#1 | Link | |
New Container Mod
![]() Join Date: Apr 2002
Ogg Theora Update
I'm suprised this isn't on the front page and that there hasn't been any threads on the subject. But I imagine this is why
#2 | Link |
![]() Join Date: Nov 2001
these are indeed great news!
the idea behind theora is simply fantastic (like vorbis) and i think we should cover the developments about this much more on doom9 maybe the reason why there is not much talk about it is simply because there are no compiles for testing available so can someone of our compiler pros (maybe athos) plz make a nice compile for us
#4 | Link |
well i remembered that i had compiled ffmpeg not so long ago
![]() so using : ffmpeg_g.exe -i test_th.avi -f yuv4mpegpipe test_th.yuv i get what i wanted. Unfortunatly, the player crash badly on any ogg file producted, so i can't judge on video quality atm ![]() for a 23.23sec video, 558 frames, 320x240, no audio : - size : 1.11Mb - speed : 35.61 sec (~15fps) now if someone have some idea for playback ...
#5 | Link |
Ok, i got the player working, when compiling everything in Release mode (there was some debug things in the decoder which was stopping the process).
I included the dump utility too, here the new build : http://moodub.free.fr/theora_tools-1...ease_build.rar And for the one who want a ffmpeg build to make yuv files : http://moodub.free.fr/ffmpeg_win32_cvs20040223.rar As for quality, i'm very pleased, although it was very quick, it looked fine (well the source wasn't that great )As for speed, I can't decode flawlessly (some lag) a 640x480 video + vorbis audio, with my 2300mhz Athlon XP. |
#6 | Link |
thanks a lot!
does it output .ogg files by default? i will test it as soon as possible
#7 | Link |
it only output ogg
![]() and it isn't compatible with the actual ogm MPC internal splitter from Gabest...i leave the interpretation to you :whistle: oh, i found that it's lagging, not because of a too slow decoding (40% in 832x480), but most likely because of some synching problems when there is audio. Last edited by bill_baroud; 23rd March 2004 at 21:41. |
#8 | Link |
man, this .yuv only is crap
![]() does anyone know if there is a way to create something like a fake .yuv file which is .avs
#10 | Link |
One would have hoped that you could pipe the yuv from ffmpeg, but it doesn't look like it.
mplayer seems to play the created streams file. Can also I guess encode to theora, but I think only as an AVI? |
#11 | Link |
i got piping working \o/ so now you can test big file without a lot of extraspace
![]() just use : Code:
ffmpeg_g.exe -i test_th.avi -f yuv4mpegpipe - | encoderwin.exe -a 5 -V 1000 -o test_th.ogg test_th.wav - |
#12 | Link |
found this one
ffmpeg2theoa - simple converter to create OggTheora files. decodes all files supported by ffmpeg. no, its not a 1st april joke
#13 | Link |
well we were very lame, because latest ffdshow build with ffvfw support Theora Alpha3 for encoding
So you can put Theora in AVI/Whatever and it's decompressed by ffdshow ![]() geh, i discovered that, when hacking around Gabest OGM splitter for theora support (which was not that easy, and now, dropped ).btw, now i've a stand-alone version of his splitter at least
#15 | Link |
? personnally, i won't make any OGM files anymore (there's better alternative and it's unsupported by Xiph -look to the ogg theora bitstream-). But now i can give a working filter to people when they complain about non-playing-OGM
#16 | Link |
RealPlayer can play Vorbis & Theora! Install this plug-ins for RealPlayer:
https://helixcommunity.org/project/s...php?group_id=7 Seeking doesn´t work (loses sync), but otherwise everything is fine. |
#17 | Link | |
Senior n00b
Still, VP6 is almost 3 dB above Theora... let's hope Xiph can improve this codec a little bit more ![]() cheers ![]() virus |
#18 | Link | |
Firefox User
You need mplayer, ffmpeg and theora encoder in order to use this batch Code:
mplayer.exe %1 -vc dummy -vo null -ao pcm ffmpeg -i %1 -f yuv4mpegpipe - | encoderwin.exe -a 5 -V 1000 -o %2 audiodump.wav - del audiodump.wav
http://www.viralsound.com/get.php/roytam1.jpg |
#19 | Link |
Seek bugs fixed in RealPlayer 10 plugins
I've fixed the loss of lip-sync problems with the RealPlayer 10 Vorbis and Theora plugins. The new version is posted on the Helix site. If you have any other problems with these plugins, please post a message to dev@xiph.helixcommunity.org. I'll try to fix them as quickly as I can.
Aaron |
| Thread Tools | |
| Display Modes | |
