7th December 2002, 17:10 | #1 | Link |
Is there an MPEG2DEC YV12 that actually works?
I've discovered that MarcFD's mpeg2dec3 (YV12 capable) delivers bad frames. This causes DecombYV12 to fail as it does not always receive correct fields to match. The same VOB works perfectly with the standard mpeg2dec.
Since it seems that mpeg2dec3 has become an orphan, I am wondering if there is either a working YV12-capable mpeg2dec, or any other reliable YV12-capable decoder. Without a reliable YV12 decoder available, I will not release DecombYV12, because it will be unfairly blamed. I will be happy to make available the proof of the mpeg2dec3 failure if anyone cares to see it. Finally, since MarcFD's site is down, does anyone have the source for mpeg2dec3? Thank you. Last edited by Guest; 7th December 2002 at 17:24. |
7th December 2002, 17:23 | #3 | Link |
They are progressive source frames that get delivered with one field wrong (displaced downward). I don't know how the RFF/TFFs are set for it in the VOB. It may be that the 3:2 pulldown is not being done correctly (DVD2AVI non-Force Film).
7th December 2002, 17:48 | #4 | Link | |
Still Laughing
Re: Is there an MPEG2DEC YV12 that actually works?
7th December 2002, 18:14 | #5 | Link |
@neuron2
Are you sure you have the newest version? Because I had problems with it too and now they have gone away. Did anyone else have trouble stepping backwards through the video before? Once I installed MPEG2DEC3 v0.93, it worked fine. Does anyone know what was causing that problem? Anyway, now would be a really great time for Marc to release the source code. He has done a good job of finding the initial bugs, but no one person can find all of them. And even if there is no bug, it might help us to know what it is doing. Stephen |
7th December 2002, 19:30 | #8 | Link |
XviD fan
don, don't get mad ^^
1) i rewrote all the YV12 part to make it work correctly, but it's brand new (in v0.93) i can correct your bug in less than 10 minutes, just explain it. 2) i released the source 3 weeks ago, so please int21h, don't say such things thx. just ^__________^ marc |
7th December 2002, 19:48 | #9 | Link |
Hi Marc,
Thank you. I'd appreciate it if you could have a look at the problem. The version of mpeg2dec3 I used is 0.93. First get this VOB: http://shelob.mordor.net/dgraft/bitch.vob Then decode it with standard mpeg2dec (and Avisynth 2.06) and mpeg2dec3 and compare frame 2 from each. For me, mpeg2dec presents it correctly, and mpeg2dec3 mangles it. Following are my scripts: mpeg2dec: LoadPlugin("..\..\mpeg2dec.dll") mpeg2source("bitch.d2v") mpeg2dec3: LoadPlugin("..\..\mpeg2dec3.dll") mpeg2source("bitch.d2v") Regarding source: with your web page down, the fact that you released it is...less than satisfying. (Don't blame me for the clip; I got it from manono! I did choose the name though. Anyway, it's just Cowboy Bebop.) regards, Don Last edited by Guest; 7th December 2002 at 19:57. |
7th December 2002, 19:57 | #11 | Link |
XviD fan
hmm don, 10 Mb for my 56k ?? maybe too much.
just explain the problem, i'm 90% sure i can reproduce it with my own vobs. BTW, when i rewrote the YV12 stuff i compared with MPEG2Dec to see if the options worked well, but it's very probable that there's something i ommited. what's your problem ? swapped fields ? EDIT : if i can't reproduce it i'll of course dl your vob, but i prefer to do that in last. i hope you understand. Last edited by Marc FD; 7th December 2002 at 19:59. |
7th December 2002, 20:20 | #16 | Link |
XviD fan
3:2 pulldown.. you used "force-film" ?? that'ld explain everything (because a lot of code for force-film is changed, btw my mmx transferts should speed up pulldown ^^)
i think i'll dl you vob and do it seriously tonight. i've just 2-3 things to finish in speed ^__^ |
7th December 2002, 20:24 | #17 | Link |
Marc,
Please read the thread carefully. I used non-Force Film. When you do non-Force Film, the decoder has to obey the RFF/TFF flags and output the necessary pulled-down fields. That is my understanding. Am I wrong? In any case, the output from the two is clearly different. |
