Old 7th April 2004, 20:15   #1  |  Link
The X
The X's Avatar
GUIDE : *.DTS to *.WAV (DTS/WAV)
Finally I WIN !!!
I Convert my dts file (vts_01_1.dts) into a 6ch dts/wav file (vts_01_1.wav); then i write it as Audio-Cd, put in my dvd-player & i hear a 5.1 DTS SOUND !!!
Here the step by step guide 4 all people that as me want to do it
BEFORE ALL DOWNLOAD the follow softwares/codecs
1) WinDVD Platinum v5.1 5.26
2) dtsac3source.ax (dtsac3source_20030603.zip) (From http://sourceforge.net/projects/guliverkli/)
3) BeSweet v1.4 (Besweet.exe) (From http://dspguru.doom9.net/)
4) BeSweet GUI v0.6 (From http://dspguru.doom9.net/)
5) BeSweet v1.5b23 (BeSweet.dll) (From http://dspguru.doom9.net/)
6) azidts 0.1 (http://www.doom9.org/Soft21/Audio/azidts.zip)
7) Minnetonka SurCode CD Pro DTS
8) SSRC (From http://www.afterdawn.com/software/au...tools/ssrc.cfm)
THEN :
1) Install WinDVD
2) Copy dtsac3source.ax into c:\windows\system32 dir
3) RUN regsvr32 dtsac3source.ax
4) Extract BeSweet 1.4 & copy inside the dir the BeSweet GUI, the BeSweet DLL, the azidts EXE, the ssrc.exe
5) Install SurCode CD Pro DTS
NOW the Convertion :
1) Open BeSweet GUI
2) Load as INPUT the *.dts file
3) Select as OUTPUT "Six waves"
4) Click on "Downconvert Sample Rate"
4) Click on AC3/OGG/DTS & select the dir of azidts.exe & SurCode CD
5) Click on BeSweet
6) Click on "DTS to WAV"
7)In the upcoming IVIAudio.ax dialogue (see above) select "6 speakers mode (5.1 channel)" (not SPDIF!)
When you Press OK a Dos window as this it appears :
NOW you've 6 mono wav files at 44Khz
8) Open SurCode CD Pro DTS
9) Load the 6 mono wav e select the Destination THEN press "ENCODE"
NOW you've a Dts Wav file
10) BURN the file as Audio-CD and you WIN ^_^
I hope that this post is a good things...
The X is offline   Reply With Quote
Old 8th April 2004, 10:08   #2  |  Link
The X
The X's Avatar
UP, I add 1 step ^_^
Old 22nd April 2004, 22:35   #3  |  Link
Eye of Horus
Banned
Eye of Horus's Avatar
How about http://www.app.demon.nl/guides.htm ??
(handle DTS......)
You invented the wheel again
grtz,
EoH
Eye of Horus is offline   Reply With Quote
Old 23rd April 2004, 00:16   #4  |  Link
The X
The X's Avatar
(handle DTS......)
grtz,
EoH
First all I never found this guide; i write this "guide" cause i founded full info in internet...
However, I never said to invented the METOD
If u want i can delete the post ^_^
Old 23rd April 2004, 11:37   #5  |  Link
Eye of Horus
Banned
It's not meant as criticism, only to show you this was already known for more than a year. For me there is no need to delete the message !
The more people who can benefit from the method the better !
There is one clear advantage on what you describe her : in my guide it only works with DVD platinum 4.5. You managed to use a newer version !!
kind regards,
EoH
Old 23rd April 2004, 14:07   #6  |  Link
The X
The X's Avatar
kind regards,
EoH
Good ^_^
If I had found your guide time ago I would have spared a lot of job of search...
:P
Old 24th April 2004, 16:57   #7  |  Link
bflora1952
I Need Heip
I have tried this with a trial version of WinDvd and I am using BesweetGui. When I start the conversion process I just get a flash of a screen that says something about Intervideo but it is not displayed long enough to read it. The process then proceeds but the ouput file is only silence. I don't have the option of choosing 6 channel output. Does the trial version of WinDvd not work with this procedure? Any suggestions would be greatly appreciated.
bflora1952 is offline   Reply With Quote
Old 24th April 2004, 19:15   #8  |  Link
The X
The X's Avatar
Re: I Need Heip
Try with alternative WinDVD Audio Decoder : IViAudio 5.3.5.20
When u press the "DTS to WAV" button u MUST see this windows
Old 24th April 2004, 22:39   #9  |  Link
bflora1952
Still the same result
Thanks X, but I am still getting the Intervideo screen appearring for an instant and vanishing as the black Dos display begins. I have 2 computers and this result is the same on both. The page that flashes momentarily appears to be the correct one, but I have no chance to choose anything before it disappears. The output files are silent or sometimes says "file damaged".
Old 25th April 2004, 04:09   #10  |  Link
bflora1952
Just another thought. Could my problem have anything to do with Windows XP? Is anybody using XP along with BesweetGui and having success?
Old 25th April 2004, 11:09   #11  |  Link
Eye of Horus
Banned
No problem with using XP here.
And the method doesn't work with the demo of WinDVD.
You need the full registered version !!!!
grtz,
EoH
Old 25th April 2004, 15:13   #12  |  Link
bflora1952
Does that registered version require the audio booster pack? What about the alternate audio codec from The X? Anybody use this with XP? Has anybody else experienced the problem I'm having?
Old 25th April 2004, 15:35   #13  |  Link
Eye of Horus
Banned
I always use PowerDVd on my PC.
When I had to re-install WinDVD (as mentioned my guide works with 4.5 Platinum only) I saw there are 2 versions of 4.5 . One of them is for XP only !! I don't know if that's still the case with newer versions.......
You don't need the booster pack !
If this method described here does not work, try my guide.
With WinDVD Platinum 4.5 XP (!) it definitely works !
grtz,
EoH
Old 25th April 2004, 15:51   #14  |  Link
The X
The X's Avatar
I create & test my guide with Windows XP Professional SP1 & Full Registred versione of WinDVD...
Old 25th April 2004, 17:35   #15  |  Link
bflora1952
Does your fully registered version include the audio booster pack? I am hesitant to buy WinDvd 5 if that is not the cause of my problem. On my 2 computers I have XP home on one and XP Pro SP1 on the other and they both have the same problem. The WinDvd is probably the cause, but I would feel much more confident if someone else experienced the same effects. When I create an mp3 file DTS-> MP3, the resulting file "plays" but is silence. If I create 6 waves, the files produce the message "file damaged" when I try to play with Winamp. If I create an AC3 file, the file shows a size of 0kb. Thanks for responding to my situation.
Old 25th April 2004, 18:37   #16  |  Link
The X
The X's Avatar
I dunno
The only think that i can say u is "Try to DL the full version in internet; test it & if ALL r working THEN buy it"
Old 26th April 2004, 14:11   #17  |  Link
bflora1952
I have installed a registered version of Windvd 5 and I am still getting the "flash and go" of the Intervideo screen. However the process is now outputting the 6 mono waves from a dts file. I used a music dvd that had ac3 and dts surround to compare the 6 waves outputted. With the dts input, the 6 waves output are labelled wrong as compared to the ac3 input. When I get home from work today, I will post the corrected labels.
Old 27th April 2004, 00:12   #18  |  Link
bflora1952
6 wave dts output labels.
When using azidts to convert dts to 6 waves the waves are mislabeled. Here are the labels as output -> and what they should be. SL->LFE; FR->C; FL->FL; C->FR; LFE->SR; SR->SL. I hope this helps.
Old 27th April 2004, 10:26   #19  |  Link
The X
The X's Avatar
Re: 6 wave dts output labels.
Uhmm... i really dunno what's ur problem...
Check the config of Besweet & control if u r set all right :
Then re-follow step by step my guide & check if u r using the same version of my sw
Old 27th April 2004, 11:06   #20  |  Link
daphy
Miles Freak
daphy's Avatar
try this DTS test file and please post the right mapping!
THX
CYA Daphy
daphy is offline   Reply With Quote
