Old 19th January 2006, 01:09   #1001  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Originally Posted by Doom9
Required tools:
For XviD, lavc, Snow and x264 encoding (alternative to x264 CLI)
latest version of mencoder (it's part of the mplayer package, pick the version that best matches your CPU
does anyone of you ever used one of these Mencoder compiles? For example there is a special precompiled Mencoder binary - XviD 1.1.0 - x264 svn...
I'm going to test it but not tonight
sillKotscha is offline
Old 27th January 2006, 15:36   #1002  |  Link
klicker4546
Build mplayer/mencoder win32
Hello everybody,
Somewhere in the forum I had recently seen a thread with detailed information regarding how to build mplayer/mencoder for win32 with cygwin or mingw. Does anybody know where I can find that specific thread?
klicker4546 is offline
Old 1st March 2006, 21:50   #1003  |  Link
nexus
digitally remastered
nexus's Avatar
I think I found a bug in megui. I stupidly postet in the x264-thread.
May The FourCC Be With You
nexus is offline
Old 23rd March 2006, 18:28   #1004  |  Link
cc979
Curious BetaTester
been thinking about getting back into programming(i did program assembly language mostly 6502 and 68000 long time ago) - i can follow c# code to a degree - but can anybody recommend any c# books (free ebooks or whatever) - and i will try some debugging and that if i can
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT
Tools: ProcessExplorer & ProcessMonitor - BatchCompressor
Guide: MinGW Compiling GCC
cc979 is offline
Old 4th April 2006, 07:57   #1005  |  Link
Infirmus
Infirmus's Avatar
Just wanted to say thanks to the developers of meGUI (esp Doom9) and also the developers of the tools it uses (x264, avisynth, etc).
I used it for the first time a few days ago and I was impressed.
Infirmus is offline
Old 5th April 2006, 20:18   #1006  |  Link
stholt
Troubles...
I am trying to use MeGUI, but I can't seem to get it to work. I have all the tools setup and pointed to properly, I start the program up and set it up to encode 3 pass x264, but it's not working. Here's a copy/paste of the logfile:
Starting job job3-1 at 3:12:14 PM
Job is a video job. encoder commandline:
--pass 1 --bitrate 700 --stats "C:\2004_BIG_O_V_1_8_SCN\VIDEO_TS\bogO1.stats" --subme 1 --analyse none --me dia --threads 2 --thread-input --progress --output NUL "C:\2004_BIG_O_V_1_8_SCN\VIDEO_TS\BigO_1.avs"
successfully started encoding
Processing ended at 3:12:15 PM
Log for job job3-1
unknown option ( )
job job3-1 has been processed. This job is linked to the next job: job3-2
Starting job job3-2 at 3:12:15 PM
--pass 3 --bitrate 700 --stats "C:\2004_BIG_O_V_1_8_SCN\VIDEO_TS\bogO1.stats" --analyse p8x8,b8x8,i4x4 --threads 2 --thread-input --progress --output "C:\2004_BIG_O_V_1_8_SCN\VIDEO_TS\BigO_1.mp4" "C:\2004_BIG_O_V_1_8_SCN\VIDEO_TS\BigO_1.avs"
Log for job job3-2
unknown option ( )
job job3-2 has been processed. This job is linked to the next job: job3-3
Starting job job3-3 at 3:12:15 PM
Processing ended at 3:12:16 PM
Log for job job3-3
unknown option ( )
Anyone know what's going on?
stholt is offline
Old 5th April 2006, 22:14   #1007  |  Link
Doom9
clueless n00b
well.. you really should use the more up-to-date threads.. digging up old stuff is bad etiquette and just clutters up the forum.
My guess is your x264 build doesn't support the
--thread-input
option
Doom9 is offline
Old 5th April 2006, 22:17   #1008  |  Link
chipzoller
Mr. Woof
chipzoller's Avatar
Doom9,
Which thread should we use?
chipzoller is offline
Old 20th May 2006, 08:54   #1009  |  Link
modsoul
i have a question. megui i can't encode using 2 passes when using a quantizer but real anime allows this. is this possible is megui ?
if so please tell me how to do it.
thank you
modsoul is offline
Old 20th May 2006, 08:58   #1010  |  Link
berrinam
berrinam's Avatar
There's not much point in doing a 2pass quantizer encode since there's no bitrate target that needs to be met with a quantizer encode, so x264 will get it right the first time. Anyway, if you are very picky about it, then you can do a first pass with a constant quantizer, get the bitrate of the file from the log, and then do a 2pass encode with that new bitrate, but seriously, why?
berrinam is offline
Old 20th May 2006, 09:05   #1011  |  Link
modsoul
oh sorry. then i thought 2 pass would increase the quality a bit. i encoded a video at a 32 quantizer and the file size can out reall good. but the issue was the video was 640x480 and when i watched it full screen i saw a lot of blockyness. i thought 2 pass would make that better.
will it?
modsoul is offline
Old 20th May 2006, 09:17   #1012  |  Link
berrinam
berrinam's Avatar
will it?
Yes and no. Doing a second pass after a constant quantizer encode will pretty much not add anything, because it won't have a a proper first pass. However, a 2pass encode to the same filesize will look better, because 2pass is simply a better algorithm. You should never really use constant quant, because constant quality mode is better.
Nevertheless, 32 quantizer is always going to be bad. You should experiment with values between 18 and 26.
berrinam is offline
Old 20th May 2006, 09:34   #1013  |  Link
modsoul
i tried 25. but that came out even worse. and when i checked the bitrate (while playing under media player classic) it was 30-40 Kbps.
is that right i thought lower quantizer was better. ?
modsoul is offline
Old 20th May 2006, 09:43   #1014  |  Link
stax76
staxrip & mpv.net
IIRC at crf 20 filesize can get as big as XviD at q3, IMHO a big waste. I'm always using crf 22 which gets 30-40% smaller than 20.
staxrip is in need of a new maintainer since I would like to retire.
stax76 is offline
Old 20th May 2006, 10:02   #1015  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
I think you forgot to switch it back to constant quantizer/quality mode. It sure sounds like bitrate mode was engaged.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
foxyshadis is offline
Old 31st May 2006, 10:30   #1016  |  Link
M.H.A.Q.S.
OK, I waited exactly five days to post... :P. I wanted the MeGUI x264 compile and source code only. All previous links in other threads appear to be dead and I could not find anything. I did take look at x264 GUI but its in VB.NET and does not really serve the purpose.
Can I have a link to MeGUI x264 build part only with source code. I really want to work on it.
M.H.A.Q.S. is offline
Old 31st May 2006, 10:32   #1017  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
MeGUI-x264 was dropped.
please refer to the sticky thread (on top of this board) for MeGUI (full version) bins and sources.
very latest binaries of megui can be found on http://x264.nl in the GUI section.
Sharktooth is offline
Old 31st May 2006, 10:41   #1018  |  Link
M.H.A.Q.S.
hmm, I suspected that. But is there a way I can get an older source and build?
Old 31st May 2006, 10:45   #1019  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i really dont know. i do not mantain older sources but you can ask the other megui devs if they still have archived the latest megui-x264.
Old 31st May 2006, 10:46   #1020  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
via CVS
btw. Why do not use MeGUI full?
dimzon is offline
