#1 | Link |
Just A Walker
Problem with Koepi's XviD-09122002-1
I have just encoded a clip with this build but I can't decoded it with ffdshow-20021113. In bsplayer is sais overlay failed and in mplayer it doesn't load...Anyone has the same problem?
Thanks, MoonWalker |
#2 | Link |
aka Νικόλαος
What about the original XviD decoder? Did you try it? Does it work?
NiTroGen: Colorless, odorless, tasteless, generally inert gas. Fifth most abundant element in the universe. Makes up about 78% of earth's atmosphere. |
#6 | Link |
![]() Join Date: Oct 2001
You seem to finally have somehow messed up your system %) That's quite an unusual behaviour - but certainly not caused by xvid-09122002-1.exe.
Koepi
Koepi's new media development site |
#7 | Link |
Works fine, no decoding problems, i have tried lots of different settings(b-frames+Qpel+crom. mot. etc etc.) but i don't use bsplayer(because i don't like it). I haven't tried GMC...
I use ffdshow 20021129, Zoomplayer and mplayer 6.** without any problems... |
#8 | Link |
DVD Rebuilder!
No problem on my machine, Win2k, Sp3, Zoomplayer 3.0 beta2, Gabest's MPC 6.4.006,
2-pass int, with B-frame : 3/150/100, Qpel, fourCC:XVID, DV50 compatibility enabled. ffdshow 20021113 with "used XviD":unchecked and Nic's postprocessing, with IDCT:XviD. |
#9 | Link |
No problems here at all. Actually, I encoded 6 movies today, and they all look great!
MPEG, DX50, CME, 3/100/150, no Qpel, no GMC, 2-pass internal. Win2k SP3, XP SP1, bsplayer, ffdshow 11-13, no postproc. cjv |
#10 | Link | |
n00b ever
y |
#12 | Link |
qpel settings
I've another problem.
I doesn't matter if you set qpel on or off, it's always off, if you set off the automatic qpel decision. And i don't like the automatic decision. The picture is definatly more blurrier than with the nov.25. build. (ok, the other new features can cause this too, but i suspect the qpel/hpel switcher.) |
#13 | Link |
I've got some crash with this build using VDub.
Here's my settings: Quant: MPEG Max I: 300 Min I: 1 Max B: 2 Quant: 150/100 DIVX5 Comp enabled Alt Curve with 175/80, 30% str. VirtualDub crash report -- build 14328 (release) -------------------------------------- Disassembly: 013ebc60: ff03 inc dword ptr [ebx] 013ebc62: ff03 inc dword ptr [ebx] 013ebc64: c08b73580fafc6 ror byte ptr [ebx-50f0a78d], c6 013ebc6b: 8b09 mov ecx, [ecx] 013ebc6d: 03cf add ecx, edi 013ebc6f: 03c8 add ecx, eax 013ebc71: 894b4c mov [ebx+4c], ecx 013ebc74: d1ee shr esi, 1 013ebc76: 8d1412 lea edx, [edx+edx] 013ebc79: 03d2 add edx, edx 013ebc7b: 03d2 add edx, edx 013ebc7d: 8d4c2d00 lea ecx, [ebp+ebp+00] 013ebc81: 03c9 add ecx, ecx 013ebc83: 03c9 add ecx, ecx 013ebc85: 0fafce imul ecx, esi 013ebc88: 8bb42480010000 mov esi, [esp+180] 013ebc8f: 8b6e08 mov ebp, [esi+08] 013ebc92: 03ea add ebp, edx 013ebc94: 03e9 add ebp, ecx 013ebc96: 896b44 mov [ebx+44], ebp 013ebc99: 8b6e04 mov ebp, [esi+04] 013ebc9c: 03ea add ebp, edx 013ebc9e: 03e9 add ebp, ecx 013ebca0: 896b40 mov [ebx+40], ebp 013ebca3: 8b6c243c mov ebp, [esp+3c] 013ebca7: 8b7500 mov esi, [ebp+00] 013ebcaa: 03f7 add esi, edi 013ebcac: 03f0 add esi, eax 013ebcae: 897328 mov [ebx+28], esi 013ebcb1: 8b742444 mov esi, [esp+44] 013ebcb5: 03f7 add esi, edi 013ebcb7: 03f0 add esi, eax 013ebcb9: 89732c mov [ebx+2c], esi 013ebcbc: 8b742440 mov esi, [esp+40] 013ebcc0: 03f7 add esi, edi 013ebcc2: 03f0 add esi, eax 013ebcc4: 897330 mov [ebx+30], esi 013ebcc7: 8bb4247c010000 mov esi, [esp+17c] 013ebcce: 8d343e lea esi, [esi+edi] 013ebcd1: 03f0 add esi, eax 013ebcd3: 897334 mov [ebx+34], esi 013ebcd6: 8b7508 mov esi, [ebp+08] 013ebcd9: 03f2 add esi, edx 013ebcdb: 03f1 add esi, ecx 013ebcdd: 89733c mov [ebx+3c], esi 013ebce0: 8b6d04 mov ebp, [ebp+04] 013ebce3: 03ea add ebp, edx 013ebce5: 03e9 add ebp, ecx 013ebce7: 896b38 mov [ebx+38], ebp 013ebcea: 8bac2490010000 mov ebp, [esp+190] 013ebcf1: 8b14ad60d44001 mov edx, [ebp*4+0140d460] <-- FAULT 013ebcf8: 895350 mov [ebx+50], edx 013ebcfb: 8b14ade0d34001 mov edx, [ebp*4+0140d3e0] 013ebd02: 8bac24a8010000 mov ebp, [esp+1a8] 013ebd09: 895354 mov [ebx+54], edx 013ebd0c: 8b94248c010000 mov edx, [esp+18c] 013ebd13: f7c200000300 test edx, 00030000 013ebd19: c7436800000000 mov dword ptr [ebx+68], 00000000 013ebd20: 7546 jnz 013ebd68 013ebd22: 8b7304 mov esi, [ebx+04] 013ebd25: 8d5601 lea edx, [esi+01] 013ebd28: 83fe00 cmp esi, 00 013ebd2b: 0f4cf2 cmovl esi, edx 013ebd2e: 83e6fe and esi, fe 013ebd31: 8b13 mov edx, [ebx] 013ebd33: 897304 mov [ebx+04], esi 013ebd36: 8d7a01 lea edi, [edx+01] 013ebd39: 83fa00 cmp edx, 00 013ebd3c: 0f4cd7 cmovl edx, edi 013ebd3f: 83e2fe and edx, fe 013ebd42: 8b730c mov esi, [ebx+0c] 013ebd45: 8913 mov [ebx], edx 013ebd47: 8d5601 lea edx, [esi+01] 013ebd4a: 83fe00 cmp esi, 00 013ebd4d: 0f4cf2 cmovl esi, edx 013ebd50: 83e6fe and esi, fe 013ebd53: 89730c mov [ebx+0c], esi 013ebd56: 8b7308 mov esi, [ebx+08] 013ebd59: 8d5601 lea edx, [esi+01] 013ebd5c: 83fe00 cmp esi, 00 013ebd5f: 0f db 0f Windows 5.1 (WinXP build 2600) [Service Pack 1] EAX = 00000000 EBX = 0400edf8 ECX = 00000000 EDX = 00000000 EBP = 30347039 DS:ESI = 0023:033b0090 ES:EDI = 0023:00000000 SS:ESP = 0023:0400ec08 CS:EIP = 001b:013ebcf1 FS = 003b GS = 0000 EFLAGS = 00010202 MM0 = 0000000000000012 MM1 = 000000000000000c MM2 = 9d9d9d9d9d9d9d9d MM3 = 0000000000000000 MM4 = 0000000000000000 MM5 = 0000000000000078 MM6 = 000000000000007b MM7 = 00000000000001fa Crash reason: Access Violation Thread 00000b68 (Main thread) T:\projects\VirtualDub_old\main\Init.cpp(219) T:\projects\VirtualDub_old\main\Init.cpp(238) T:\projects\VirtualDub_old\main\Init.cpp(256) T:\projects\VirtualDub_old\main\Init.cpp(318) T:\projects\VirtualDub_old\main\Main.cpp(182) T:\projects\VirtualDub_old\main\Main.cpp(205) T:\projects\VirtualDub_old\main\VideoSource.cpp(566) T:\projects\VirtualDub_old\main\FilterSystem.cpp(126) T:\projects\VirtualDub_old\main\FilterSystem.cpp(128) T:\projects\VirtualDub_old\main\FilterSystem.cpp(126) T:\projects\VirtualDub_old\main\FilterSystem.cpp(128) T:\projects\VirtualDub_old\main\FilterSystem.cpp(126) T:\projects\VirtualDub_old\main\FilterSystem.cpp(128) T:\projects\VirtualDub_old\main\FilterSystem.cpp(411) T:\projects\VirtualDub_old\main\FilterSystem.cpp(427) Thread 00000b98 (FastWriteStream) Thread 00000b9c (Processing) T:\projects\VirtualDub_old\main\VideoSource.cpp(1455) T:\projects\VirtualDub_old\main\VideoSource.cpp(1483) T:\projects\VirtualDub_old\main\Dub.cpp(2840) T:\projects\VirtualDub_old\main\FilterSystem.cpp(515) T:\projects\VirtualDub_old\main\FilterSystem.cpp(526) T:\projects\VirtualDub_old\main\VideoSequenceCompressor.cpp(358) T:\projects\VirtualDub_old\main\VideoSequenceCompressor.cpp(371) T:\projects\VirtualDub_old\main\Dub.cpp(3022) T:\projects\VirtualDub_old\main\Dub.cpp(3220) T:\projects\VirtualDub_old\main\Dub.cpp(2835) T:\projects\VirtualDub_old\main\VideoSource.cpp(1455) T:\projects\VirtualDub_old\main\VideoSource.cpp(1483) T:\projects\VirtualDub_old\main\Dub.cpp(2840) T:\projects\VirtualDub_old\main\FilterSystem.cpp(515) T:\projects\VirtualDub_old\main\FilterSystem.cpp(526) T:\projects\VirtualDub_old\main\VideoSequenceCompressor.cpp(358) Thread 00000ba0 (I/O processing) 013ebcf1: xvid!xvid_init [013a0000+a0b4+41c3d] 77f46e44: ntdll!RtlTimeFieldsToTime [77f40000+64ff+945] 77f50d06: ntdll!RtlUnwind [77f40000+10c44+c2] 77f6591f: ntdll!NtContinue [77f40000+25913+c] 77f50d2f: ntdll!RtlUnwind [77f40000+10c44+eb] 77f41ef9: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+2fb] 77f41ec8: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+2ca] 77f417b2: ntdll!RtlAllocateHeap [77f40000+16a1+111] 013f9d0f: xvid!xvid_init [013a0000+a0b4+4fc5b] 013f9c06: xvid!xvid_init [013a0000+a0b4+4fb52] 013eb6e6: xvid!xvid_init [013a0000+a0b4+41632] 77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff] 013f9b96: xvid!xvid_init [013a0000+a0b4+4fae2] 013cea8e: xvid!xvid_init [013a0000+a0b4+249da] 013cebec: xvid!xvid_init [013a0000+a0b4+24b38] 013cea8e: xvid!xvid_init [013a0000+a0b4+249da] 013bc600: xvid!xvid_init [013a0000+a0b4+1254c] 013b9b90: xvid!xvid_init [013a0000+a0b4+fadc] 77e748b0: kernel32!SetThreadExecutionState [77e40000+34772+13e] 013bb3b4: xvid!xvid_init [013a0000+a0b4+11300] 013bb3ef: xvid!xvid_init [013a0000+a0b4+1133b] 77e748b0: kernel32!SetThreadExecutionState [77e40000+34772+13e] 77e7487d: kernel32!SetThreadExecutionState [77e40000+34772+10b] 77f69ba4: ntdll!RtlConvertUlongToLargeInteger [77f40000+29b3d+67] 77f69b78: ntdll!RtlConvertUlongToLargeInteger [77f40000+29b3d+3b] 77f50bf4: ntdll!CsrCaptureMessageString [77f40000+10a8b+169] 77fa4dbd: ntdll!KiUserExceptionDispatcher [77f40000+64daf+e] 77e53887: kernel32!RaiseException [77e40000+13837+50] 77f607af: ntdll!_vsnprintf [77f40000+20782+2d] 77f60909: ntdll!_vsnprintf [77f40000+20782+187] 77f608ce: ntdll!_vsnprintf [77f40000+20782+14c] 77f4b4ab: ntdll!vDbgPrintExWithPrefix [77f40000+b474+37] 77e53887: kernel32!RaiseException [77e40000+13837+50] 013e96bc: xvid!xvid_init [013a0000+a0b4+3f608] 013f2f27: xvid!xvid_init [013a0000+a0b4+48e73] 013f27fb: xvid!xvid_init [013a0000+a0b4+48747] 013bc9fc: xvid!xvid_init [013a0000+a0b4+12948] 013b846e: xvid!xvid_init [013a0000+a0b4+e3ba] 77d1a657: USER32!wvsprintfA [77d10000+a4fc+15b] 77d1a564: USER32!wvsprintfA [77d10000+a4fc+68] 77e749fd: kernel32!OutputDebugStringA [77e40000+349b7+46] 013a2619: xvid!00002619 013aa09f: xvid!xvid_encore [013a0000+a05c+43] 013a543f: xvid!0000543f 013a9d44: xvid!DriverProc [013a0000+9ac4+280] 0473928e: DVD2AVI!0000928e 04736254: DVD2AVI!00006254 04733311: DVD2AVI!00003311 0473a986: DVD2AVI!vfGetPluginFunc [04730000+9a30+f56] 0043e31e: cc_row() 0043eda9: Resampler::_DoRow() 0043f4a4: Resampler::Process() 00436ce3: resize_run() 73b2181d: MSVFW32!ICSendMessage [73b20000+17f4+29] 73b24789: MSVFW32!ICCompress [73b20000+4728+61] 00471da1: VideoSequenceCompressor: ackFrame()0046b3ff: Dubber::WriteVideoFrame() 77e5a652: kernel32!WaitForSingleObjectEx [77e40000+1a5a2+b0] 77e5ac21: kernel32!WaitForSingleObject [77e40000+1ac12+f] 0046bebf: Dubber::ProcessingThread() 0046bd86: Dubber::ProcessingThreadKickstart() 0048419c: _threadstart@4() 77e5d33b: kernel32!RegisterWaitForInputIdle [77e40000+1d2f8+43] -- End of report |
#14 | Link |
sirber:
which CPU are you running it on? Tommy Carrot: if you don't like a feature, just switch it off, but don't whine around that you don't like it! The dyn hpel/qpel decision is giving performance improvement on "mixed" material. all: hell, what a bitching & whining around the last two days. You wanted developer binaries, you got warned that there is some experimental code in which can break _everything_, you know about the risks, but you complain? Come on, sit back, relax, and think about it again. I'd be lucky not to provide developer binaries and safe some work with "unnecessary" work like reminding you about the readme's, documentation, development status,... Thanks for respecting that. Best regards Koepi
#15 | Link |
You're Q-pel checkbox isn't working. Only the dynamic one. Frankly, I didn't even see where the dynamic flag was in the api. I just assumed the dynamic decision was built in q-pel now. I still don't see where the dynamic decision flag is.
#16 | Link |
TheXung:
maybe my local source tree has different code than CVS? E.g., check the "About" box. I've got some code from sysKin directly to check it out. Koepi
#17 | Link |
Anime-otaku
Yes, it is quite important that there are someone out there who are making binaries available of the latest and greatest in the CVS tree. Not all of us have either the money to buy a compiler, or the will to download a pirate version of MSVC. Of course, there is ICL, but that's only usable for 30 days, right?
I'd help out testing, if it wasn't for my slow-a** 600MHz/128MB RAM computer with way too little HDD space free (the latter is the biggest problem). It would be really nice if there was such a thing as an MPEG-4 validator in existance, but I guess that that is only going to happen if someone sits down and codes it. Quite "unsexy" work, and noone wants to do "unsexy" stuff, right?
We're all connected - Serial Experiments Lain |
#18 | Link |
We're trying to validate our code every now-and-then with reference ISO impementations, thus we have a kind of a spec-validator (if it doesn't decode it's not spec compliant, quite easy
).But it can happen that some code snapshot isn't spec compliant, which get's "repaired" ASAP. That's what I mean with "don't whine around" - it'll get fixed for sure. Then on the other hand, writing "xvid-09122002-1 seems not to be mpeg4 compliant" (and just as a note, not with anything attached to it) is quite useful for us indeed. Regards Koepi
#20 | Link |
@Koepi
I have a AMD Athlon TBird 1.333 Ghz, with 512 PC-133 SDRAM, on a ECS K7S5A. I wrote to VDub about this because I have no problem with DVD2AVI, so I don't think it's a XviD problem. XviD stable release works #1. |
| Thread Tools | |
| Display Modes | |
