Thread Tools Display Modes
Old 30th November 2003, 02:41   #1  |  Link
Koepi
Koepi's Avatar
Aloha!
Tadaaa!
We are very proud to announce..... *whirling drums*
XviD-1.0-Beta 1 (codename Aloha)!
There will be plenty of bugs, your bitstreams might be not mpeg4 compliant , the usual stuff... but it's there, it's real, it's fresh, we're alive 'n kicking!
Enjoy this release and give plenty of feedback please! We want XviD-1.0 to be rock-solid, so we need your input now as we found most of the important bugs ourselfes and think you are way better in finding the remaining (hidden for us) flaws.
Btw.: the GUI might be subject to change. Play around with it in any case, you'll find some features are a bit "hidden" compared to the old GUI.
Ok, stopping the babbling now, follow the link in my signature to find the build - and enjoy the all new, close-to-final XviD-1.0!
Best regards,
Koepi
Koepi is offline
Old 30th November 2003, 02:46   #2  |  Link
gldblade
XviD Junkie
I guess I should have waited for it to be announced officially
About the GUI, I've always been wondering why hovering over the options does not consistently bring up the pop-up yellow descriptions. Is this just a problem with my computer, or is anyone else having this problem?
gldblade is offline
Old 30th November 2003, 02:53   #3  |  Link
Koepi
Koepi's Avatar
Some items don't have a description :-/ But vfw GUI isn't major concern now, it's the codec internals (as I wrote, GUI is subject to change, so it'll be all different from the interface side some time soon hopefully).
Regards
Koepi
Koepi is offline
Old 30th November 2003, 03:02   #4  |  Link
cipher
WOW!!
I'll just leave my name here for future historical records
'been waiting for this for a long damn time, tho I know this is not quite different than the latest dev-api-4 cvs, but XviD 1.0 sounds just cool.
cipher is offline
Old 30th November 2003, 03:36   #5  |  Link
Lobuz
Lobuz's Avatar
....finally!!!
It sounds cool. But just take a look at the backstage of xvid dev mailing list.
Regards
Lobuz
Lobuz is offline
Old 30th November 2003, 03:44   #6  |  Link
mfluder
I guess I will be the first one to open this bug hunting season. What an honour
I noticed this during the testing of my dev-api-4 compiles but I wanted to wait for the official betas. When decoding dev-api-3 streams (Koepi's latest) and the height is not multiple of 16 (it's multiple of 8, 640x360) there is a bleeding at the bottom of the clip. I don't have any webspace so I can't post a screenshot but you can spot it easily. There is no problem when the clip is encoded with dev-api-4.
Other than that, so far, I haven't found anything serious. It's worth mentioning that the speed has quite improved compared to dev-api-3. Oh wait, that's not a bug
Congratulations to the whole XviD team, you are doing a great job.
mfluder
mfluder is offline
Old 30th November 2003, 03:50   #7  |  Link
yeeyy
Cool!!! I have been waiting for today.
yeeyy is offline
Old 30th November 2003, 03:53   #8  |  Link
cipher
....finally!!!
yeah I know there's been little arguments regarding the XviD 1.0 and its code, and honestly, I was a little shocked when I saw this beta released, coz' I thought they hadn't reached an agreement.
Anyway, the more important thing for us to do now is testing and giving feedbacks.
cipher is offline
Old 30th November 2003, 05:30   #9  |  Link
BoNz1
BoNz1's Avatar
Hey, hey it has been too long! Anyway, even though I have been testing dev-api-4 a lot since the summer I'm going to do some encodes tonight and I will report tommorow maybe. I think I'm going to encode the Grinch w/ qpel, bframes: 1 1.5 1, adaptive quant, trellis, h263, vhq1, cm. Hopefully, I will be able to put it onto 1 cd at 704x384 res.
BoNz1 is offline
Old 30th November 2003, 05:54   #10  |  Link
K-Dash
nooblar
K-Dash's Avatar
Great work!
I was wondering if b-frames works since I can't seem to find the old options for it in this one and I've tried several passes with bframe quant 2-6 2-4 and it doesn't show up on the xvid frame encoding window.
K-Dash is offline
Old 30th November 2003, 06:01   #11  |  Link
Tuning
I'm back! :D
Tuning's Avatar
Alohamora!
Opening new year of encoding, with XviD 1.0. How wonderful!.
Thanks koepi.
Tuning is offline
Old 30th November 2003, 06:11   #12  |  Link
winman
Wow...this is nice.
@K-Dash
- Click on the [...] box next to Profile @ Level (you need to select AS or higher profile inorder to enable b-frames).
- Check the box BVOPs
@Koepi
Is there a way to read the info for the first and last 173 frames in the StatsReader?
BTW...does the "Display encoding status" option work with avs2avi?
winman is offline
Old 30th November 2003, 08:40   #13  |  Link
Enigmax
greetings
Enigmax is offline
Old 30th November 2003, 08:58   #14  |  Link
kastro68
Dai Suki
kastro68's Avatar
When doing 2passes and using a quantizer ratio of 5,
The first pass and second pass have the same file size.
ie. The second pass does not shrink to the target size.
I'll try it again on a different source, I'm pretty sure I didn't do two first passes.
Is GMC safe to use with VHQ4?
edit: Thanks for new build. I like the new gui...comes in handy especially for managing credits.
Always choose the path that leaves you with the most degrees of freedom.
kastro68 is offline
Old 30th November 2003, 10:12   #15  |  Link
K-Dash
nooblar
K-Dash's Avatar
Originally posted by winman
Wow...this is nice.
@K-Dash
@Koepi
I see, thanks. Woah the first thing I noticed about this is the speed upgrade from the old build.
K-Dash is offline
Old 30th November 2003, 10:38   #16  |  Link
amirlsm
Can anyone post an updated "Xvid Options explained"?
Nice work developers!
I'm already trying encoding with the new beta.
Since the options GUI changed, Can anyone post an updated "Xvid Options explained"?
Could anybody shade some light on the "profiles"
Will using a pre-defined profile, guaranty playing the disk on a hardware "Divx" player or a future MPEG-4 player?
Tnx,
Amir
amirlsm is offline
Old 30th November 2003, 11:11   #17  |  Link
VincentRPGz
Finally! A new xvid! this is what everyone has been waiting for! Good job so far from what I see, another amazing thing from the xvid team!
As usual, keep up the good work!
VincentRPGz is offline
Old 30th November 2003, 11:25   #18  |  Link
b00zed
Person
b00zed's Avatar
That codename sounds eerily similar to those released by DivX labs, coincidence?
I recognise, and can appreciate, the effort that goes into some of these fairly complex open source projects. I'm consistently impressed by the abilities of the various beta codecs that have been released, and a solid representative v1.0 release might be just the thing to convince me to turn to the dark side, at least for high bitrate work
I think congratulations are appropriate for everyone involved in the development of this project.
Edit: I have to say I like the interface, and the addition of selective quantization zones is very nice
Would you like some candy little girl?
b00zed is offline
Old 30th November 2003, 11:31   #19  |  Link
Teegedeck
Moderator, Ex(viD)-Mascot
Teegedeck's Avatar
@kastro68: No, GMC still doesn't help with VHQ=4.
But Trellis now works with MPEG-quantization, give it a try.
Thanks to all developers out there who sacrificed their spare-time to give us this! We follow your activities on the ML; though you can't hear us cheering everytime you submit code, we certainly do.
It's a man's life in Doom9's 52nd MPEG division.
"The cat sat on the mat."
ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl!
Teegedeck is offline
Old 30th November 2003, 11:43   #20  |  Link
ammer
woohoo! yay
ammer is offline
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
