Old 22nd September 2005, 14:24   #141  |  Link
leowai
Originally Posted by bob0r
Now for .mp4, does x264 need to change code, or does gpac need to change code?
Originally Posted by Sirber
@Haali
Problem fixed for MKV. Many thanks!!!!!!
Produced MKV is 100% valid.
From my point of view, since x264 raw-> mp4 works using MP4Box, it's more to the bug in porting x264 with gpac's mp4 output support.
Correct me if I'm wrong. Thanks.
Just curious about this: What's the different between x264 encoder and MP4Box when creating a *.mp4 output? If they are same (using same function), does it means that's the problem in x264 using gpac's mp4 output function?
leowai is offline   Reply With Quote
Old 22nd September 2005, 14:36   #142  |  Link
Sirber
retired developer
Sirber's Avatar
For (x264 raw-> mp4), you need to know the FPS, which cound have been altered by user avisynth script, and bork the result MP4. It's best to have it handeled by x264 directly.
Detritus Software
Sirber is offline   Reply With Quote
Old 22nd September 2005, 16:36   #143  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Hmm yes ofcourse.
psp.avs:
LoadPlugin("i:\cap\_x264\_dgdecode.dll")
LoadPlugin("i:\cap\_x264\_decomb521.dll")
LoadPlugin("i:\cap\_x264\_mpasource.dll")
v=mpeg2Source("i:\cap\_x264\cap.d2v")
a=mpasource("i:\cap\_x264\cap.mpa")
audiodub(v,a)
fielddeinterlace()
crop(4,2,712,574)
LanczosResize(368,208)
ChangeFPS(29.97)
psp.bat:
start /belownormal /b /w x264 --progress --pass 1 --me dia --ref 1 --subme 1 --analyse none --output NUL psp.avs
start /belownormal /b /w x264 --progress --pass 2 --bitrate 512 --ref 1 --subme 6 --analyse all --output video.264 psp.avs
start /belownormal /b /w MP4Box.exe -fps 29.97 -add video.264 output.mp4
start /belownormal /b /w MP4Box.exe -fps 29.97 -add audio.aac output.mp4
start /belownormal /b /w ATOMChanger.exe output.mp4 MAQ00264.MP4 AtomAVC.ini
I'll try setting the FPS in the x264.exe line too; --fps <float|rational> Specify framerate
--fps 29.97, and then maybe it "fixes" the .mp4 file, ill try
Note the _detected_ fps here:
avis [info]: 368x208 @ 29.97 fps (9539 frames)
If i remove ChangeFPS(29.97) from the .avs and --fps 29.97 via x264.exe, will x264 then convert the 25FPS PAL to 29.97?
bob0r is offline   Reply With Quote
Old 22nd September 2005, 17:03   #144  |  Link
movax
Member
I think both will certainly convert the framerate, but the telecining/assorted processes that have been done to the PAL video can't be easily fixed by a simple framerate change. (e.g., a 24fps source to 25fps PAL is just speeded up, this is common, but then converting that to 29,97 would be akin to telecining 24fps video, I'm kind of sure.)
movax is offline   Reply With Quote
Old 22nd September 2005, 17:18   #145  |  Link
bob0r
Pain and suffering
bob0r's Avatar
@movax
Ah yes, well the videos are for Sony PSP, and they work fine with MP4Box, its purely about a working .mp4 now, converting the right way may come later (unless it influences the .mp4 output)
I see i have made a small mistake; avis [info]: 368x208 @ 25.00 fps (7957 frames) is just how many FPS the .avs file is outputting.
I am now trying --fps via x264.exe and ill send the files to my friend to test on his PSP.
avs change 29.97 FPS > .mp4 PSP does not work
avs change 29.97 FPS + x264.exe --fps 29.97 = Needs to be tested
avs 25 FPS (original source) + x264.exe --fps 29.97 = Needs to be tested
... will let you know. (If all fails on PSP, ill remux the audio/video with MP4Box)
Edit:
It seems x264.exe --fps 29.97 does NOT change the video fps, i wonder what it does do
Or is it the same as MP4box, just to set the .mp4 FPS?
In that case, .avs changefps 29.97 + x264.exe .mp4 output --fps 29.97, should create a valid file?
Old 22nd September 2005, 17:50   #146  |  Link
Sirber
retired developer
Sirber's Avatar
PSP encoding is kinda OT...
Detritus Software
Old 22nd September 2005, 18:18   #147  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Not really, it can be used perfectly for .mp4 output testing.
I just encoded:
.avs ChangeFPS(29.97) and x264.exe --fps 29.97, and indeed the .mp4 output file is fucked, so adding --fps 29.97 is indeed b0rked.
Atomchanger.exe goes besoik on this output.mp4!
Old 3rd December 2005, 17:50   #148  |  Link
bond
seems jeanlf fixed this framerate problem with gpac:
I just fixed 64-bit ts support in isomedia and other parts of GPAC. You should now be able to import with pretty much any kind of timescales and dts - just checked it with a file lasting 4 days with only 31 frames.
can sharktooth or celtic_druid plz make a new compile with latest gpac and anyone who had a crashing sample file test whether it is now fixed?
Ogg Theora | Ogg Vorbis
Old 3rd December 2005, 20:07   #149  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
You can grab my last compile here...
Old 3rd December 2005, 20:14   #150  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
that should fix the problems in x264 too...
EDIT: i've just updated gpac and i get tons of undefined references... and obviously it doesnt compile.
Old 3rd December 2005, 21:15   #151  |  Link
bond
the last cvs before the change compiles fine?
Old 3rd December 2005, 21:16   #152  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yeah.
EDIT: i checked out the CVS in during a series of updates... i will let you know if there are news.
EDIT2: There are syntax errors during the compilation... the results is undefined references...
For example:
commands.c: In function `gf_sg_command_apply':
commands.c:432: error: `SVGElement' undeclared (first use in this function)
commands.c:432: error: (Each undeclared identifier is reported only once
commands.c:432: error: for each function it appears in.)
commands.c:432: error: syntax error before ')' token
commands.c:438: error: syntax error before ')' token
commands.c:457: error: syntax error before ')' token
commands.c:465: error: syntax error before ')' token
commands.c:484: warning: implicit declaration of function `svg_attributes_copy'
commands.c:486: warning: implicit declaration of function `svg_attributes_add'
make[2]: *** [commands.o] Error 1
Old 4th December 2005, 09:12   #153  |  Link
Kurtnoise
Kurtnoise's Avatar
Indeed...nevertheless the static library is built.
http://kurtnoise.free.fr/x264_r381.zip
Old 4th December 2005, 12:06   #154  |  Link
bond
thx kurtnoise
now can anyone reporting problems about this framerate issue check whether its fixed?
Old 4th December 2005, 20:15   #155  |  Link
Sirber
retired developer
Sirber's Avatar
C:\Projets\RealAnimeLE\output\bin>xvid_encraw.exe -i test.avs -o test.m4v -type
2
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
Avisynth input is based on Avs2YUV by Loren Merritt
test.avs: 640x480, 10000000/417083 fps, 573 frames
converting YUY2 -> YV12
    376 Frames encoded - 65.62%
Isn't it AVISynth giving odd FPS numbers?
Detritus Software
Old 5th December 2005, 16:41   #156  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Ok, my 384/384A builds use the latest gpac.
