Old 14th August 2015, 01:44   #3101  |  Link
Xor
Originally Posted by LigH View Post
The used call with all command line parameters is missing in your log.
Furthermore, there is apparently no AC3 audio stream, only raw PCM.
i use tools>hd streams extractor
how to grab FULL command line?
Xor is offline
Old 14th August 2015, 02:29   #3102  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Xor View Post
...how to grab FULL command line?
Is not necesary.
Seems there are some corrupt data in your ISO file or maybe the playlist have more than one m2ts with different tracks.
If the mpls have more than one m2ts try open each one (Select file as input) to see if there are different track 3 and 4.
BTW to extract PCM tracks use always wav or w64 output, never use raw or pcm.
tebasuna51 is offline
Old 14th August 2015, 07:27   #3103  |  Link
LigH
LigH's Avatar
Alright, tebasuna51 will know MeGUI better. — But if you are still interested, I would guess it may be stored in the log file.
German doom9 / Gleitz video board
CQME – change the Matrix!
BeSweet 1.5b31 All In One | HeadAC3he 0.24a13
Rémoulade is spoiled
LigH is offline
Old 14th August 2015, 10:57   #3104  |  Link
tebasuna51
tebasuna51's Avatar
Not the full MeGUI, but yes the HD Streams Extractor like a eac3to GUI.
It generate a command line like this (replace the upper case with the selected/generated value):
eac3to BD_FOLDER_INPUT PLAYLIST_NUMBER) TRACK_NUMBER: OUTPUT.EXT PARAMETERS
With:
EXT can be selected in 'Extract As'
PARAMETERS can be added manually in '+Options'
When eac3to analyze a playlist show the tracks of first m2ts, if there are only one the message:
[a04] The ts pcm reader received a PCM block in an unexpected format. <WARNING>
only can be corrupt data.
But if there are a second m2ts with a track 4 PCM 5.1 the ts pcm reader can detect the change (pcm blocks in ts container have a little header).
Is a know problem when there are different tracks in m2ts's in the same playlist. The only solution is extract the audio track from each m2ts and convert them to the common desired format.
Old 27th August 2015, 18:42   #3105  |  Link
Glarioo
Hey guys. I'm new here.
Is it normal that the Reframes are displayed differently by media info than set by MeGui (one-click mode)? Or did i something wrong. I've tried "Restore Defaults" with no result.
Glarioo is offline
Old 27th August 2015, 19:19   #3106  |  Link
LigH
LigH's Avatar
Which video format?
And how old is your MediaInfo?
I know there was a mistake interpreting the references of AVC video in case of B-frame pyramid enabled (one reference array space had to be reserved for the pyramid details), but MediaInfo should have corrected that a while ago, I believe?!
LigH is offline
Old 27th August 2015, 19:31   #3107  |  Link
Zathor
Is it normal that the Reframes are displayed differently by media info than set by MeGuide (one-click mode)? Or did i something wrong. I've tried "Restore Defaults" with no result.
Please post your log file of the encoding.
Zathor is offline
Old 27th August 2015, 20:49   #3108  |  Link
Glarioo
Thanks for the quick response!
I've encoded the same movie today again, same "problem".
Here's the log file.
Video format was AVC, i think. (MKV container).
I use the latest version of MediaInfo (0.7.76).
Glarioo is offline
Old 28th August 2015, 04:15   #3109  |  Link
sneaker_ger
I assume you refer to this:
http://forum.doom9.org/showthread.ph...06#post1470506
I don't think MediaInfo has changed anything so this is normal. (His log isn't approved yet but I guess that's indeed where the difference comes from.)
sneaker_ger is offline
Old 30th August 2015, 15:07   #3110  |  Link
Glarioo
When i disable B-Pyramid in the x264 configuration dialog (Frame-Type), the problem is solved (post #3105).
However, i do not know if this is allowed.
Glarioo is offline
Old 30th August 2015, 16:09   #3111  |  Link
LigH
LigH's Avatar
Better trust in x264 doing a great job in the given limits, and do not panic over MediaInfo not explaining this header analysis verbosely. Most probably x264 won't exhaust the reference frame limit in every GOP, anyway, will often be satisfied with less references per frame than allowed.
LigH is offline
Old 31st August 2015, 17:39   #3112  |  Link
Glarioo
Did some test with B-Pyramid enabled (normal) and disabled. I see no difference. The quality of the movie, in both encodes, is very good.
Glarioo is offline
Old 10th September 2015, 19:40   #3113  |  Link
Glarioo
My installed version of Avisynth is 2.5.8. In options - settings - main configuration is "Always use the included version of Avisynth" unchecked. Should i checked it or just leave it? I always use one click mode of MeGui.
Glarioo is offline
Old 10th September 2015, 19:53   #3114  |  Link
LigH
LigH's Avatar
This is not at all related to the B-frame pyramid.
And in general, you may want to update to AviSynth v2.60 final, eventually ...
Whether you always want to use the AviSynth+ version included in MeGUI, I don't know; if you are going to use very complex script functions like QTGMC, you may not want to. Not until AviSynth+ got fixed. It may leak memory and drop speed. But there seems to be serious effort now.
LigH is offline
Old 11th September 2015, 13:53   #3115  |  Link
Glarioo
Thanks LigH. I just wanted to know if the included, newer version of AviSynth is "better" than my installed version. I gonna use my installed version until AviSynth+ got fixed, like you said. I don't use complex script functions, i have no experience with those things. I just use One-Click, sometimes automated 2-pass, but most of the time Const. Quality (CRF-18). Preset medium or slow it depends...
BTW, this question had nothing to do with B-Pyramid. My apologize 'cause i confused you a little.
Glarioo is offline
Old 14th September 2015, 07:42   #3116  |  Link
Xor
i want try to create a HEVC 4k (4096 PX) with Megui and source a normal untouched bluray x264.
On Megui select X265 but connot permit to upscaling over 1920.
how to proceed using Megui to upscaling?
Or what do you recommend different encoder? which ?
Thank's
Xor is offline
Old 14th September 2015, 08:22   #3117  |  Link
AMED
AMED's Avatar
Thank's
Edit the Avisynth profile you are using, Extra setup tab and tick Upsizing allowed.
A Man Eating Duck
AMED is offline
Old 14th September 2015, 08:32   #3118  |  Link
hello_hello
Thank's
I assume you've not enabled "upsizing" in the script creator's Avisynth profile configuration? If that's the problem, once it's enabled you should be able to use the script creator's resizing to upscale to 4k. I still think it'd be better if "upsizing" was enabled by default. I rarely use the OneClick encoder so I don't know how upscaling applies there.
Isn't 4K for the masses 3840x2160 rather than 4096 wide? I just thought I'd mention it.....
https://en.wikipedia.org/wiki/Blu-ray#Ultra_HD_Blu-ray
https://en.wikipedia.org/wiki/Ultra-...ion#Resolution
hello_hello is offline
Old 14th September 2015, 15:27   #3119  |  Link
stax76
staxrip & mpv.net
Yes, it looks QTGMC works with ref 1773, I'll downgrade AviSynth+ in my next release, the discussion is here:
http://forum.doom9.org/showthread.ph...51#post1736551
StaxRip - use pastebin for log files and imgbox for screenshots
mpv.net player
stax76 is offline
Old 14th September 2015, 22:41   #3120  |  Link
hello_hello
My installed version of Avisynth is 2.5.8. In options - settings - main configuration is "Always use the included version of Avisynth" unchecked. Should i checked it or just leave it? I always use one click mode of MeGuI.
Zathor switched the "included" Avisynth to Avisynth 2.6 very recently. At least on the development update server. The "included" Avisynth is no longer Avisynth+ (due to a few recent problems with that version).
It might be an idea to uninstall your old Avisynth 2.5.8 and install Avisynth 2.6, given it's the current version.
It shouldn't matter whether MeGUI uses the "included" Avisynth or the "installed" Avisynth.
