Old 26th December 2008, 05:57   #1921  |  Link
AkumaX
Not sure if I could post here, but if this is the wrong thread, someone point me to a place
I have 2 problems:
1)
DirectShowSource
XviD encoding sometimes "glitches"
- on a 2 Pass HQ, does 500fps on the 1st pass
- after 2nd pass is done, resulting file size is around 3gb, when it's supposed to be 600mb (my target)
- a "normal" encode is only 200fps on the 1st pass
doesn't happen all the time... but increasing in frequency more and more
2) x264 Encoding
DirectShowSource
1280x720, specifying 5000kbps, 2pass, resulting file size should be 2.5gb for my file
- actual ends up being 200mb
Sigh, why is this happening...
AkumaX is offline
Old 28th December 2008, 14:44   #1922  |  Link
BlackPrince
Shark thx for all the great work!! Keep on going!
And 1 thing at last...
I have done many updates (megui-updater) and after that, i started the AVS Script Creator, = FAILURE
The "MediaInfoWrapper.dll" was crashed and megui restarted! I have deinstalled megui, reninstalled meg =it works, than the update programme started and crashed again!
BlackPrince is offline
Old 28th December 2008, 14:53   #1923  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
you should read the other megui related posts...
Kurtnoise is offline
Old 28th December 2008, 14:55   #1924  |  Link
BlackPrince
now i have my fault :P
Old 28th December 2008, 18:52   #1925  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
you should also thank kurtnoise and the other devs...
im actually not much active.
Sharktooth is offline
Old 28th December 2008, 20:27   #1926  |  Link
Chumbo
Chumbo's Avatar
May I add a couple "wish list" items please?
- Add Select All and Deselect All buttons on Import dialogs
- Allow multiple selections on import dialogs
Thank you.
Chumbo
Chumbo is offline
Old 28th December 2008, 20:35   #1927  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
right click...
Old 28th December 2008, 21:27   #1928  |  Link
Chumbo
Chumbo's Avatar
LOL, how about that? I'll give it a try the next time it pops up.
Chumbo
Chumbo is offline
Old 31st December 2008, 22:28   #1929  |  Link
Drake008@
Say is it possible to code for example the xvid and x264 encoder that it uses NVIDIA Graphics card and/or the normal CPU? I just want to see how fast the GPU can handle encoding.
Drake008@ is offline
Old 2nd January 2009, 02:31   #1930  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it's offtopic and it has already been discussed on the AVC forum
MeGUI is a Graphical User Interface that uses other tools for encoding stuff...
Old 3rd January 2009, 12:28   #1931  |  Link
yesgrey
Why not including the "--aud" option when we select the RAWAVC file format? Some mkv muxing tools only accept h264 raw streams which contains the AUDs.
Yes, I know I can put the option myself, but when we update the profiles they come without that option, and we could start an encoding forgetting to add it again... I could request the adition to the profiles, but I believe the right place should be in megui... What do you think?
yesgrey is offline
Old 3rd January 2009, 14:41   #1932  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
what are those mkv muxing tools?
Old 3rd January 2009, 14:57   #1933  |  Link
I don't know about MKV but transport streams require AUDs by spec. I believe they should be included in all cases, as the overhead is relatively small.
Guest is offline
Old 3rd January 2009, 15:08   #1934  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm, ok.
Old 3rd January 2009, 15:18   #1935  |  Link
From ISO/IEC 13818-1:2000/Amd.3:2004 (E) (Amendment 3: Transport of AVC video data over ITU-T Rec. H.222.0 | ISO/IEC 13818-1streams) paragraph 2.14.1:
Each AVC access unit shall contain an access unit delimiter NAL Unit;
NOTE 2 – ITU-T Rec. H.264 | ISO/IEC 14496-10 requires that an access unit delimiter NAL Unit, if present, is the
first NAL Unit within an AVC access unit. Access unit delimiter NAL Units simplify the ability to detect the
boundary between pictures; they avoid the need to process the content of slice headers, and they are particularly useful for the Baseline and Extended profiles where slice order can be arbitrary.
Guest is offline
Old 3rd January 2009, 16:00   #1936  |  Link
yesgrey
eac3to. It only supports h264 streams with AUDs.
yesgrey is offline
Old 3rd January 2009, 16:05   #1937  |  Link
Kurtnoise
Kurtnoise's Avatar
this is not a switch from mkv tools but an option from the x264 itself (or added in the bitstream afterward for eac3to)...
Old 3rd January 2009, 16:41   #1938  |  Link
yesgrey
Yes, I know (see my quote above), that's why I think it would be a good idea to megui automatically set it when we select RAWAVC file format...
yesgrey is offline
Old 4th January 2009, 13:42   #1939  |  Link
buzzqw
HDConvertToX author
afaik (but i hope to be in error) -aud isn't an official option, but added with a patch
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 4th January 2009, 13:55   #1940  |  Link
Kurtnoise
Kurtnoise's Avatar
it's in the main branch, not added via a patch...
it will be included in the next megui release.
