Old 29th July 2008, 16:44   #321  |  Link
Wraul
Originally Posted by rrkradio View Post
WRAUL ..... Please update to BETA 3 the OSX version
Here you go.
OS X Binary (Universal) of Beta 3
I haven't had time to test rip a DVD-A with it yet, hope it works without problems anyway.
Wraul is offline   Reply With Quote
Old 29th July 2008, 17:02   #322  |  Link
rrkradio
Originally Posted by Wraul View Post
Here you go.
Hello Wraul, i tried "on the fly" with 2 DVD-A (one with PCM stereo 2ch and another with downmixing enabled) .... PERFECT under OSX 10.5.4
Tnx again
rrkradio is offline   Reply With Quote
Old 31st July 2008, 22:24   #323  |  Link
Pumpa
Suggestion for beta4 ?
a) Possible to get one wave file for all selected tracks (good for whole album in one file)
b) Generate CUEsheet for "split" tracks in one file
a) is high important for me, b) not
Pumpa is offline   Reply With Quote
Old 1st August 2008, 06:21   #324  |  Link
gfxnow
That's quite barbaric
gfxnow is offline   Reply With Quote
Old 1st August 2008, 07:52   #325  |  Link
Pumpa
I did not found application for proper joining WAV files with WAVE_FORMAT_EXTENSIBLE. Foobar2000 makes standard wavs...
Anyone could help ?
Old 2nd August 2008, 18:01   #326  |  Link
73ChargerFan
73ChargerFan's Avatar
Me neither...
Try opening 2 files in separate Audacity sessions, then copy/paste one channel at time, then save.
73ChargerFan is offline   Reply With Quote
Old 2nd August 2008, 18:34   #327  |  Link
73ChargerFan
eac3to source1.wav+source2.wav result.wav
http://forum.doom9.org/showthread.ph...27#post1133627
Old 4th August 2008, 19:19   #328  |  Link
Pumpa
eac3to result:
WAV, 5.1 channels, 0:04:23, 24 bits, 88.2khz
Source file joining currently doesn't work for WAV files.
Old 5th August 2008, 00:31   #329  |  Link
audio_cf
Are there any stand alone DVD-A players that doesn't check for the water mark?
Are there any firmware modified players that doesn't look for the water mark ?
I would like to play my backupss in a player that can send the audio over HDMI.
audio_cf is offline   Reply With Quote
Old 5th August 2008, 14:49   #330  |  Link
rrkradio
Hello audio_cf,
look at this thread
http://forum.doom9.org/showpost.php?...0&postcount=50
roby
Old 15th August 2008, 17:31   #331  |  Link
mommyman
This is my last post here. I quit DVDAE project. Thanks for everyone who participated.
mommyman is offline   Reply With Quote
Old 15th August 2008, 20:11   #332  |  Link
ron spencer
DVD Magistrate
sorry you are leaving......
ron spencer is offline   Reply With Quote
Old 16th August 2008, 17:51   #333  |  Link
73ChargerFan
same here, best wishes mommyman
Old 17th August 2008, 21:36   #334  |  Link
jolson
Yes, many thanks
jolson is offline   Reply With Quote
Old 17th August 2008, 23:14   #335  |  Link
gfxnow
I wish you best of luck in all your future endeavors mommyman. You've been an invaluable resource to the DVD-A community.
Old 23rd August 2008, 21:19   #336  |  Link
tteich
Thanks mommyman! Best wished for your future projects.
tteich is offline   Reply With Quote
Old 24th August 2008, 01:46   #337  |  Link
nevragain
I wish you the best of luck mommyman.
nevragain is offline   Reply With Quote
Old 24th August 2008, 12:08   #338  |  Link
DragonQ
Hi guys I have a problem related to this program. When I chose to make downmixes it saved them as 24-Bit 96kHz Stereo WAV files that play fine in all media players. However, when I open them in Adobe Audition 3.0 (to make some edits etc.) and save them as "Microsoft PCM WAV" (24-Bit, 96kHz, Stereo), they do not play in any of my media players. The file appears to be playing but there is no sound. The only differences I can see in the file attributes are that there is a new "Audio Format" attribute whose value is "PCM" - this attribute does not exist on the original (working) files. However, if I save the file as a "32-Bit float" Microsoft PCM WAV in Audition, they play fine! Here is an image to explain:
http://www.aotplaza.com/Files/Audio Problem.PNG
I don't think that WAV requires any codecs so it can't be a codec problem, right? Any ideas?
Old 24th August 2008, 20:48   #339  |  Link
DragonQ
Yeah I was pretty sure it was a problem with Audition but thought that someone who knew more about how DVD-A Explorer saved its WAV files might be able to help me. I fixed the problem by setting ffdshow to handle all WAV files. According to some websites I have visited, high resolution and/or surround sound WAV files can only be played back natively if they are in WAVE EXTENSIBLE format and the files I was saving were in PCM format, which cannot be played back natively (due to Microsoft not implementing backwards compatibility properly, sigh). Thanks anyway .
Old 25th August 2008, 15:05   #340  |  Link
rrkradio
Tnx for your beautiful soft
