Old 12th March 2004, 20:21   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
How to change the default Language Menu Unit
How to change default Language Menu Unit
Courtesy of
2CL
Tool I used:
IFOedit 0.95/0.96
Most of the time, DVDs have just one Language Menu Unit (LMU), preferably English, but sometimes you’ll encounter some with more than one. Normally, the menus should all look alike with the difference of the words are in different languages. Unfortunately, there is no selection menu to choose the one you really want. I know that some DVD players can let you set the preferred language so if the language is detected in your LMUs, it will display the menu in question.
In this guide, I used Terminator 3: Rise of the Machines (region 1) as my example. It has two LMUs, English as default and French. Again, there is no LMU selection menu present. The menus are in VTS_05 so opening VTS_05_0.IFO with IfoEdit and browsing to VTS Overview / Menu Language Unit, this is what I have.
Figure 1.
Menu Language Units: 2
   Language Menu Unit 1: [English]
   Language Menu Unit 2: [Français]
     Menu 1: [Root-Menu]          (entry PGC) (Programs: 0) (Cells: 0)
     Menu 2: [Audio Menu]         (entry PGC) (Programs: 0) (Cells: 0)
     Menu 3: [Chapter (PTT) Menu] (entry PGC) (Programs: 0) (Cells: 0)
     Menu 4: [entry only]                     (Programs: 6) (Cells: 6) (uses VOB-IDs: 1)
     Menu 5: [entry only]                     (Programs: 5) (Cells: 5) (uses VOB-IDs: 2)
     Menu 6: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 3)
     Menu 7: [entry only]                     (Programs: 8) (Cells: 8) (uses VOB-IDs: 4)
     Menu 4: [entry only]                     (Programs: 6) (Cells: 6) (uses VOB-IDs: 5)
     Menu 5: [entry only]                     (Programs: 5) (Cells: 5) (uses VOB-IDs: 6)
     Menu 6: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 7)
     Menu 7: [entry only]                     (Programs: 8) (Cells: 8) (uses VOB-IDs: 8)
We need French to be our new default so below is what our end result would look like.
Figure 2.
Menu Language Units: 1
   Language Menu Unit 1: [Français]
From the start, here’s how I went about doing this.
__________________________________________________________
1. Open up your IFO in question with IfoEdit.
2. Go to / VTSM_PGCI_UT. You should have like what I have below.
Figure 3.
[00000000]  Number of VTSM_PGCI_LUs (Language Units)	    2
[00000004]  End byte of VTSM_PGCI_LUs table	            8947
[00000008]  LU_1: Video Title Set Menu Language Code	    en
   	     language_1:	                            English
[0000000b]  LU_1: Video Title Set Menu Existence mask	    168
   	     existant menus:
   	      Root Menu:	                            yes
   	      Sub-picture Menu:	                            no
   	      Audio Menu:	                            yes
   	      Angle Menu:	                            no
   	      Chapter (PTT) Menu:                           yes
[0000000c]  LU_1: Video Title Set Menu Language start byte  24
[00000010]  LU_2: Video Title Set Menu Language Code	    fr
   	     language_2:	                            Français
[00000013]  LU_2: Video Title Set Menu Existence mask	    168
   	     existant menus:
   	      Root Menu:	                            yes
   	      Audio Menu:	                            yes
   	      Angle Menu:	                            no
[00000014]  LU_2: Video Title Set Menu Language start byte  4486
Notice the start addresses for the two LUs above.
English : [00000008]
Français: [00000010]
3. Click on “HexEdit” button. You will have your HexEdit Module pop up and you will something like below. I’m just showing the first 4 lines. I highlighted the addresses and associated hex and ascii values to let you see what we need to be concerned about.
Figure 4.
00000000 00 02 00 00 00 00 22 F3 ......”.
00000008 65 6E 00 A8 00 00 00 18 en......
00000010 66 72 00 A8 00 00 11 86 fr......
00000018 00 07 00 00 00 00 11 6D .......m
4. We want 65 6E 00 A8 00 00 00 18 to be changed as our French, 66 72 00 A8 00 00 11 86. So select and only highlight 66 72 00 A8 00 00 11 86 with your mouse.
5. Do a Ctrl-C to copy values
6. Now, select and highlight 65 6E 00 A8 00 00 00 18.
7. Do a Ctrl-V to paste.
Your end results should look like this now.
Figure 5.
00000008 66 72 00 A8 00 00 11 86 fr......
8 Press OK to set.
9. IfoEdit does not automatically refresh when hexediting so as a personal trick, double-click on “Show Reserved values” checkbox bottom left and we should have it like below.
Figure 6.
[00000008]  LU_1: Video Title Set Menu Language Code	    fr
   	     existant menus:
   	      Root Menu:	                            yes
   	      Audio Menu:	                            yes
   	      Angle Menu:	                            no
[0000000c]  LU_1: Video Title Set Menu Language start byte  4486
   	     existant menus:
   	      Root Menu:	                            yes
   	      Audio Menu:	                            yes
   	      Angle Menu:	                            no
10. We just want only one LU so change the “Number of VTSM_PGCI_LUs (Language Units)” to 1.
Figure 7.
OLD > Number of VTSM_PGCI_LUs (Language Units)  2
NEW > Number of VTSM_PGCI_LUs (Language Units)  1
11. Browse back to your VTS Overview / Menu Language Unit and we now have accomplished our mission (Figure 2).
12. Save your IFO and BUP
13. Repeat steps above for VIDEO_TS.IFO / VMGM_PGCI_UT.
14. Play to test.
That’s it.
2COOL
Old 13th March 2004, 14:02   #2  |  Link
Federicos
Nice guide, 2Cool.
I'm playing now with the movie "daddy day care" region 2.
Here there are 3 menu (english, italian, spanish).
With the menu extra option of ifoedit i've been able to strip the english and spanish menu.
Now i'm trying to have italian language set as default audio track, because my player use english as default.
So the question.
When you set the french menu in the example, did the player use franch audio as default, or you must force it changing values in some pre/post command ?
Federicos is offline   Reply With Quote
Old 13th March 2004, 15:48   #3  |  Link
2COOL
2COOL's Avatar
@Federicos
Well, the example DVD I used in the guide only had one audio in the menus. In fact, it was just music without words that both menus used.
VTS overview:
Menu attributes:
  Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (16:9) (pan-scan)
  Audio 1:      Not Specified        (Dolby AC-3) 2ch 48Kbps DRC
  SubPicture 1: Not Specified        (2-bit rle )
I don't have a DVD similar to yours for testing. Maybe you can find out for both of us?
2COOL
Old 13th March 2004, 16:06   #4  |  Link
Federicos
That's a bad notice.
Opposite of you, just all the dvd that i got, have different menu.
Unfortunately, with my method i can only force the player to use the menu left after the stripping, but the other settings don't are affected.
To choose a different audio i have to set by hand the preferred language, and, except some cases, this is not easy to do due to my lower knowledge about the commands.
However, i'll try to re-edit daddy day care in your way...i'll post the result soon.
Old 13th March 2004, 17:15   #5  |  Link
P3gasus
P3gasus's Avatar
It's not difficult to set default language but the procedure changes from ifo to ifo. So it's difficult to tell you a general method.
Message in italian to make me better understand: E' difficile darti un metodo generale per settare il linguaggio di default di un dvd. Io l'ho fatto già una volta e non è difficile, solo ci vuole un po di referse engeneering sugli ifo e soprattutto la procedura cambia da dvd a dvd. E quel che è peggio è che, anche volendo, sarebbe difficile per me modificarti gli ifo perchè al 90% per capire la struttura ho bisogno anche dei vob. Cmq se vuoi provare a inviarmeli magari posso esserti utile. Mandali se vuoi a holdencaufield at wooow.it.
CIAO
Pegasus
Pegasus
P3gasus is offline   Reply With Quote
Old 13th March 2004, 20:48   #6  |  Link
2COOL
2COOL's Avatar
@Federicos
Can you post your IFO's menu attributes in VTS Overview like I did in my second post? Use the Copy2clipboard button to copy and then paste (Ctrl-V) only what I request into your post. All the DVDs I've encountered had stream combinations as below. I haven't worked with any NTSC DVD that has it differently.
  • 1 audio and no subpictures
  • 1 audio and 1 subpictures
  • no audio and 1 subpictures
  • no audio and no subpictures
Also, check your PM.
2COOL
Old 13th March 2004, 22:42   #7  |  Link
djan
- DVDRB User -
Hi 2COOL, your guide is simply amazing, it worked very well for me, thx.
- CaN -
djan is offline   Reply With Quote
Old 13th March 2004, 22:55   #8  |  Link
2COOL
2COOL's Avatar
EXCLENT!
2COOL
Old 14th March 2004, 19:24   #9  |  Link
Federicos
2Cool,
i've finished now to answer to your pm.
As i wrote, i have read it just now...sorry abain for this.
I've changed the settings of the forum to avoid other problems.
Mi vts overview of the movie daddy day care is:
VMG Overview:
Video Manager Menu attributes:
Video: MPEG-2 720x576 (PAL) (PAL 625/50) (4:3) (not specified perm.display)
Audio 1: Not Specified (Dolby AC-3) 6ch 48Kbps DRC
and at the end there is this:
First play PGC: (Programs: 0) (Cells: 0)
Menu Language Units: 3
Language Menu Unit 2: [Italiano (Italian)]
Language Menu Unit 3: [Español]
Menu 1: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 1)
Menu 2: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 2)
Menu 3: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 5)
Menu 4: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 6)
Menu 5: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 7)
Menu 6: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 8)
Menu 7: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 9)
Menu 8: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 10)
Menu 2: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 3)
Menu 2: [entry only] (Programs: 2) (Cells: 2) (uses VOB-IDs: 4)
As you can see, there are 3 menus.
Usually, i strip the unnecessary menus with ifoedit, but this affect only the language of the menu...the other settings remain as the default.
Old 14th March 2004, 19:55   #10  |  Link
2COOL
2COOL's Avatar
@Federicos
I assumed from what you mentioned before that you had more than one audio for your Language Menus but I only see just one.
Also, I see that your menus also share the same VOB IDs? With the exception of 2,3, and 4.
Since you want your Italian menu, try this. Perform the guide and then afterwards, delete VOB IDs 2 and 4 in Menu Extras. You might have to repeat step 10 afterwards.
2COOL
Old 14th March 2004, 20:08   #11  |  Link
Federicos
well,
we got a misunderstand then.
However, as i posted before, i use another way to set a different menu that have the same result..the menu extras button of ifoedit.
In this way i can also strip the cell referring to the other menu.
However, your method demonstrate again your deep knowledge of the dvd structure.
Without that button, i wouldn't be able to do this.
Old 14th March 2004, 20:18   #12  |  Link
2COOL
2COOL's Avatar
For VTS_01_0.IFO, you would have to strip VOB IDs 1-6 and 13-18 afterwards. Again, step 10 may have to be repeated and change to 1.
    Menu 2: [Sub-picture Menu]   (entry PGC) (Programs: 0) (Cells: 0)
    Menu 3: [Audio Menu]         (entry PGC) (Programs: 0) (Cells: 0)
    Menu 4: [Angle Menu]         (entry PGC) (Programs: 0) (Cells: 0)
    Menu 5: [Chapter (PTT) Menu] (entry PGC) (Programs: 0) (Cells: 0)
    Menu 6: [entry only]                     (Programs: 6) (Cells: 6) (uses VOB-IDs: 1)
    Menu 7: [entry only]                     (Programs: 0) (Cells: 0)
    Menu 8: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 2)
    Menu 9: [entry only]                     (Programs: 0) (Cells: 0)
    Menu 10: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 3)
    Menu 11: [entry only]                     (Programs: 0) (Cells: 0)
    Menu 12: [entry only]                     (Programs: 8) (Cells: 8) (uses VOB-IDs: 4)
    Menu 13: [entry only]                     (Programs: 0) (Cells: 0)
    Menu 14: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 5)
    Menu 15: [entry only]                     (Programs: 0) (Cells: 0)
    Menu 16: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 6)
    Menu 6: [entry only]                     (Programs: 6) (Cells: 6) (uses VOB-IDs: 7)
    Menu 8: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 8)
    Menu 10: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 9)
    Menu 12: [entry only]                     (Programs: 8) (Cells: 8) (uses VOB-IDs: 10)
    Menu 14: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 11)
    Menu 16: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 12)
    Menu 6: [entry only]                     (Programs: 6) (Cells: 6) (uses VOB-IDs: 13)
    Menu 8: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 14)
    Menu 10: [entry only]                     (Programs: 1) (Cells: 1) (uses VOB-IDs: 15)
    Menu 12: [entry only]                     (Programs: 8) (Cells: 8) (uses VOB-IDs: 16)
    Menu 14: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 17)
    Menu 16: [entry only]                     (Programs: 10) (Cells: 10) (uses VOB-IDs: 18)
2COOL
