#1 | Link |
clueless n00b
![]() Join Date: Oct 2001
DivX5 Adware summary & DivX5 Pro Cracked
We all don't like adware so here's the definitive summary how to get rid of it.
This also means we will not tolerate any more discussion about adware on this board as it is intended for video encoding related discussion and not corporate policy and spyware. Furthermore, everybody should use the official gain installer and not a cracked version First of all the crack is reported to cause severe problems resulting in completely screwed up video and 2nd it is warez and warez talk is not permitted on this board anyways. Now here we go: 1) Installation: Make sure you're running a personal firewall or are not connected to the Internet when you install. Good free personal firewalls are available at http://www.zonealarm.com (ZoneAlarm) and http://www.tinysoftware.com (Tiny Personal Firewall). If you're using a firewall you'll see a new program trying to connect to the Internet after the installation. Block it and create a rule that will forever block it. 2) Post installation: After the installation run msconfig, go to the startup options and deactivate gain_trickler_xxxx or CMEsys, then reboot. If you have no msconfig on your machine then run regedit and remove the following keys: HKEY_LOCAL_MACHINE\software\gator.com\ HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\stashedgef HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\stashedgmg HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\trickler Then reboot. Now you can also delete c:\program files\DivX\DivX Pro Codec\gain_trickler_3102.exe That concludes the removal. The following registry key must exist or you can no longer use the codec: HKEY_CLASSES_ROOT\clsid\{21ffb6c0-0da1-11d5-a9d5-00500413153c}\ Alternatively you can use AdAware (http://www.lavasoft.de) which will locate the new registry keys and programs and offer to remove them. Make sure you don't remove the Gator key:HKEY_CLASSES_ROOT\clsid\{21ffb6c0-0da1-11d5-a9d5-00500413153c}\ or the codec will no longer work. That's it folks. One lousy registry keys is all there is to it. If you use tools to protect your privacy in the first place you have nothing to fear and will never get to see a single banner or have a single byte of information about you transmitted anywhere.
| Thread Tools | |
| Display Modes | |
