Thread Tools Display Modes
Old 29th February 2004, 13:01   #1  |  Link
Koepi
Koepi's Avatar
ni hao! (XviD-1.0-RC3)
Ni hao everyone!
We are proud to release XviD-1.0-RC3, hopefully the last version before going final.
We need proper bugreports now ("It's black! I don't see anything!" or "This sucks, it's jerky." is not a proper bug report!), so please read the thread "how to report bugs" and follow the guidelines. Thanks
Changelog:
XviD-1.0-RC3-29022004 (ni hao!):
- Bitrate calculator fixes
- Status window fixes (-> GMCed frames get counted)
- Decoder fixes
- Workaround for dev-api-3 non-mod16 encodes
- Mod4 / YV12 resolutions encoding fixed
- Multilanguage installer
-> IMPORTANT: we need proper feedback and testing now - we want 1.0 to be final soon!
ATTENTION: Since I lost all my data, I switched to another installer system.
(Since XviD-1.0-RC1.)
If you used the old NSIS installer, please uninstall it manually
before upgrading with these new installers.
If you have done that already, upgrading with these new installers
works like you expect it.
Also, Win9x support is better now with this installer.
Thanks for your support!
Best regards
Koepi
Koepi is offline   Reply With Quote
Old 29th February 2004, 14:08   #2  |  Link
RexManning
Generalization Officer
RexManning's Avatar
<totally unhelpful comment>
Whooooo-hooooooo, RC3! Go XviD-Team! \o/
</totally unhelpful comment>
RexManning is offline   Reply With Quote
Old 29th February 2004, 14:16   #3  |  Link
Manao
Thank's a lot Koepi and all XviD's devs !
Manao is offline   Reply With Quote
Old 29th February 2004, 14:27   #4  |  Link
OBcecado
LuLz
Another RC
Thanks for giving us tools to play with in the dvd-backup world.
Greetz.
OBcecado is offline   Reply With Quote
Old 29th February 2004, 15:26   #5  |  Link
vinkes
now at 300 xvid rips!
@ xvid team, thanx for the new release.
I immediately started encoding 'indiana jones and the last crusade' PAL.
avs settings:
704x288
neutral bicubic
no filtering
xvid settings:
profile level unrestricted
2pass
motion precision: 6
vhq : 1
turbo mode: on
chroma motion: on
frame drop ratio: 0
i-frame interval: 300
unrestricted quantizers (1-31)
trellis quantization: on
decoder options:
deblocking u & uv: on
compatibility mode: on
I ended with a firstpass (full quality) filesize of 1.735.906kb.
The first pass is completed now. Quality looks excellent, i did a quick look, i could not detect any visual artifacts.
I had no probs encoding or decoding. Running second pass now.
Ezekiel 25:17.
"The path of the righteous man is beset on all sides by the inequities of the selfish and the tyranny of evil men. Blessed is he who, in the name of charity and good will, shepherds the weak through the valley of the darkness. For he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who attempt to poison and destroy my brothers. And you will know I am the Lord when I lay my vengeance upon you."
vinkes is offline   Reply With Quote
Old 29th February 2004, 15:28   #6  |  Link
communist
Cool
Oh a sidenote could you please check your pm Koepi?
communist is offline   Reply With Quote
Old 29th February 2004, 15:37   #7  |  Link
virus
Senior n00b
well, the only problems I found are GUI-related, and they're almost the same as RC1 & RC2... some tooltips still missing (chroma optimizer, bvop sensitivity, reduced resolution) plus that nasty "jump" of the weight zone slider (set it to 1.15 and you'll see... can someone confirm it anyway?)
I hope not to get bashed for reporting these 2 times, but I think now it's time to worry about these "small" things
thx for all your work
virus
virus is offline   Reply With Quote
Old 29th February 2004, 15:58   #8  |  Link
communist
Yep when you slide to 1.15 and release mouse button it jumps to 1.13. Setting it manually to 1.15 changes it to 1.14, manually set it to 1.16 and then it was 1.15. Is it just reporting wrong number or is that number actually being used?
There is more:
If you choose 'Single Pass', switch to 'Target quant', enter any value between 1.13 and 1.16 and keep switching between 'Target quant' and 'Target Bitrate' it will incrementally drop the Target quant to 1.12 with each switching.
Just went through Target Quant again with the keyboard there seem to be a lot more values that are simply not 'allowed':
2.01 2.03 2.05 2.07 2.26
and more...
Values not allowed for Weight:
0.29 0.57 0.58 1.12-1.16
Also if you enter 1.16 in weight / quant (Zone options) and then switch to the other method and hit ok / enter it will decrease the value too.
To the devels:
Are these values not allowed and are there for being skipped?
Old 29th February 2004, 16:26   #9  |  Link
Koepi
Koepi's Avatar
That jumping slider issue is (hooray!) yet again a M$ bug. We need to look into that (i.e. remove the slider completele).
@communist:
Your PM was regarding Reduced Resolution: it's not broken, but it's not meant for the mainstream usage. It's there for streaming media (therefore a rule 1 strike, it's gotten explained many times) over the internet. We have now the profile "ASP level 5" as default which prevents the usage of reduced resolution.
Regards
Koepi
Old 29th February 2004, 17:27   #10  |  Link
communist
Originally posted by Koepi
it's not broken,
Ok thats all I wanted to know
Thx for clarifying.
Old 29th February 2004, 17:42   #11  |  Link
crusty
Ahhh....Nuts!!
crusty's Avatar
@communist:
It's not broken, it's simply of not much use.
AFAIK it's not broken or buggy, but the proper use of it requires a dynamic implementation of RRV which isn't implemented (yet) in XviD.
Basically that means it's pretty much useless.
Use the search, there's a post by sysKin which pretty much explains it.
Xp2100+, ECS L7VTA, Terratec Aureon Fun, Radeon 9500 pro, Maxtor 200 GB HDD, 512 MB ram, Windows 2003 server
New Xvid FAQ at ronald.vslcatena.nl/docs/xvidfaq.html
Want to know how Bush is meddling with your dollars? www.bushnews.com
My Weblog
crusty is offline   Reply With Quote
Old 29th February 2004, 19:37   #12  |  Link
snorre
No fair! I've been a fan of your binary since I started using XviD, but lately I've been compiling my own XviD codecs (better CPU optimization I think, gains ~20% speed over Koepi's binary).
I can't find RC3 for download on xvid.org!!!
Stop cryin' and mow the lawn!
snorre is offline   Reply With Quote
Old 29th February 2004, 19:45   #13  |  Link
atreya2011
Apprentice Ripper
http://koepi.roeder.goe.net/
get it from Koepi's site then....
My Rig(Not the best, but good enough)
AMD Athlon XP 2100+
ATI Radeon 9700 PRO
80 GB Seagate HDD 7200 RPM
LG 16X DVDROM Drive
Kingston 512MB PC3200 DDR-RAM
ABIT NF7 NForce2 MOBO
atreya2011 is offline   Reply With Quote
Old 29th February 2004, 19:49   #14  |  Link
snorre
I have, but as you can read in my post, I prefer to compile myself, so I need the sourcecode, not a precompiled binary.
Old 29th February 2004, 19:56   #15  |  Link
Episode
n00b
Episode's Avatar
You can get the source code from here.
Episode is offline   Reply With Quote
Old 29th February 2004, 19:58   #16  |  Link
snorre
Thanks!
Old 29th February 2004, 20:17   #17  |  Link
communist
Exactly. This is the post I was refering to :
http://forum.doom9.org/showthread.php?s=&threadid=64924
Originally posted by sysKin
There is a big chance it's even broken completely. I haven't tested it for ages... And if it is, I have no idea if it's decoder or encoder that has it broken (or both).
Thats why I wanted to know if its broken or not.
Old 29th February 2004, 20:32   #18  |  Link
Koepi
Koepi's Avatar
a) For which CPU are you optimizing?
b) 20% gain is quite unrealistic. Retest with your compile of rc3 and my build. (Do a proper speed test, exactly the same setup, fresh restarted system etc.). You can squeeze out max. 5% more as a rough guess from optimizing for a special CPU.
Koepi
Old 29th February 2004, 21:40   #19  |  Link
Selur
member of flaskmpeg.info
Selur's Avatar
If 20% turns out to be true, I'll start compiling my own builds too, but I guess Koepi is right normally 5% is more realistic.
Cu Selur
Ps.: are there any plans to change the GUI up to 1.0? (otherwise I'll update my 'Wissenswertes rund um Xvid' next weekend)
Old 29th February 2004, 22:13   #20  |  Link
crusty
Ahhh....Nuts!!
crusty's Avatar
Yes, I'd love to know that as well...I'm planning to include screenshots of vfw GUI in my FAQ.
BTW, haven't tried RC3 yet, but have started encoding again with RC2 and must say that not only quality is excellent, but speed is A-OK as well.
20-25 fps on NTSC version of Disney's alice in wonderland using Undot, Dup, and Fluxsmooth is quite neat! (Settings: VHQ 4 (!) B-fr 2/1.5/1, H.263, Chroma Optimizer, Trellis). I was especially surprised about the speed i get with VHQ=4.
(As a sidenote: I found that Alice in Wonderland animation is in fact often only 12 FPS. Only when there's a lot of motion in the clip it's true 24FPS. I guess they were kinda lazy over at Disney's..)
My Weblog
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
