Old 27th September 2015, 17:47   #3121  |  Link
Glarioo
Uninstalled Avisynth 2.5.8 and installed Avisynth 2.6.0.6 (downloaded from Videohelp). Encoded some Harry Potter movies (1, 2, 3 and 4). A quick look at the MKV's tells me that everything looks fine.
Glarioo is offline
Old 18th November 2015, 13:26   #3122  |  Link
Zebbik
MeGUi warnings
I've got this warning when I run MeGUI application. I am not an expert on that and I don't exactly know what may be wrong and cause it. I have copied a part of a log.
[Warning] Versions
-[Information] [18/11/2015 11:30:52] MeGUI: 2525
-[Information] [18/11/2015 11:30:52] Operating System: Windows 7 Enterprise Edition x64 SP1 (6.1.65536.7601)
-[Information] [18/11/2015 11:30:52] .Net Framework: 2.0.50727.5420
-[Information] [18/11/2015 11:30:52] .Net Framework: 4.0.0.0
-[Information] [18/11/2015 11:30:54] AviSynth+ portable: 2.6.0.5 (02-01-2014)
-[Information] [18/11/2015 11:30:57] AvisynthWrapper:  (02-01-2009)
-[Warning] [18/11/2015 11:30:57] Haali Matroska Splitter not installed properly.
-[Warning] [18/11/2015 11:30:57] Therefore DSS2() and certain functions of FFVideoSource() and the HD Streams Extractor may also not work.
-[Warning] [18/11/2015 11:30:58] Please download and install it from http://haali.su/mkv/
-[Information] [18/11/2015 11:30:58] Haali DSS2: not installed
-[Information] [18/11/2015 11:30:58] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
-[Information] [18/11/2015 11:30:58] LinqBridge: 1.0.0.0 (28-05-2009)
-[Information] [18/11/2015 11:30:58] MediaInfo: 0.7.72.0 (07-01-2015)
-[Information] [18/11/2015 11:30:58] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
-[Information] [18/11/2015 11:30:58] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
-[Information] [18/11/2015 11:30:58] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
-[Information] [18/11/2015 11:30:58] 7z: 9.20 (18-11-2010)
MeGUI is on a USB HDD. I hope that's not why the problem appears!
Zebbik is offline
Old 18th November 2015, 15:21   #3123  |  Link
LigH
LigH's Avatar
You have MeGUI version 2525. The most current development version is 2620. The use of Haali Media Splitter is quite deprecated now for many features. Please update after switching to the development update server, then check if this warning still appears. Anyway, you may possibly not need it except for a few specific uses.
New German Gleitz board
LigH is online now
Old 19th November 2015, 09:51   #3124  |  Link
Zebbik
Hi and thanks for the answer. I use either x264 or XviD (unfortunately I still need to deal with XviD) in MKV or AVI container. If that's possible, could explain when I would need to worry about the Haali Splitter? What is it for?
As to the version, the MeGUI2525 seems to be the most up-to-date at SourceForge (the link).
thanks
Zebbik is offline
Old 19th November 2015, 10:11   #3125  |  Link
LigH
LigH's Avatar
Haali Media Splitter used to be helpful for reading different video formats, supporting FFMS2 while it depended on its help, and demultiplexing streams from HD formats to be processed separately. Also it was a common DirectShow splitter filter for the Matroska container (*.mkv).
Today it is rather obsolete since FFMS2 uses no special Matroska splitter anymore, but libavformats instead, just like L-SMASH Source always did (and was much more reliable this way). Regarding DirectShow filters, "LAV Filters" substituted both ffdshow and Haali Media Splitter in most cases.
_
You may have downloaded the latest "stable" MeGUI release; but the "stable" versions last long and miss a lot of recent updates from the "development" branch. Development versions of MeGUI are usually well tested, and new bugs won't last long, so it is usually recommendable to switch to the development update server in the MeGUI options.
LigH is online now
Old 19th November 2015, 14:59   #3126  |  Link
nekrovski
nekrovski's Avatar
Can anyone tell me why MeGUI keeps crashing?
It's been a while since I've done some encodings. I'm on windows 10 now. Opening MeGUI, going to tools -> avs script creator -> video input
I select the video, the preview comes up totally blank and after closing the preview it crashes. Sometimes after selecting the video, MeGUI starts loading, 15 seconds pass by and I get some DirectShowSource timeout error.
Event viewer says this
Faulting application name: MeGUI.exe, version: 1.0.2525.0, time stamp: 0x54fc5b03
Faulting module name: DirectShowSource.dll_unloaded, version: 2.6.0.3, time stamp: 0x55332925
Exception code: 0xc00001a5
Fault offset: 0x00010600
Faulting process id: 0x13d0
Faulting application start time: 0x01d122d0f24746d6
Faulting application path: C:\Users\X\Desktop\MeGUI_2525_x86\MeGUI.exe
Faulting module path: DirectShowSource.dll
Report Id: c1372567-e047-4ce1-a20c-45663d17eec5
Faulting package full name:
Faulting package-relative application ID:
I have avisynth installed.
nekrovski is offline
Old 19th November 2015, 15:07   #3127  |  Link
LigH
LigH's Avatar
Why do you prefer DirectShowSource, despite all recommendations to use it only when native AviSynth plugins (like DGDec*, L-SMASH Source or FFMS2) fail?
Such a crash is probably caused by issues with an installed DirectShow filter or DirectShow as a whole (Windows 10 is going to deprecate it). Native AviSynth decoders don't depend on installed DirectShow filters. Furthermore, DirectShow filters are not always tuned for optimal quality, sometimes instead for performance with possible quality loss, down to skipped frames (which will ruin your conversion).
Native plugins will just have a little disadvantage that they usually need an index file being generated. But in general, their reliability is better today than ever before.
LigH is online now
Old 19th November 2015, 15:15   #3128  |  Link
nekrovski
nekrovski's Avatar
Thanks for your reply.
I use DirectShow because that's how I was taught several years back after following a tutorial.
Now, you recommend I should click File indexer?
Old 19th November 2015, 15:34   #3129  |  Link
LigH
LigH's Avatar
Yes, that would be the recommended procedure in these days.
In case of doubt, show us a MediaInfo analysis of your source, and a description of the desired target (especially when a playback device may require some compatibility), then we can give more specific recommendations. Sometimes it may be useful to use the HD streams extractor if a source contains audio formats which need a special processing because the target format would not support them.
LigH is online now
Old 19th November 2015, 16:27   #3130  |  Link
nekrovski
nekrovski's Avatar
In case of doubt
There's no doubt since I don't really understand these things, but since file indexer seems to do the job DirectShow was supposed to, I think it's fine.
Thanks for your support!
Old 6th December 2015, 08:29   #3131  |  Link
Glarioo
I'm using MeGui 2624. Since the last update (saturday 5/12/2015) i get this error: LoadPlugin: unable to load "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI_2525_x86\tools\lsmash\LSMASHSource.dll", Module not found. Install missing library?
These tools have been updated: FFmpeg, L-SMASH Works and mkvmerge. The movie that fails since the last update was working well a day earlier.
Glarioo is offline
Old 6th December 2015, 10:03   #3132  |  Link
LigH
LigH's Avatar
Thank you - already reported in the MeGUI bug reports thread. I believe we have 3 current big threads related to MeGUI now.
LigH is online now
Old 6th December 2015, 21:44   #3133  |  Link
Zathor
Yes, maybe it would be a good idea to close this thread here as the information in the thread start is outdated.
Zathor is offline
Old 7th December 2015, 10:26   #3134  |  Link
Glarioo
Yesterday evening i've installed the new update (LSMASHWorks r804) and MeGUI is working perfectly again.
Glarioo is offline
Old 7th December 2015, 10:35   #3135  |  Link
LigH
LigH's Avatar
Rather looks like the L-SMASH Source version was downgraded a bit (r82x => r804), until there is a reliable updated version again.
LigH is online now
Old 7th December 2015, 12:50   #3136  |  Link
tebasuna51
tebasuna51's Avatar
Yes, I also think so.
Please use only:
MeGUI: General Questions and Troubleshooting Thread
MeGUI: bug reports and feature requests
Thread closed.
tebasuna51 is offline
