. Is there anything in particular you want testers to look for, or are concerned with?
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 26th July 2004, 11:11   #3  |  Link
Leak
Leak's Avatar
Well, first and foremost I'd like to know if it works on all kinds of CPUs, seeing as I only have a P4 here. I was keeping a close eye on a list of which MMX/SSE instructions are supported by which CPU, but without older CPUs I can't really test that.
And I'd of course like to know if there are bugs in it, or if people find it useful, or if they have ideas for enhancements... the usual things...
np: Bigg Jus - NYC Color Designer (Black Mamba Serums v2.0)
Old 26th July 2004, 12:12   #4  |  Link
kassandro
Sorry, but you simply can't call this field matching. On the other hand, BlendBob is a good name, because you blend with the best neighbour. Nevertheless motion is blurred. A field matcher, like trbarry's Uncomb or Donald Graft's Telecide (without postprocessing) never touches the fields, they only may move to an adjacent frame. While your Blendbob certainly produces better output, if the above field matchers cannot find a good match, the output is clearly inferior, if they can, but the same effect can be obtained if you simply deinterlace. Essentially you are converting a sharp deinterlacer (the bob input) into a blur deinterlacer. Your Blendbob is more a deinterlacer with good compression ratio rather than a field matcher.
kassandro is offline   Reply With Quote
Old 26th July 2004, 12:56   #5  |  Link
Leak
Leak's Avatar
Okay then, how about "smartbobbed-field matching" then?
Actually, I've not tested it on real video material - it's really ment for telecined material that was 24 FPS (probably mixed with 30 FPS material, as you get it a lot in anime these days) to begin with; and in that case no motion is blurred, as the match with the smaller difference must be the other half of the source frame, or there was so little or no motion going on that a false match doesn't matter.
Of course you'll get motion blending on full framerate material (i.e. sport broadcasts), but on movies or TV series or anime you shouldn't get blurred motion.
Well, I rather meant you can use BlendBob with a smart bob when you'd use a field matcher otherwise. Using a perfect smart bob, you'd always get 2 identical frames on 24 or 30FPs material, which, when blended, would also result in the same frame as final output. But of course, no such smart bob exists, but the ones we have now do come quite close IMHO.
Uh - could you rephrase that sentence please? I'm not sure what you really wanted to say...
If you meant to say that the output is inferior to when a field matcher can find a match - yes, it's a bit smoother, but not as much as if you'd simply deinterlace everything.
I'm not quite sure what the compression ratio has to do with this, other than a slightly smoothed picture compresses a bit better.
To be honest, I'm not looking for the sharpest picture possible (but I do think the output of my filter still looks quite sharp), but for the smoothest motion possible without the jaggies you get when suddenly a deinterlacer kicks in with Decomb and without the possibility of there being stray combs because there's this one scene that needs a lower vThresh in Telecide... (this is not against Decomb, as it does what it does great, but I like to be able to do things in more ways than one... )
np: Alter Ego - Satanic Circus (Transphormer)
Old 26th July 2004, 13:48   #6  |  Link
kassandro
Ok, I see, I was wrong about blurred motion. If the input was in some way progressive, motion stays sharp, but interlaced motion is blurred. Thus there is no temporal blurring, but certainly some spatial blurring, simply because you average a frame derived from the top field with a frame derived from a bottom field (if the input filter is smart, then this happens only in the presence of motion). Nevertheless your filter is a deinterlacer in nature, which handles scene switches extremely well, and treats messed up progressive clips better than a normal deinterlacer, but worse than a real field matcher.
[/B][/QUOTE]
Well, I more meant you can use BlendBob where you'd use a field matcher otherwise. Using a perfect smart bob, you'd always get 2 identical frames on 24 or 30FPs material, which, when blended, also result in the same frame as output. But of course, no such smart bob exists, but the ones we have now do come quite close IMHO.
I think your BlendBob is a good alternative to a "normal" deinterlacer, whenever true field matcher yield unsatisfactory results and it is ideal for mixed material.
Uh - could you rephrase that sentence please? Something seems to be missing in there...
I have just done that - hopefully.
I'm not quite sure what the compression ratio has to do with this.
If you use kerneldeint, which is one of the worst deinterlacers as far as compression is concerned, you will certainly get a significantly better compression ratio.
Old 26th July 2004, 14:14   #7  |  Link
You Know
hi i have just finish similat plugin based on dup thresold :P and now i seen this thread.... DOH
i have got confusion where is Kernelbob function?? in blendbob script? or in dll??
to work i have past into my script kernelbob function from blendbob.avsi and loaded dll is corrent?
You Know is offline   Reply With Quote
Old 26th July 2004, 16:01   #8  |  Link
Leak
Leak's Avatar
Whoops... sorry 'bout that.
Yeah, you can either cut the function out of my BlendBob script and put it in a KernelBob.avsi file in your plugin dir or you can just paste it into your script.
np: Bigg Jus - Dedication 2 Pray (Black Mamba Serums v1.0)
Old 26th July 2004, 17:59   #9  |  Link
You Know
more plugins there are better is!
Old 27th July 2004, 11:42   #10  |  Link
niamh
Dismembered
niamh's Avatar
Ok, I've tried your filter on a telecined PAL series I have last night. I know, hardly challenging, PAL field shifts are pretty straighforward, but that's all I have, and if it can't do the basics, what else can it do hey?
Result: You've sold it to me Excellent results. No shimmering, or anything untowards(I have former episodes to check against).Considering the crappy state of the source(obviously remastered VHS to a DVD),I'm pretty happy to have it look as good as it can, even slightly nicer to me(in this case) than telecide(guide=2) !
THX leak.... now if I get my hands on a hybrid, I will be sure to give it a go, and please keep working on it
I have a question about this:
It returned an invalid argument error and nothing in your script mentions a third parameter...is it a typo?
I got it running as kernelbob(1,8)
niamh is offline   Reply With Quote
Old 27th July 2004, 12:14   #11  |  Link
Leak
Leak's Avatar
Well, that's the KernelBob function that's in my BlendBob.avsi script; the third parameter is the "sharp" parameter of KernelDeint; here it is for reference:
# Kernel Bob - uses KernelDeint to bob-deinterlace video
# (maybe not the newest version, but it gets the job done)
# c ...................... clip to bob
# topFieldFirst .......... 0 for bottom field first, 1 for top field first
# kernelDeintThreshold ... threshold used for KernelDeint, 8 works for me
# sharp .................. use sharpening, higher resolution kernel
# Needs KernelDeint(), tested with version 1.4.0
Function KernelBob(clip c, int "topFieldFirst", int "kernelDeintThreshold", bool "sharp")
  Assert(Defined(topFieldFirst),"topFieldFirst must be specified!")
  kernelDeintThreshold=Default(kernelDeintThreshold,3)
  sharp=Default(sharp,false)
  a=((topFieldFirst == 1) ? c.AssumeTFF() : c.AssumeBFF())
  b=separatefields(a).trim(1,0).weave()
  a=a.kerneldeint(order=topFieldFirst, \
                  sharp=false, \
                  threshold=kernelDeintThreshold)
  b=b.kerneldeint(order=(1-topFieldFirst), \
                  sharp=false, \
  return interleave(a,b)
And yes, I'll keep working on it considering I'm using it myself...
Next stop will be implementing the de-rainbowing I have in my BlendBob script (so I'll finally be able to get a good encode out of my Armitage III RC2 DVD).
Then I'll probably have a look if it makes sense to add a second mode that'll match the unbobbed fields using data gained from the bobbed ones, which would get this plugin quite a bit closer to being an actual fieldmatcher... In this case, integrating KernelBob into the filter might be a good idea so you can directly feed it your source, without the need of bobbing it first (although leaving an option to use any bobber might be a good idea).
Also, looking at KernelDeint's source I see it's all C++, so I guess converting the main loop to assembler using MMX or rather floating point SSE/SSE2 might speed it up a great deal (not that it's slow to begin with... ).
np: Alter Ego - Rocker (Transphormer)
Old 27th July 2004, 12:27   #12  |  Link
niamh
Dismembered
niamh's Avatar
Thx for the clarification, though I was on my way to edit my post to say I'd figured it out
2 good ideas indeed
btw i have a P4 too, so I can prove nothing .
I forgot to say that it's what I wanted on this particular source, slightly smoother...it's still definitely more precise than a deinterlacer.
Does it make any sense at all to give it a try?
and will there be an option to use the de-rainbower on its own as well?
Old 27th July 2004, 13:14   #13  |  Link
Leak
Leak's Avatar
*g*
60i video: Does it make any sense at all to give it a try?
Well, my filter works on the assumption that every frame has a neighbouring frame that's very, very similar (which is the case for bobbed 24 or 30 FPS material, and probably also for slow-moving 60 FPS stuff), which you won't have with faster movements. Just using a deinterlacer followed by SelectEven() will probably yield better results in that case.
I'm planning to add a parameter to set the field matching to a fixed direction (which is what you really want on non-telecined stuff), but if it's telecined you'll need to match frames, as the derainbowing assumes that the only difference between 2 neighbouring frames are the rainbows.
I just have the nagging feeling that a bad edit in the video can screw that up, so probably changing the matching direction if enough frames seem to be wrong might be a good idea. (If you're suddenly matching the wrong frames, all movement in the chroma will be detected as rainbows, which won't be pretty...)
Of course, you'll still need to bob your material then, but if the fieldmatching part I've talked about above works out the derainbowing should also work on the raw input.
np: Bigg Jus - Athena (Black Mamba Serums v1.0)
Old 27th July 2004, 21:49   #14  |  Link
dbzgundam
Hates all his encodes
dbzgundam's Avatar
I have to say Leak, I've tested it on Hybrid material.... And while it does blur a tad bit, it definitely conquers stray frames/poorly telecined frames in a manner that any other deinterlacer I used could not. Great filter!
http://thevideophile.blogspot.com/ Watch and be amazed by my frustration over the video world!
dbzgundam is offline   Reply With Quote
Old 28th July 2004, 07:12   #15  |  Link
acrespo
Brazilian Anime Ripper
This filter is a very good surprise for me. I try in two different anime series (Yu-Gi-Oh and Captain Tsubasa) both I have better IVTC/deinterlace results than Telecide, TomsMoComp and KernelDeint.
Tanks for this great filter.
Capture cards:
Compro VideoMate Gold+ (Philips SAA7134 based) (not active)
Hauppauge PVR 150MCE (not active)
ATI TV Wonder Elite (active)
acrespo is offline   Reply With Quote
Old 28th July 2004, 12:50   #16  |  Link
kingmob
Wouldn't it be better if you check for similarity between bobbed frames and then weave the fields, thus retaining the fps? So in moving scenes you simply bob, but in still scenes you get some sort of enhanced bob, just like you have now, but you also retain fluidity of motion.
That was at least what I was thinking about a few days ago. Gotta do something when you can't sleep .
kingmob is offline   Reply With Quote
Old 28th July 2004, 16:02   #17  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
yes - a parameter like "blend=false" or something of the kind would be good. even a "mode=1" style param would be useful for choosing whether to weave, blend or use a combination with some kind of thresholding.
hmmm... have you considered having a look at scharfi's intellibob? there's something that could use it's own plugin, even if it is a simplified version that could be built on in scripts, like a generic per-pixel field matcher plugin that could be called from script functions.
Old 28th July 2004, 17:11   #18  |  Link
Leak
Leak's Avatar
Yes, that's already on my to-do list...
Sorry, I only do one filter at a time, and I'll be back at work next week...
Also, before I do anything like that I'll probably take a shot at optimizing KernelDeint; currently it's pure C++ code which could use some floating point SSE code - dunno if an Integer MMX version is practicable.
np: El-P - Truancy (Fantastic Damage)
Old 28th July 2004, 17:11   #19  |  Link
Leak
Leak's Avatar
Ummm... I already retain the original frame rate - the bobbing doubles it and the blending cuts it in half again. The fluidity of motion should stay the same in the process; if I didn't blend the bobbed frames there'd be quite a few jaggies that KernelDeint still introduces...
If you mean to apply my filter on 60 FPS interlaced material it'll probably work quite poorly, it's mainly meant for telecined material.
But yes, I've thought about using the bobbed frames for calculating the metrics and then weaving the original fields instead of blending the bobbed frame; it's just that I'm currently working on the derainbowing part I myself could use very much...
np: Radiohead - The National Anthem (Kid A)
Old 28th July 2004, 17:26   #20  |  Link
Leak
Leak's Avatar
Version 1.1 released
Okay, so you've probably already noticed that I've updated the first post...
Version 1.1 adds de-rainbowing (look in the readme or the first post for info on how to use it), but currently it's implemented in C++ only so you'll get a noticeable speed drop for using it (my test script went from 28 FPS to 17 FPS using a blur radius of 6, so I think that it's not too bad - after all, it took most of the rainbowing down with it... ). Adding MMX and SSE versions of the performance critical functions is up next.
Also, I've fixed a bug in the MMX frame blender that was not really blending well - since nobody noticed it I guess everybody is using SSE capable CPUs nowadays...
np: Gold Chains - Young Miss America (Young Miss America)
