Old 7th July 2015, 08:11   #3081  |  Link
Dion
Originally Posted by Zathor View Post
Thanks for the report. As I am not able to test this myself right now can you please post a log? Or does it look correct in there?
It seems that the audio is receiving the lang=en command but its not working. Video is not receiving it at all. I would assume it would use whatever is the default in the options. In my case English. Either way it was working before so I am not sure what happened.
[Information] [7/7/2015 12:07:07 AM] Job command line: "D:\Software\Programs\MeGUI\tools\mp4box\mp4box.exe" -add "D:\Download\source.h264#trackID=1:fps=23.976:name=file://D:\Download\source.h264_TRACKNAME0.txt" -add "D:\Download\audio.aac#trackID=1:lang=en:name=file://D:\Download\audio.aac_TRACKNAME0.txt" -tmp "D:\\Download" -new "D:\Download\source-muxed.mp4"
MediaInfo shows it missing too.
General
Complete name                  : source-muxed.mp4
Format                         : MPEG-4
Format profile                 : Base Media
Codec ID                       : isom
File size                      : 273 MiB
Duration                       : 9mn 56s
Overall bit rate mode          : Variable
Overall bit rate               : 3 831 Kbps
Encoded date                   : UTC 2015-07-07 07:07:07
Tagged date                    : UTC 2015-07-07 07:07:07
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings, CABAC         : Yes
Format settings, ReFrames      : 5 frames
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 9mn 56s
Bit rate                       : 3 701 Kbps
Maximum bit rate               : 7 159 Kbps
Width                          : 1 152 pixels
Height                         : 720 pixels
Display aspect ratio           : 16:10
Frame rate mode                : Constant
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.186
Stream size                    : 263 MiB (97%)
Title                          : x264
Tagged date                    : UTC 2015-07-07 07:07:09
Audio
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Codec ID                       : 40
Duration                       : 9mn 56s
Bit rate mode                  : Variable
Bit rate                       : 128 Kbps
Maximum bit rate               : 150 Kbps
Channel(s)                     : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 48.0 KHz
Compression mode               : Lossy
Stream size                    : 9.09 MiB (3%)
Title                          : AAC
Encoded date                   : UTC 2015-07-07 07:07:09
Dion is offline
Old 7th July 2015, 10:13   #3082  |  Link
LigH
LigH's Avatar
I believe that a video stream would only need a language flag if it has language-dependent content (like the multi-angle trick on the "Shrek" DVD to show the cast rendered with translated texts).
German doom9 / Gleitz video board
CQME – change the Matrix!
BeSweet 1.5b31 All In One | HeadAC3he 0.24a13
Rémoulade is spoiled
LigH is offline
Old 8th July 2015, 02:01   #3083  |  Link
CRFOnly
x264 Addict
How ironic i came here to report the audio language problem from the mp4 muxer. Of course im using the last MeGUI dev server with all updated packages.
I found out that the command line must have changed in last mp4box. The language tag has to be 3 digits now, so instead of
lang=en
, it must be
lang=eng
Works well when i try to do it from CLI manually with the MeGUI's MP4Box.exe Should be an easy fix for the dev.
Thanks by the way for this awesome tool.
CRFOnly is offline
Old 8th July 2015, 07:06   #3084  |  Link
LigH
LigH's Avatar
There are different ISO-639 language codes, at least 2CC (639-1) and 3CC (639-2 and 639-3). If MP4Box "upgraded", then possibly for clarity and diversity.
LigH is offline
Old 8th July 2015, 17:10   #3085  |  Link
Carpo
Carpo's Avatar
Zathor are you still considering doing an x64 version of megui? I remember you saying way back that you might if and when support for x64 caught up (avisynth, dll's and such)
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline
Old 8th July 2015, 20:59   #3086  |  Link
Zathor
Stax did a recent try with Avisynth+ x64 here:
http://forum.doom9.org/showthread.php?t=172068
I still consider it myself, but it will be a lot of work to find working plugins and so on. And I do not want to abandon MeGUI x86 like Stax did with his tool. But then it will be too much work... so no clue when it will happen. Maybe tomorrow, maybe not in the next years. Depends an the dvelopment in the AviSynth x64 area (currently seems to be on hold again).
Zathor is offline
Old 8th July 2015, 22:30   #3087  |  Link
Carpo
Carpo's Avatar
I did try that out, but prefer megui more, as for plugins
http://avisynth.nl/index.php/AviSynt...2B_x64_plugins
not sure how up to date that is but a good starting point.
When MeGUI x64 does appear I will test it
Carpo is offline
Old 9th July 2015, 09:16   #3088  |  Link
Dion
lang=en
, it must be
lang=eng
Ah nice find. Well anyways I hope this can be fixed. For the video track and audio track.
edit: Just noticed there was a megui update. And it seemed to fix the audio. But the video is still left blank. Shouldn't this use what language is set in the options? Or maybe add a pulldown menu for the video as well for languages.
Dion is offline
Old 9th July 2015, 09:25   #3089  |  Link
LigH
LigH's Avatar
Does a language tag for the video stream make sense at all, except for the case when you have multiple video streams with different content for each language? ... MeGUI does not support multiple parallel video streams.
LigH is offline
Old 9th July 2015, 22:18   #3090  |  Link
Dion
That's not really the point. It was working at some point. Now its not. Also MKVMerge supports it. I see no reason why mp4 can't. I use it so yes there is a use for it for some.
Dion is offline
Old 10th July 2015, 14:02   #3091  |  Link
stax76
staxrip & mpv.net
The biggest problem with AviSynth+ x64 at this moment is you cannot use complex scripts like QTGMC. It's however possible to use QTGMC using VapourSynth x64 where it works greatly.
Another problem is DGDecode x64 isn't working correctly, it's not a big deal though since ffms2 x64 can handle NTSC fine and there is also DGDecNV x64.
Depending on situation I use both AviSynth+ x64 and VapourSynth x64.
StaxRip - use pastebin for log files and imgbox for screenshots
mpv.net player
stax76 is offline
Old 10th July 2015, 17:43   #3092  |  Link
Zathor
To my knowledge it was never supported in MeGUI to set a language for the video track. There is no option for that in the muxer GUIs.
Zathor is offline
Old 11th July 2015, 02:09   #3093  |  Link
Dion
Hmm interesting. Well I have muxed stuff in the past with MeGUI mp4 muxer and it set the English language. Maybe it was already set on the file before muxing.
Either way can you add this option?
Dion is offline
Old 10th August 2015, 17:40   #3094  |  Link
laz1989
Hey guys.
Noob question.
Is there anyway to go back to vfw4x264 in the new MeGui version ? MeGui replaced with avs4x264mod.
Or should i go back to older MeGui version ?
Thanks!
laz1989 is offline
Old 10th August 2015, 18:18   #3095  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm getting a weird error when opening MeGUI: it complains about a running MeGUI instance being detected. I certainly do not have another MeGUI running and the dialog also appears after a fresh reboot.
I also get the same error when trying to open "IV Play" (a MAME GUI).
I tried to watch what happens with Process Explorer but couldn't find any direct reason or hint where to start looking at. I've also uninstalled EMET and tried disabling the antivirus resident shield (AVG).
Does anyone have any tips?
Boulder is offline
Old 11th August 2015, 18:50   #3096  |  Link
Zathor
Not sure why you want to do that, but it may be possible to simply switch the executables (vfw4x264 renamed to avs4x264mod of course). If this does not work because of changed command lines then you need to use an older MeGUI version.
Zathor is offline
Old 11th August 2015, 19:19   #3097  |  Link
Zathor
MeGUI (same as IV-Play) are using Mutex to check if another instance of their programs are already running. It seems that your system has problems to detect those Mutex objects and therefore you get these messages.
Zathor is offline
Old 11th August 2015, 20:16   #3098  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, I'll try to dig up some information to fix the issue for good
Boulder is offline
Old 13th August 2015, 14:25   #3099  |  Link
Xor
i have a problem to extract audio track from an iso, i get a files 1mb ac3 not good.
I try to extract Ac3 and Raw, but extract fails, this is a log:
M2TS, 1 video track, 4 audio tracks, 1 subtitle track, 1:27:11, 0.423p
1: Chapters, 10 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: RAW/PCM, Italian, 2.0 channels, 16 bits, 48kHz
4: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz
5: RAW/PCM, French, 2.0 channels, 16 bits, 48kHz
6: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz
7: Subtitle (PGS), English
[a04] Extracting audio track number 4...
[a04] Reading RAW/PCM...
[a04] Swapping endian...
[a03] Extracting audio track number 3...
[a03] Reading RAW/PCM...
[a03] Swapping endian...
[a04] Creating file "D:\F1_T4_Audio - English.raw"...
[a03] Creating file "D:\F1_T3_Audio - Italian.raw"...
[a04] The ts pcm reader received a PCM block in an unexpected format. <WARNING>
[a03] The ts pcm reader received a PCM block in an unexpected format. <WARNING>
[a03] The original audio track has a constant bit depth of 16 bits.
[a04] The original audio track has a constant bit depth of 16 bits.
Video track 2 contains 125429 frames.
eac3to processing took 7 minutes, 20 seconds.
Done.
How to solve and extract correctly this track ?
Thanks
Xor is offline
Old 13th August 2015, 14:44   #3100  |  Link
LigH
LigH's Avatar
The used call with all command line parameters is missing in your log.
Furthermore, there is apparently no AC3 audio stream, only raw PCM.
LigH is offline
