#306 | Link |
One big thanks to all that have worked on this tool. Simply awesome. Kudos to all of you that are much smarter and have more patience than I to code programs.
However, on my Mac, I am having a problem using beta2. It recognizes the .exe file as a text file. I cannot get it to run as an executable in the mac os. I used it in my windows bootcamp partition with no problems and it worked great. All of my DVD-A's are now as wav files on my HD so that I can use my computer as the media source. If you could repost the beta 2 or maybe try and recompile it, I will test it for functionality on my mac. Like I said, beta 1 works as an executable, beta 2, not so much... Or is it possibly I am doing something incorrectly? Thanks again and I look forward to trying the ripping process on the mac side (although all of my Current DVD-A's are already done) I would like to still be able to do so on the mac side. Cheers Chris |
#307 | Link | |
You could run beta 1 in OS X because: 1. mommyman provided the source code for the application. 2. mommyman used the Qt framework when developing the program, this makes the program sort of platform independent. 3. I used the source provided by mommyman and compiled it into a OS X application. Now to the good news. mommyman released the source code for beta 2 too. This made it possible to compile a version for OS X which you can download here OS X Binary (Universal) of Beta 2 Now you can continue to happily rip your DVD-A in OS X. |
#308 | Link |
Ok, so now the program ran, but...
Hey there,
OK, so I got the program to run on the Mac side, however I am getting an "Encrypted Stream" error message when I try and extract the same disc that worked just fine on the PC side. Just thought that I would give a heads up on that issue. Any thoughts? Thanks again for all the hard work Chris |
#312 | Link | |||
No, though PS3 probably provides the best platform so far for this.
There's a guide about how to make DSD Disc at http://www.ps3sacd.com/dsddiscguide.html Quote:
Carrying a little further and probably more interesting (because the PS3's UI doesn’t support it) is the idea of playing DVD-Audio discs on PS3 under Linux. It's discussed in here. The idea is that DVD-Audio is basically just a DVD-ROM (which PS3 can read) with some specific audio files (such as multichannel, high-resolution PCM, which the PS3 can decode) so if someone were to port a DVD-Audio player like DVDAE to Linux for PS3 it might make a yet greater multi-format player. Sounds like an interesting idea? |
#314 | Link |
Beta 3: http://www.sendspace.com/file/4muyhm
Changes: 1. Build with the "official" mlpdec.c module (revision 14206). 2. User manual added. |
#318 | Link |
Hello!
First off, thanks so much to Mommyman and anyone else who's worked on this project - it great to be able to back up my DVD-A discs. Had a question, though - I've got one DVD-A - Naxos 5.110102-03 - Bach's Mass in B minor conducted by Helmut Muller-Bruhl, that when I attempt to convert on particular track (Disc 2, Track 4) of the MLP disc data data to WAV, it crashes DVDAExplorer - access violation. Also, if I just grab the MLP directly off the disc (which works) and attempt to play it through the TrueHD/MLP decoder plugin for WinAmp, it doesn't play there either. However, the disc plays just fine through my 2 DVD-A disc players. If I turn on logging in DVDAExplorer when attempting to convert to WAV, I see this: [32] ### MLP Stream (channels: 6, sample_rate: 96000, bits_per_sample: 24) ### [24] Stream parameters not seen; skipping frame. There are lots of lines like the second one, then the app crashes with an access violation. Can I provide more information about this error somehow for debugging purposes? Thanks! |
#319 | Link |
Here you go.
OS X Binary (Universal) of Beta 3 I haven't had time to test rip a DVD-A with it yet, hope it works without problems anyway. |
#320 | Link | |
Tnx again |
