#1 | Link |
DVD2one Team Member
DVD2one new version out now (1.1!)
Here's a new version of DVD2one with the following new features:
- Full disk copy mode added. Please note that the image quality will be less than when you use movie-only copymode, because there is more data to copy and also all soundtracks will be included. - New system to calculate the compression ratio. This should keep the image quality more stable. - Improved the progress bar. It should run continuously now for all movies. - Added detection that you try to read directly from a protected DVD.
<-- Official DVD2one.com team member --> |
#4 | Link |
![]() cheers guys,ill check it out,im running it already and its again the fastest 1 ![]() edit: first movie(blade2) is alright, have past the test,theres quality loss,good to watch though (used the default settings=3289MB) Have to test on that 1,anyways its working whitout a bug takes 69 min to complete,conclusion dvd2one is fast ![]() keep up the great work on this piece of software ![]() Last edited by Sofaking; 20th March 2003 at 21:34. |
#6 | Link |
![]() Join Date: Oct 2001
Just did my first movie -- looks good so far, will advise after burn and viewing on the bigscreen. There's a couple of good ways I can imagine to remove the extra audio streams before compressing... I'll try a couple and give some feedback.
#9 | Link |
Just did a full copy of Yamakasi - PAL:
Original DVD: Total filesize 7.429.886 Movie 6.225.656 Extras 1.204.210 DVD2ONE 1.1.1: Total filesize 4.579.548 Movie 3.837.768 Extras 741.780 Everything tested out allright - all menus working fine - all extras selectable and playable - all audiotracks and subtitles present and selectable. Quality SURPRISINGLY GOOD - naturally not CCE quality but definately acceptable considering the transcoding of the movie from 6.225.656 to 3.837.768 - I could show this dvd to everyone I know and noone would question it was the real thing. And how long did this 1 to 1 copy including transcoding take ?? A staggering 19 min !!!!!!!! Yes you read it correct - 19minuttes total. Simply incredible ![]() Last edited by DVC2; 21st March 2003 at 00:00. |
#11 | Link |
Ever considered getting a real dvd-player instead of using a gameconsole ? the ps2 is not exactly famous for its compatibility as a dvd-player
![]() ![]() http://club.cdfreaks.com/showthread....threadid=66369 ReneB has some comments on the "layer break issue" Apart from this you must admit that 19 minuttes to create a 1 to 1 copy is pretty impressive ![]() Last edited by DVC2; 21st March 2003 at 00:05. |
#16 | Link |
hehehe - I totally agree with you - I also hate the time it takes for ifoedit to do its stuff
![]() Talk about spoiled - in the old days (which werent to long ago) we spent days creating one dvd/svcd/vcd whatever - now we moan about spending 20 minuttes with ifoedit - LOL ![]() Last edited by DVC2; 21st March 2003 at 00:08. |
#17 | Link |
Remember Rule One
#18 | Link |
I have to disagree just slightly - as I see it the current ways to do dvd2dvd ripping actually requires less usertime than before when ripping to vcd/divx if we settle for the same result (just a main title) or now also even for a 1to1 copy - both of these scenarios can be done in a 3 click environment and result is great. Theres not more usertime in this than there was before. Definately not.
The main difference now is we are spoiled and dont settle for either main movie or 1to1 copy - we want to controle EVERYTHING - we wont settle for movie, we also want menus, preferably moving menus at that - we wont settle for mpegaudio, we also want ac3 or dts - we wont settle for all audiotracks and extras, we want to customize and take away certain items only. Our demands are way higher today for the final result than it was before - and still we want it finished before we finish our cup of coffee. Call me crazy but I think we are spoiled with the options we have and the things we can do today ![]() |
#19 | Link |
There is a new version of DVD2One... well sort of... ReneB said that they fixed another bug this morning an put it on their site without changing the version number...
//DVMan\\ |
#20 | Link |
New version looks good - just also wondering about the Audio/Sub stripping. Anyone got any preference for how to do this before DVD2One does it trick. IFOEdit was mentioned earlier, but I am unsure what the sequence- there must be a guide somewhere already!
