Old 22nd December 2005, 09:24   #961  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Would it be possible for any of you put up a mirror somewhere. I haven't been able to download the binaries for more than a day. Very frustrating!
Regards, sh0dan // VoxPod
sh0dan is offline
Old 22nd December 2005, 14:39   #962  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
a mirror is already provided. check this post: http://forum.doom9.org/showthread.ph...913#post754913
Sharktooth is offline
Old 22nd December 2005, 20:56   #963  |  Link
Paul Atreides
nsis 2.12 could be use by Sharktooth to make x264 package
Paul Atreides is offline
Old 23rd December 2005, 05:25   #964  |  Link
charleski
charleski's Avatar
Originally Posted by stax
@amango
The available MPEG-2 cutters "don't seem to cut it"
The vast majority of my encodes are DVB MPEG-2s cut and demuxed with ProjectX or PVAstrumento/cuttermaran. I have no problems with them in meGUI whatsoever.
Introducing editing functions into meGUi would hugely add to the complexity (as you need to maintain sync with the audio) and is completely unessecary as there are other tools that do the job.
charleski is offline
Old 23rd December 2005, 11:42   #965  |  Link
stax76
staxrip & mpv.net
Maybe those apps have improved but compared to the application I use to cut I found those apps much of a pain last time I've tried.
I have a dream by Martin Luther King
one hundred years later...
We can never be satisfied...
With this faith...
Let freedom ring...
stax76 is offline
Old 27th December 2005, 10:31   #966  |  Link
nixo
nixo's Avatar
Fixed quant XviD encoding
Is it possible in MeGui to do a fixed quant XviD encode using a quantizer that isn't a whole number?
It seems to work fine from command line but I'm not having a lot of success in MeGui.
nixo is offline
Old 27th December 2005, 10:46   #967  |  Link
sh0dan
sh0dan's Avatar
I cannot see the Full Package anywhere - and it's still down.
sh0dan is offline
Old 27th December 2005, 12:59   #968  |  Link
Doom9
clueless n00b
No (well, yes but doing that is only for programmers). And I'm pretty sure as far as XviD or other ASP codecs are concerned, you only have integer quantizers.
@sh0dan: I've added a link to the temporary mirror.
Doom9 is offline
Old 27th December 2005, 13:11   #969  |  Link
stax76
staxrip & mpv.net
Don't know about mencoder but VFW codecs don't need integer, for DivX there is quite a bit difference beween 3 and 4, I tend to use XviD at 2.5, iirc it compares to DivX at 3.
With this faith...
Let freedom ring...
stax76 is offline
Old 27th December 2005, 13:15   #970  |  Link
Doom9
clueless n00b
and what would 2.5 result in? 50% 2 and 50% 3? Don't tell me there's 2.5 quantizer I'm unaware off (and for that matter the XviD status window)
Doom9 is offline
Old 27th December 2005, 13:35   #971  |  Link
stax76
staxrip & mpv.net
I just recently started to play with advanced codec settings so I'm pretty much clueless. I made however a quick XviD test, there appear to be a file size/quality difference:
q4   = 2.89 MB
q3.5 = 3.75 MB
q3   = 4.13 MB
q2.5 = 6.28 MB
q2   = 6.76 MB
With this faith...
Let freedom ring...
stax76 is offline
Old 27th December 2005, 13:39   #972  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Yes, XviD dithers the quants, 50% q2 and 50% q3.
lavc allows a qscale=2.5, and really does it (rounds to the nearest integer quant, but tweaks RD and trellis to get a quality point halfway between qscale=2 and qscale=3).
stax: Notice how your q2.5 is nowhere near halfway between q2 and q3. That's because the q3 half of the frames are lower quality, but most of the details missed there just have to be encoded in the next q2 frame. So overall you don't save many bits, and just lose a little compression efficiency.
akupenguin is offline
Old 27th December 2005, 13:56   #973  |  Link
nixo
nixo's Avatar
AutoGK uses this approach when you choose 'Target Quality' mode. 75% quality equals quant 2.67, 67% equals quant 2.99 and so forth... It's really nice to do 1-pass encodes when your hardware isn't exactly state-of-the-art and file size isn't an issue.
I've been doing 2.67 quant encodes through VDubMod for a while and I just thought I'd ask since MeGUI looks really good to me... :-)
nixo is offline
Old 27th December 2005, 14:12   #974  |  Link
Doom9
clueless n00b
well, it's no problem changing those up/down boxes. I don't see the sense of 1 pass encoding *at all* but it's no problem to make the change.
Doom9 is offline
Old 27th December 2005, 14:14   #975  |  Link
nixo
nixo's Avatar
That'd be great. Thanks!
nixo is offline
Old 27th December 2005, 14:52   #976  |  Link
stax76
staxrip & mpv.net
I use always single pass quality mode. Regarding multipass vs quality mode I started a thread recently. While there were great answers and help I'm still much interested in other peoples opinion on the topic, it can be found here:
http://forum.doom9.org/showthread.php?t=104548
With this faith...
Let freedom ring...
stax76 is offline
Old 27th December 2005, 15:04   #977  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
got it.
coz thats no longer the latest version. get this: http://www.webalice.it/f.corriga/meg..._0.2.3.1024.7z
and the sources are here: http://www.webalice.it/f.corriga/meg...0.2.3.1024.rar
Old 27th December 2005, 15:09   #978  |  Link
smok3
brontosaurusrex
smok3's Avatar
what command line exactly are you using for x264 quality mode?
how do you calculate the proper q amount (based on input resolution?)?
smok3 is offline
Old 27th December 2005, 15:51   #979  |  Link
stax76
staxrip & mpv.net
Nixo had requested it for XviD, I'm not using AVC. There is a reason why I should educate myself regarding x264 and want to do so pretty soon.
With this faith...
Let freedom ring...
stax76 is offline
Old 28th December 2005, 00:11   #980  |  Link
smok3
brontosaurusrex
smok3's Avatar
right, actually my 2nd question 'how do you calculate the proper q amount' does not make any sense (just figured that out few minutes after posting...)
smok3 is offline
