Old 28th April 2008, 01:19   #261  |  Link
bertox
bertox's Avatar
mommyman:
Please upload both files to Mediafire or Rapidshare...
....SendSpace don't works!!!!! He allways ever says: 'Sorry, the free service is at full capacity.'
Please, thank you.
bertox is offline   Reply With Quote
Old 28th April 2008, 07:50   #262  |  Link
mommyman
SendSpace seems to be ok by now. Maybe, that was temporarily.
DragonQ
Downmixes are so silent because they were produced in that way. The default downmix Lf/Rf coefficients for SurCode MLP Encoder are -6dB. This is the point, probably...
mommyman is offline   Reply With Quote
Old 29th April 2008, 04:32   #263  |  Link
bertox
bertox's Avatar
Days and days without work....this is not temporal...
Please...
Old 29th April 2008, 06:24   #264  |  Link
mommyman
DVDAE: http://rapidshare.com/files/11119225...04.16.zip.html
Winamp MLP/TrueHD Decoder: http://www.winamp.com/plugins/search/?q=TrueHD
Норе these sites will be ok...
Old 29th April 2008, 09:51   #265  |  Link
bertox
bertox's Avatar
Yeeeaaahhh!!!!
Old 1st May 2008, 18:33   #266  |  Link
Hancoque
@mommyman: I've studied the MLP documentation a bit and now see that a 6 channel stream might also provide dedicated information for a stereo downmix. I wasn't aware of that before. Does DVD-Audio Explorer fully adhere to that specification? And would it be possible to show the downmix coefficients in the program or at least if default or custom settings have been used?
Edit: I just tested the downmix feature with the seven DVD-Audio discs I own. Only two of them featured a downmix substream and one of them had audible artefacts in the downmix (crackling noise).
Hancoque is offline   Reply With Quote
Old 2nd May 2008, 14:09   #267  |  Link
DragonQ
Crackling in the downmix is usually due to clipping. I also wonder if there's a way to see if there's an included downmix coefficient table on the disc, or even to customise the table manually within the table - that would be a great feature for Beta 2 (hint hint :P)!
The other problem with downmixes is some tracks might have out-of-phase elements (usually vocals) but there's nothing you can do about that. On the DVD-A I ripped there's about 3 of 26 tracks that feature a noticable out of phase vocal.
Old 2nd May 2008, 14:33   #268  |  Link
Hancoque
It's not related to clipping as the highest peak of the affected tracks doesn't even reach 60%. The crackling noise only appears at the beginning and end of these tracks (3 out of 14). On one track it vanishes exactly when the drums start playing. Might it be that some channels start later than others and therefore have no information (random data) until a certain point in time?
Old 2nd May 2008, 15:12   #269  |  Link
DragonQ
Unlikely...it might just be a bad rip. Have you tried ripping it to 5.1 and trying your own downmixes or just listening to each of the channels around the point where there is crackling to see if it exists on the main 5.1 mix?
Old 2nd May 2008, 15:18   #270  |  Link
Hancoque
I have also done a full 5.1 rip. It doesn't show those problems. So, it's definitely related to the downmixing process of DVD-A Explorer.
Old 2nd May 2008, 23:08   #271  |  Link
DragonQ
Can you open one of the the downmixed files in Adobe Audition or Audacity or something similar and post a screenshot?
Old 3rd May 2008, 01:22   #272  |  Link
Hancoque
Old 3rd May 2008, 01:41   #273  |  Link
DragonQ
Hmm. That is very strange, it must be a bug in the program's downmixing code. Hopefully the guy who wrote it will try to help you.
Old 3rd May 2008, 14:43   #274  |  Link
Wraul
First I want to thank mommyman for the continued development of this wonderful application. The additions has made the process to rip my DVD-A discs so much more enjoyable.
I was also very happy to see that the source code was included.
This enabled me to compile a version for Mac OS X.
The Beta 1 binary can be found here (Mac OS X Universal) http://www.sendspace.com/file/r9520u
I never worked with Qt before and have very little experience with Mac development. Hopefully I've done everything correct. The files I've tested produced identical result as the windows version.
Wraul is offline   Reply With Quote
Old 4th May 2008, 10:23   #275  |  Link
mommyman
Amazingly, surcode encoder gives the same crackling sound in downmixed output) Some of the tracks are a bit shorter when decoded by surcode, but don't differ (except length) from their DVDAE partners. Still haven't found an explatation of these facts. Seems that problem must be in mlp track itself...
Old 4th May 2008, 14:32   #276  |  Link
frenchglen
I'm not a mac user (at the moment) so cannot test it, but I'm very very happy to see this compiled, thank you! and welcome to doom9!
"DVD-Audio, say Hi to FLAC"...Now possible on Mac.
frenchglen is offline   Reply With Quote
Old 4th May 2008, 16:35   #277  |  Link
DragonQ
I converted the stereo downmix to WMA Lossless for storage but I've kept the 5.1 mixes in WAV so I can make remixes from them .
Old 5th May 2008, 12:11   #278  |  Link
mommyman
I've been playing a bit with matrixing stage of mlp decoder and can say that the answer is rather negative.
Old 5th May 2008, 23:24   #279  |  Link
borndevil
thank you, thank you, thank you!
it worked perfectly on leopard, and many many thanks to all those will contribute to this awesome project!
borndevil is offline   Reply With Quote
Old 6th May 2008, 14:37   #280  |  Link
Wraul
I know what a pain in the but it can be with these kind of specialist programs only being writen for windows. It is so boring to reboot into Windows every time you want to rip a DVD-A (Well ok it dosen't happen that often with the minimal number of DVD-A releases). Anyway when I saw that the source was released I thought I should make my part and make DVD-A one of the few exceptions.
I just wish I could run EAC in OS X and I no more reboots to Windows for me.
Glad someone more than me appreciate to run DVD-A native in OS X.
You should direct most of your thanks towards mommyman that made this possible by open the source and using qt when programing.
