Old 5th November 2005, 15:00   #801  |  Link
bond
Originally Posted by Doom9
did you check out the link in the changelog? It explains it.. it's needed for compliance.
ah ic, so its not really an explicit requirement but the only way to ensure compliance atm in x264
Ogg Theora | Ogg Vorbis
bond is offline
Old 5th November 2005, 15:03   #802  |  Link
subcool
with which version did it start?
Is x264.exe still running before you manually abort?
Also, could you run the exact same commandline that gets stuck (does it always? if you restart the job does the same thing happen) in a commandline and paste everything you see here?
it started with 0.2.2.8.
I haven't looked at if x264.exe is stuck too, i'll look at that next time it happends. I'll give the commandline a shot too soon.
But another thing i noticed is that it doesnt happen on short encodes (like if the encoding takes less than 5 mins) just on longer ones where (for me) the first pass takes 1 hr and the 2nd bout 1.5 ~ 2 hrs
All you gotta do is run for your life, i just gotta know why!?
subcool is offline
Old 5th November 2005, 15:20   #803  |  Link
Doom9
clueless n00b
Are you sure it's megui or is it perhaps the x264 revision you're using? I've been looking at the source code archive and the video encoder hasn't been changed since october 4th or release 0.2.2.6.. and I'm pretty sure that's the only place your problem could stem from (well.. actually I think it's your setup but on my end the videoencoder makes the most sense looking at your log and what is missing from it). It is quite important to know if x264.exe is still running or not.. it narrows down the section where something could've gone wrong (basically your reported bitrate makes me thing that's where something goes wrong.. hence me asking to run x264 from the commandline).
Doom9 is offline
Old 5th November 2005, 19:25   #804  |  Link
subcool
I have updated x264 but the problem stayed the same. And when a job remains stuck, x264.exe is still running too. the 1-2 job got stuck too >_<
subcool is offline
Old 5th November 2005, 19:27   #805  |  Link
Doom9
clueless n00b
now run the job from the commandline please... I have a suspicion but the lack of reports plus my own experience seem to contradict it.
also, it would be useful to run a job that gets stuck (long one) and one that doesn't on the commandline and post the entire output here for both cases so that I can see the difference.
Doom9 is offline
Old 6th November 2005, 04:13   #806  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
@Doom9 - FYI, the latest build fixes both of the exceptions I saw before.
Richard Berg is offline
Old 6th November 2005, 15:12   #807  |  Link
charleski
charleski's Avatar
Umm, unless I'm very much mistaken (which is always possible! ), it looks like there's a bug in the way MeGUI constructs the commandline for BeSweet using Nero AAC. I was trying to work out why my delay compensation wasn't happening when I noticed that the commandline was:
"...\BeSweet\BeSweet.exe" -core( -input "stuff.mpa" -output "stuff.mp4" -logfile stuff.besweet.log ) -bsn( -2ch -vbr_normal -codecquality_high -aacprofile_lc  -ota( -d -80 -g max )
Surely there needs to be a closing parenthesis after -aacprofile_lc? It would help if the name of the logfile is enclosed in quotation marks as well, DGIndex produces demuxed tracks with spaces in the filename. This only affects use of the NAAC encoder, the other options seem fine.
[Edit]This is using version 0.2.3.1 of meGUI, whcih is otherwise excellent.
Here's the relevant portion of the log (had to copy it from the tab, for some reason nothing is saved in my logs directory):
Next job job1 is an audio job. besweet commandline:
"C:\Program Files\GordianKnot\BeSweet\BeSweet.exe" -core( -input "C:\New Folder\stuff T01 DELAY 0ms.mpa" -output "C:\New Folder\stuff T01 DELAY 80ms.mp4" -logfile C:\New Folder\stuff T01 DELAY 80ms.besweet.log ) -bsn( -2ch -vbr_normal -codecquality_high -aacprofile_lc  -ota( -d 80 -g max )
successfully set up audio encoder and callbacks for job job1
Log for job job1
besweet: "C:\Program Files\GordianKnot\BeSweet\BeSweet.exe" -core( -input "C:\New Folder\stuff T01 DELAY 0ms.mpa" -output "C:\New Folder\stuff T01 DELAY 80ms.mp4" -logfile C:\New Folder\stuff T01 DELAY 80ms.besweet.log ) -bsn( -2ch -vbr_normal -codecquality_high -aacprofile_lc  -ota( -d 80 -g max )
BeSweet v1.5b31 by DSPguru.
[00:00:00:000] Initializing...
[00:00:00:000] -- Initializing...
charleski is offline
Old 6th November 2005, 15:41   #808  |  Link
Doom9
clueless n00b
@charleski: it's all fixed in the "b" release.
Doom9 is offline
Old 6th November 2005, 16:18   #809  |  Link
max-holz
I see that's pending.
max-holz is offline
Old 6th November 2005, 22:49   #810  |  Link
charleski
charleski's Avatar
Thanks for the speedy fix. Sync issues are a major pain for me as I'm encoding from DVB-T streams that almost always start with an open GOP. I was tearing my hair out until I noticed the commandline.
Old 7th November 2005, 10:45   #811  |  Link
subcool
here is one run in CLI that gets stuck in MeGui
I copy/pasted the 1st pass CLI that MeGUI uses, so i didnt expect any problems... but as you see, there were.
there only was a 1.4 MB kaleidscope.stats.temp file in the x264 directory while normally the stats files would be around 3 MB
C:\x264>x264.exe --pass 1 --bitrate 690 --stats ".stats" --keyint 240 --bframes
2 --subme 1 --weightb --analyse none --qpmax 27 --ratetol 90 --qcomp 0.9 --me di
a --sar 1:1 --progress --no-psnr --output NUL "D:\encoding\raws\kaleidoscope\Kal
eidoscope.avs"
avis [info]: 640x480 @ 23.98 fps (34407 frames)
x264 [info]: no need for a SAR
x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow!
encoded frames: 16172/34407 (47.0%), 13.45 fps, eta 0:22:35
C:\x264>x264.exe --pass 2 --bitrate 690 --stats ".stats" --keyint 240 --ref 4 --
mixed-refs --bframes 2 --subme 7 --weightb --analyse all  --8x8dct --qpmax 27 --
ratetol 90 --qcomp 0.9 --me umh --sar 1:1 --progress --no-psnr --output "D:\encoding\raws\kaleidoscope\Kaleidoscope.mp4" "D:\encoding\raws\kaleidoscope\Kaleidos
cope.avs"
x264 [error]: ratecontrol_init: can't open stats file
x264_encoder_open failed
subcool is offline
Old 7th November 2005, 13:03   #812  |  Link
bond
the "--stats ".stats"" looks strange, try writing a real filename in there
btw x264's statsfiles have the extension .log normally
bond is offline
Old 7th November 2005, 14:16   #813  |  Link
subcool
i actually restarted the encode before going to school and replaced '.stats.' with 'kaleidoscope.stats' and it continued with the 2nd pass (i wrote the jobs in a batch file)
Output for 1st pass was:
C:\x264>x264.exe --pass 1 --bitrate 690 --stats "kaleidoscope.stats" --keyint 24
0 --bframes 2 --subme 1 --weightb --analyse none --qpmax 27 --ratetol 90 --qcomp
 0.9 --me dia --sar 1:1 --progress --no-psnr --output NUL "D:\encoding\raws\kale
idoscope\Kaleidoscope.avs"
x264 [info]: slice I:255   Avg QP:22.46  size: 21314 0:00:00
x264 [info]: slice P:15888 Avg QP:24.64  size:  5559
x264 [info]: slice B:18264 Avg QP:26.18  size:   997
x264 [info]: mb I  I16..4: 44.2%  0.0% 55.8%
x264 [info]: mb P  I16..4: 11.4%  0.0%  0.0%  P16..4: 35.6%  0.0%  0.0%  0.0%  0
.0%    skip:53.0%
x264 [info]: mb B  I16..4:  0.6%  0.0%  0.0%  B16..8: 11.6%  0.0%  0.0%  direct:
 4.9%  skip:82.8%
x264 [info]: kb/s:624.2
subcool is offline
Old 7th November 2005, 14:39   #814  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
just a note: --subme 7 was broken on certain builds and made x264.exe crash or lock.
please use the new rev365 build OR use --subme 6.
Sharktooth is offline
Old 7th November 2005, 17:06   #815  |  Link
subcool
Output from 2nd pass (using build from 6-11-2005 from x264.nl)
the x264.exe is not even closing now... o.O
it doesnt appear to be doing anything either
C:\x264>x264.exe --pass 2 --bitrate 690 --stats "kaleidoscope.stats" --keyint 24
0 --ref 4 --mixed-refs --bframes 2 --subme 7 --weightb --analyse all  --8x8dct -
-qpmax 27 --ratetol 90 --qcomp 0.9 --me umh --sar 1:1 --progress --no-psnr --out
mp4 [info]: initial delay 262144 (scale 6285217)
x264 [info]: slice I:255   Avg QP:19.89  size: 253130:00:00
x264 [info]: slice P:15888 Avg QP:22.00  size:  6063
x264 [info]: slice B:18264 Avg QP:24.14  size:  1158
x264 [info]: mb I  I16..4: 31.6% 29.7% 38.7%
x264 [info]: mb P  I16..4:  6.3%  3.1%  3.9%  P16..4: 26.9%  8.5%  4.7%  0.4%  0
.2%    skip:46.1%
x264 [info]: mb B  I16..4:  0.4%  0.3%  0.2%  B16..8: 14.0%  0.9%  1.7%  direct:
 2.1%  skip:80.4%
x264 [info]: 8x8 transform  intra:24.3%  inter:28.0%
x264 [info]: ref P  79.0%  9.8%  7.2%  4.0%
x264 [info]: ref B  82.1%  8.7%  5.8%  3.4%
x264 [info]: kb/s:690.9
encoded 34407 frames, 1.74 fps, 690.93 kb/s
subcool is offline
Old 7th November 2005, 17:18   #816  |  Link
bond
subcool, try to search for "nicefps" in this forum. there was (is?) a problem with strange framerates fixeable with nicefps and other methods (like changefps())
bond is offline
Old 7th November 2005, 17:21   #817  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
.... ensure your commandline contains options not supported by SVN builds... --subme 7 for example........
Old 7th November 2005, 20:27   #818  |  Link
zajc
Bug?!
MeGUI version 0.2.3.1
Test case:
settings
uncheck the "Open progress window"
When I try to encode HUFFYUV .avi file into XVID the megui.exe process takes most of the CPU instead mencoder (mencoder.exe 40% CPU, megui.exe 60% CPU). Encoding is horribly slow.
When I check the Open progress window then mencoder.exe use 99% CPU, megui.exe 1% CPU.
It might be a bug!?
zajc is offline
Old 7th November 2005, 20:40   #819  |  Link
Doom9
clueless n00b
I'm encoding right now without progress window. mencoder takes 50%, megui 0% (it's a dual core so only using 50% is normal.. XviD doesn't contain any SMP optimizations).
Doom9 is offline
Old 7th November 2005, 21:22   #820  |  Link
zajc
Hmmm, now it works fine too when I restarted megui.
I put 7 jobs in queue to encode huffyuv -> xvid
1 1st pass 20 fps (.avi length 45 min)
1 2nd pass 10 fps
2 1st pass 25 fps (.avi length 130 min)
2 2nd pass 10 fps
3 1st pass 14 fps (.avi length 45 min)
3 2nd pass 6 fps
4 1st pass 7 fps (.avi length 21 min)
4 2nd pass 4 fps
5 1st pass 4 fps (.avi length 3 min)
5 2nd pass 2 fps
6 1st pass 3 fps (.avi length 5 min)
6 2nd pass 3 fps
Then I found out megui.exe procces takes more then 60% of CPU time and I abort the 7th job. After restarting megui.
7 1st pass 23 fps (.avi length 22 min)
7 2nd pass 11 fps
I have never experienced such behavour with previous version of megui althought I put 20 jobs or more in queue.
zajc is offline
