Old 4th January 2009, 14:18   #1941  |  Link
yesgrey
Originally Posted by Kurtnoise13 View Post
it will be included in the next megui release.
yesgrey is offline
Old 4th January 2009, 16:14   #1942  |  Link
Thanks. How so? Always present or only when encoding RAWAVC? I prefer the former because it makes remuxing from MP4 and MKV to transport easy because the AUDs are already there.
Guest is offline
Old 4th January 2009, 16:54   #1943  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
for the moment, it's enabled only for raw avc but I can enable it for all output types. Ok, for you ?
Kurtnoise is offline
Old 4th January 2009, 17:50   #1944  |  Link
Yes, all output types would be fine.
Note that the AUD overhead for a typical movie is less than 1MByte.
Guest is offline
Old 5th January 2009, 09:27   #1945  |  Link
buzzqw
HDConvertToX author
it's in the main branch, not added via a patch...
thanks! good to know
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 5th January 2009, 17:18   #1946  |  Link
pihug12
I don't read all the last pages of this topic but why you don't update MKVMerge to 2.4.1 ?
http://www.bunkus.org/videotools/mkvtoolnix/
Thank you for this great software !
pihug12
pihug12 is offline
Old 5th January 2009, 17:30   #1947  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
... done ...
however, not all updates are necessary...
Sharktooth is offline
Old 6th January 2009, 02:04   #1948  |  Link
swashbuckle
hi guys, im new to megui and have a question...
i'm trying to re-encode an MKV file because my Western Digital HD TV Media Player doesn't support MKV files encoded with Vorbis audio.
however the MKV file i'm trying to re-encode has dual audio tracks. how do I select only the 2nd audio track to be encoded as the 'audio input'? I don't see any option to do so and I can only encode the first track...
swashbuckle is offline
Old 6th January 2009, 02:27   #1949  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
there is no option. you have to extract the tracks using MKVExtract and re-encode them.
however, you will loose quality... you better re-rip your audio tracks from your original media and re-encode using those as sources.
Old 10th January 2009, 10:04   #1950  |  Link
Coryu
I have a problem with the meGUI, use the Windows Vista Ultimate x64 and when I try to upload a video to work with, I always closed meGUI with the typical error "Not Responding" I have to give him a program and not close works.
Does anyone know how can I fix it?
Ah! Sorry for my English, but I am Spanish and I find it a lot.
Coryu is offline
Old 11th January 2009, 05:08   #1951  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
could you give some more details? what you mean when you say "when I try to upload a video to work with" ?
Old 11th January 2009, 12:55   #1952  |  Link
Coryu
When I put the MeGUI and the option Tools - AVS Script Creator, Video Input post a video and do not load, I get the error:
MeGUI stopped working. And I can give Debug or Close Program.
Coryu is offline
Old 11th January 2009, 17:03   #1953  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
have you installed avisynth (2.57 or newer) and updated all the megui packages using the update feature?
Old 11th January 2009, 18:24   #1954  |  Link
Coryu
Thanks, the problem was that he had not updated the avisynth, had 2.0
Thank you very much for helping me with meGUI
One last thing that I can put a post TMPGEnc doubt that I am not working, and seeing that here you have helped me very fast, if I can fix it there. (The problem is that when a mp4 convert avi to the final result, the audio can be heard very badly cut and the video and slow)
Coryu is offline
Old 11th January 2009, 19:24   #1955  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
im sorry i dont use TMPGEnc.
Old 20th January 2009, 20:01   #1956  |  Link
pihug12
Where did you find MKVMerge 2.4.2 ?
Is it an official release ?
pihug12
pihug12 is offline
Old 21st January 2009, 01:16   #1957  |  Link
Chumbo
Chumbo's Avatar
pihug12
Have you ever used a search?
Chumbo
Chumbo is offline
Old 22nd January 2009, 04:10   #1958  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@pihug12: yes it is official. you may want have a look here: http://forum.doom9.org/showthread.php?t=120648
Old 22nd January 2009, 06:10   #1959  |  Link
ricky man
i am wondering if i can install 32bit MeGui on the 64bit Vista or not. Or do i have to get every filter that is 64bit on it.
ricky man is offline
Old 22nd January 2009, 13:28   #1960  |  Link
tomos
use 32-bit. works fine
for me at least :O
tomos is offline
