Old 25th April 2007, 10:31   #221  |  Link
IanB
Avisynth Developer
Someones got a bug in there code. This is typical when one doesn't clamp arithmetic results to 0 at the low end and 255 at the high end.
In 8 bit unsigned arithmetic 0-1=255 (0=black, 255=white)
IanB is offline   Reply With Quote
Old 1st August 2007, 22:00   #222  |  Link
Manao
New version : v2.0a31
Changelog :
    * fixed : mt_hysteresis was randomly crashing.
    * fixed : mt_polish is back.
    * added : round, clip, min, max and = for lut.
    * adapted : to msvc8 / yasm.
Manao is offline   Reply With Quote
Old 1st August 2007, 22:03   #223  |  Link
Manao
Didee : what you asked for isn't possible with a lut, it would require too big a lut.
Dr Khron, foxyshadis : does anybody still have the problem on the edges reported by Dr Khron ? If yes, can I have something to help me reproduce it ?
Old 1st August 2007, 23:06   #224  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
Thanks for the update Manao
Terranigma is offline   Reply With Quote
Old 2nd August 2007, 00:27   #225  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
Manao, was there some sort of speed tweak involved as well? Seems like it, but maybe i'm just off my engines.
Old 2nd August 2007, 20:08   #226  |  Link
Manao
I didn't do anything to make it faster.
Old 5th August 2007, 15:27   #227  |  Link
Manao
New version : v2.0a32
Changelog :
 * added : mt_lutxyz
 * added : mt_lutsx
 * fixed : small memory leak in mt_luts
Basically, mt_lutsx is the filter Didee previously required, and mt_lutxyz is a three clip lut. I changed my position on what "too big" is for a lut. Those filters take some time to initialize ( 3*2^24 values to compute ), something like 5 seconds can be expected. Each instance of those filters takes up 48 MB too.
Old 10th August 2007, 19:19   #228  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Just letting you know there's a typo in the filterlist in the .htm help. 'mt_rectange'
check is offline   Reply With Quote
Old 20th December 2007, 03:18   #229  |  Link
Spuds
dumber every day
Spuds's Avatar
Not so much a bug as an observation or just a plain mistake on my part.
I was using mt_lutf to see if a frame was over / under a very low threshold, something like:
lutf(mask,mask,mode="avg",expr="x 0.1 > y 0 ?")
and comparing the results to:
ConditionalFilter(mask, nullclp, mask, "AverageLuma()", "<", string(0.1),false)
I was getting different results on what frames got through and realized the mt_lutf was doing the comparison not on the float but on the rounded value of average. I know the final result is a round but expected the float to be maintained through the comparison.
Also found that the averageluma approach was about 30% faster.
Spuds is offline   Reply With Quote
Old 20th December 2007, 03:41   #230  |  Link
Didée
Interesting finding on the rounding thing.
The speed difference probably isn't surprising: averageluma operates on just one single clip. LutF/LutS always operate on two input clips, could be this makes the internal pixel shuffling a bit slower.
Old 20th December 2007, 06:58   #231  |  Link
Manao
LutF/S are completely unoptimized, so it doesn't suprises me if they are slow.
As for the rounding, I'll add that to the documentation. It makes sense for me, since the average becomes an entry to a LUT, it must be rounded, but I guess that a programmer's POV, not really a user's POV
Old 20th December 2007, 17:16   #232  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
manao, why in your signature the stable version is 2.0a31 and not 2.0a32?
Old 28th February 2008, 10:24   #233  |  Link
yup
using in Avisynth 2.57 planar YUY2
Hi folks!
Can I use MaskTools V.2 in Avisynth 2.57 with planar YUY2?
I can get planar using SSETools.
AVISource("a.avi")#YUY2 source
SeparateFields()
Interleaved2Planar()
MaskTools V.2 function
Planar2Interleaved()
Weave()
This will be work?
yup.
yup is offline   Reply With Quote
Old 28th February 2008, 10:28   #234  |  Link
Boulder
Pig on the wing
Boulder's Avatar
MaskTools requires YV12 input, so you need to convert to YV12 before using any MaskTools functions.
Old 28th February 2008, 10:44   #235  |  Link
yup
Hi Boulder!
This sentence from document.
The filters have a set of common parameters, that mainly concerns what processing to do on each planes. They all work only in YV12 ( though with Avisynth 2.6, support for all planar format will be available ).
We need waiting Avisynth 2.6? I right?
yup.
Old 28th February 2008, 10:47   #236  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I don't know the inner workings of MaskTools, it could (and probably does) mean that the MaskTools code needs some rewriting too.
Old 28th February 2008, 10:58   #237  |  Link
Manao
Internally, it supports everything from 4:0:0 to 4:4:4 planar. I'll see what I can do for avs 2.5 and interleave2planar. It already works for avs 2.6.
Old 28th February 2008, 19:56   #238  |  Link
Manao
Done : http://manao4.free.fr/masktools-v2.0a33.zip
Old 29th February 2008, 04:14   #239  |  Link
XBoy
x64
How about x64 support?
XBoy is offline   Reply With Quote
Old 29th February 2008, 04:18   #240  |  Link
Manao
I can quickly make a x64 version with assembly disabled. I don't think that's what you want, but without having a 64bit OS, I won't do anything more.
