#1 | Link |
Kiss DP-450 now plays Divx 3.11
This is firmware version 3.00 for a Kiss DP-450 clone, it has been said that it works 100% on the Kiss DP-450. It was originally meant for HB DX-6526, which is a French version of the Kiss.
Read here: http://www.multi-hardware.com/affnews.php3?p=3#3903 and download here: http://www.hb-direct.com/hb-dx-6526-PAL-3_0.zip Use with caution!! |
#2 | Link |
Doom9 in Spanish Team
This looks interesting.
Can anyone confirm it works for the original Kiss DP-450? Anyway, the link is in French (and I canīt read in French), I will see if I can find an English translation for it. CU
epere4 Doom9 in Spanish [Site] - [Forum] Get DVobSub 2.23 and VobSub 2.23 in Spanish |
#3 | Link |
Quick translation :
- You can use the firmware for the HB DX-6526 on the DP-450 - There should be a firmware update for the DP-450 soon
The fate of destruction is also the joy of rebirth. |
#4 | Link |
Capture, Deinterlace
![]() Join Date: Feb 2002
E8400/P43, 4G, GTX260+, FastCom TV+FM (BT878, Philips tuner, PAL), XP32/SP3. Get Firefox. Get SmoothWheel Firefox extension. |
#5 | Link |
This firmware works perfectly with the DP-450.
- DivX 3.11 play not always perfectly. Their's some problem when the bitrate is high. But it works.. - MP3 VBR play 100% fluent !! (Even after a "search" or a "pause" ) - BivX are now fully supported (you can select the Audio stream with the audio-menu ) - Their's a new function : "Auto FullScreen". (When you read a DivX with a resolution < 640xXXX, the Zoom is used Automatically. Like VCD & SVCD ) - Subtitles are now centered. --- But this firmware is not bugfree: - Their's some Audio problem with some 3.11. Sometimes sound becomes robotic. - (some) People reported problems with Ac3 & DivX 4/5 - (some) People reported synch problem with some Subs Official link to the firmware is down (Maybe beccause they are doing 2-3 corrections ). But you can find it here : http://overnetfr.free.fr/kiss/datas/...rmware_3.0.iso Last edited by seewen; 21st May 2003 at 18:02. |
#6 | Link |
The original Kiss firmware supports DivX 3.11 now....
http://www.kiss-technology.com/suppo...50_upgrade.asp |
#18 | Link |
look in FAQ FAQ 7 Q07: What kind of optical medias are supported by the DVD-Player? A: The following optical medias are supported: CDDA (Normal music CD's). CD-R (74min and 80min) Do not use CD's larger than 80min, doing this may cause the loader to jam shut. CD-RW (74min and 80min) Do not use CD's larger than 80min, doing this may cause the loader to jam shut. DVD-R DVD-RW (DVD+R and DVD+RW are not supported by the DVD-Player). Arda |
#20 | Link | |
Their is a TOSHIBA DVDRom in the KISS DP-450/500 (SD-M1612 RevA, RevB, RevC or SD-M1712 ). I got the SD-M1712, and it can read DVD+R(W). If I remeber well, the SD-M1612 RevA cannot.. (But I'm not sure. Maybe it's the "RevB" or "RevC" or all SD-M1612 ). But you can change the DVDRom. You can, for example, replace the TOSHIBA with a LITE-ON. So you can even read 99' CD-R. ----------- For the OGG, I think that the KISS support only Music CD with OGG. Not OGG in MPEG4. Maybe it works with the last firmware, I didn't try yet. But Kiss said that they were working on it... A futur firmware ( They were promissing 3.11, GMC, MP3-VBR, BivX, Subtitles, etc.. And they did it ;-) ). |
| Thread Tools | |
| Display Modes | |
