Old 17th January 2004, 20:00   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Bypassing Paramount's "Previews/Main Menu" Selection Menu
Courtesy of 2CL
Lately, I have encountered a lot of Paramount Region 1 DVDs that has a Previews or Main Menu option as a startup menu. Sort of like a aspect ratio menu with you selecting widescreen or fullscreen. I can't confirm for the other regions though but what I’ve noticed is that this clip always reside as a angle-menu in my VTS_02_0.VOB. Here’s what I have as viewed in IfoEdit in my VTS_02_0.IFO.
VTS overview:
Language Menu Unit 1: [English]
   Menu 1: [Root-Menu]     (entry PGC) (Programs: 0) (Cells: 0)
   Menu 2: [Angle Menu]    (entry PGC) (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) Pre menu
   Menu 3: [entry only]                (Programs: 1) (Cells: 1) (uses VOB-IDs: 2)Post Menu
Note: If it's not the same layout in VTS_02_0.IFO, then search the other titlesets and you'll find one that fits the description above.
I want to get rid of this Preview/Main Menu startup screen so here’s I do.
Using IfoEdit, go to VTS_02_0.IFO / VTS_PGCI_UT / PGC-Menu_2 (Angle Menu) / PGC Command Table. Using the example below, double click on Number of Pre Commands and enter a “1”. Double click on Number of Post Commands and enter a “0”.
BEFORE:
PGC Command Table:
  Number of Pre Commands             0
  Number of Post Commands            1
  Number of Cell Commands            0
  Size of Command table in bytes     15
  1.Post Command                     Set GPreg<0> mov (set-val)<1>(LinkPGCN) Link PGC 3
To refresh the screen, I use this personal trick. Click on “Show Reserved Values” checkbox and the you window will refresh. Scroll down to PGC Command Table to review your changes and this is what you’ll have. The Post command is now a Pre Command so that means the startup screen is now bypassed.
AFTER:
PGC Command Table:
  Number of Pre Commands             1
  Number of Post Commands            0
  1.Pre Command                      Set GPreg<0> mov (set-val)<1>(LinkPGCN) Link PGC 3
There’s also a post clip for this startup menu and it resides in the next PGC, which is PGC-Menu_3. Go to / VTS_PGCI_UT / PGC-Menu_3 / PGC Command Table. Do the same as what you did for PGC-Menu_2 and this is what you should have before and after.
BEFORE:
PGC Command Table:
  Number of Post Commands          3
  Size of Command table in bytes   31
    1.Post Command                 Set GPreg<1> mov (set-val)<2>
    2.Post Command                 If GPreg<0> == GPreg<1> then (JumpSS VMGM) Jump to VMG PGC: 22
    3.Post Command                 (JumpSS VMGM) Jump to VMG PGC: 4
AFTER:
PGC Command Table:
  Number of Pre Commands           3
    1.Pre Command                  Set GPreg<1> mov (set-val)<2>
    2.Pre Command                  If GPreg<0> == GPreg<1> then (JumpSS VMGM) Jump to VMG PGC: 22
    3.Pre Command                  (JumpSS VMGM) Jump to VMG PGC: 4
Save VTS_02_0.IFO and BUP and play to test. You shouldn’t have your Preview/Main Menu pop up now.
If you want to know the full details on why you did the edits, read here.
2COOL
Old 12th September 2004, 04:49   #2  |  Link
DocDragon
"Free your mind..."
DocDragon's Avatar
Star Trek Nemesis
hi 2cool!
thnx 4 all your efforts with your guides.
i was reading your post with great enthusiasm because i had exactly this issue with paramount's preview/main menu selection on STAR TREK NEMESIS. unfortunately, your description of the VTS overview does not match star trek's nemesis structure:
this is your description of how paramount's "VTS_02_0.IFO"'s usually are:
VTS overview:
but paramount's stnemesis "VTS_02_0.IFO"'s structure differs:
VTS overview:
Menu attributes:
Video: MPEG-1 720x480 (NTSC) (NTSC 525/60) (4:3) (pan-scan & letterboxed)
Title Set (Movie) attributes:
Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (16:9) (pan-scan)
Audio 1:      English              (Dolby AC-3) 2ch 48Kbps DRC normal (ID: 0x80)
PGC_1 (program chain): [Title(TTN): 1] [00:00:21.00 / 30 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1)
[Ch 01] [Pg 01] [Cell 01] [V/C Id:  1/ 1]          : time: 00:00:21.00 / 30 fps     [Pos: 00:00:21.00] [Frames: 630]
PGC_2 (program chain): [Title(TTN): 2] [00:00:02.15 / 30 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 2)
[Ch 01] [Pg 01] [Cell 01] [V/C Id:  2/ 1]          : time: 00:00:02.15 / 30 fps     [Pos: 00:00:02.15] [Frames: 75]
Menu Language Units: 1
here's an extract of the "VTSM_PGCI_UT" from its "VTS_02_0.IFO":
   	PGC Command Table:
[000000ec] 	  Number of Pre Commands	1	[0001]
[000000ee] 	  Number of Post Commands	0	[0000]
[000000f0] 	  Number of Cell Commands	0	[0000]
[000000f2] 	  Size of Command table in bytes	15	[000f]
[000000f4] 	    1.Pre Command	(JumpSS VMGM) Jump to VMG PGC: 7	[30 06 00 07 00 c0 00 00 ]
   	There is no PGC Program Map
   	There is no Cell Playback Information Table
   	There is no Cell Position Information Table
i can confirm that pgc_1 and pgc_2 contain the pre and post menus.
correct me if i'm wrong: according to your guide, the preview/main menu selection would be skipped to jump directly into the main menu, right?
TIA
DD
ASUS A8N32SLI; AMD 3800+ X2 (o/c'ed to 2.45 GHz); 4 GB RAM; 431 W PSU; eVGA 6800GT; Hauppauge PVR-350; Seagate HDDs: 160, 300, 2 x 300 as RAID-1; BenQ DW1640; Lite-On SOHC-5232K; Win XP SP2
DocDragon is offline   Reply With Quote
Old 13th September 2004, 05:39   #3  |  Link
2COOL
2COOL's Avatar
Re: Star Trek Nemesis
Are you sure you are referring to VTS_02? I just looked at your DVD dump and your PGCs don't have any buttons assigned to them. Hmmm...the Paramount menus I was talking about had you selecting Main Menu or Previews. Maybe it's in another VTS. Open up your DVD with DVD Shrink and preview. Tell me which VTS they are in to confirm if it's not in a menu.
2COOL
Old 14th September 2004, 06:46   #4  |  Link
2COOL
2COOL's Avatar
   	PGC Command Table:
What you posted and what you gave to me in your DVD dump does not sync up. You have an extra post command in your DVD dump and the Post command #s are not correct. Are you using PgcEdit v0.3.4?
VTST 2 / TTN 1  (0:21)  Title 1
********** pre commands:
[51 00 00 80 00 00 00 00]   1  (SetSTN) Set Audio stream = 0
********** post commands:
[30 08 00 09 01 C0 00 00]   3  (CallSS) Call the VMGM PGC 9, resume cell 1 :confused:
[30 08 00 07 01 C0 00 00]   4  (CallSS) Call the VMGM PGC 7, resume cell 1
********** cell commands:
2COOL
Old 17th September 2004, 05:59   #5  |  Link
DocDragon
"Free your mind..."
DocDragon's Avatar
2cool:
i can't verify the dumps right now because i lent the dvd to a friend of mine. i'll get back to you when he returns the disc. thnx 4 your time, though!
DD
Old 19th September 2004, 01:04   #6  |  Link
2COOL
2COOL's Avatar
No problem. I just hope I'm not to bogged down with other projects till then.
2COOL
