Old 13th January 2006, 12:58   #1201  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Current Settings form is to big to fit @ some screen resolutions. And I'm planning to add at least 3 new executables to it. So i decide to add TabControl and place all program paths @ separate page.
Does You agreed?
dimzon is offline   Reply With Quote
Old 13th January 2006, 13:26   #1202  |  Link
dimzon
dimzon's Avatar
new SettingsForm layout is here: http://www.mytempdir.com/381070
Old 13th January 2006, 13:36   #1203  |  Link
Doom9
clueless n00b
Yeah, that's no problem.. the settings form is getting rather big.
Doom9 is offline   Reply With Quote
Old 13th January 2006, 13:39   #1204  |  Link
dimzon
dimzon's Avatar
some little code cleanup in settings form:
http://www.mytempdir.com/381110
Old 13th January 2006, 13:42   #1205  |  Link
berrinam
berrinam's Avatar
Yep, and so is the AviSynth Window.
@dimzon: Those screenshots don't have the two buttons that I added recently: Reset Dialogs, and Configure Source Detector. I put the Source Detector one there in 2014 and the Reset Dialogs there in 2016. Just warning you, so we don't get clashes there.
berrinam is offline   Reply With Quote
Old 13th January 2006, 13:42   #1206  |  Link
dimzon
dimzon's Avatar
there was some problem - this stupid Visual Studio 2005 forget component names and event-handlers during Cut/Paste (VS 2003 works fine). So we can't just cut some amount of controls from form and then paste them into TabPage.
I modified InitializeComponent directly for this...
Old 13th January 2006, 13:44   #1207  |  Link
dimzon
dimzon's Avatar
Unfortunally i can't use CVS - i have no rights to get sources via ssh and anonimous access doesn't work for me! I'm using latest sources tarball from Doom9.
Sorry!
Old 13th January 2006, 14:12   #1208  |  Link
berrinam
berrinam's Avatar
Yes, I had exactly the same problem. Here's a link to the latest sources: http://rapidshare.de/files/10962720/..._2017.rar.html
Old 13th January 2006, 14:39   #1209  |  Link
Doom9
clueless n00b
Is going to get you in a world of pain.. each time somebody changes something in the GUI designer, it will reset those manual changes.. that's the reason we have 3 initializecomponent versions in the settings form.. one for each mode (I know that is as ugly as it gets.. not my choice, visual inheritance would most likely handle that just fine)
By the way, what are these optional output extensions good for?
Old 13th January 2006, 15:40   #1210  |  Link
dimzon
dimzon's Avatar
Don't worry, it still work fine even after GUI designer
This is another reason to remove conditional compilation Let's do it!
I really does'tn know (this is not my code)
Old 13th January 2006, 15:46   #1211  |  Link
dimzon
dimzon's Avatar
@Doom9
Dear Doom9, we really need working source version control solution, current situation is not acceptable! Source control allows to track and revert any changes, so don't worry about "destructive activity from developers". You can ever mark every succesfull build by tags/labels to be able to revert/switch to any version.
Old 13th January 2006, 15:49   #1212  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
So you start the GUI, go directly to the x264 configuration, configure a non SVN feature, then configure the x264 path to a svn build, which limits the GUI, but the job is already there, so when you start the job you have the usual "unrecognized commandline" error. Even worse, if after configuration of the executable, you go back to the settings, the program will crash because the subme dropdown only has 6 entries now, not 7.
No. You go to the megui settings dialog, use the "..." button to set the x264 path and MeGUI will detect the version and enable/disable the respective controls in the x264config dialog and load the default settings.
However .2017 binaries are now on SF.
Old 13th January 2006, 15:56   #1213  |  Link
dimzon
dimzon's Avatar
Dear Sharktooth
I'm sorry, can You tell me - why does you still need separate x264 build for MeGUI? It saves approx 50kb per download BUT creates a really discomfort for development and dramaticaly reduce productivity...
Old 13th January 2006, 16:01   #1214  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Well, coz MeGUI-x264 requires only... x264 and it work as it is with my (and bobor's) x264 packages.
Including the full GUI means the user should look for additional software or i (or bobor) should distribute other software along with x264 (besweet, dgindex, faac, mp4box, etc).
At that point that wont be a x264 release anymore, but an encoding solution including x264 and will weight several megabytes.
Old 13th January 2006, 16:01   #1215  |  Link
max-holz
Sharktooth could you update http://files.x264.nl?
Ciao
max-holz is offline   Reply With Quote
Old 13th January 2006, 16:06   #1216  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
done
Old 13th January 2006, 16:09   #1217  |  Link
dimzon
dimzon's Avatar
You are wrong!
It reques at least
  • donNet Framework
  • AviSynth
and you don't redistribute it with Your bundle!
PS. and nobody force users to download mencoder/dgindex/etc if they doesn't need this functioonality!
Old 13th January 2006, 16:19   #1218  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
well everyone that encodes to divx or xvid has avisynth and .NET framework is available thru Windows Update.
However including the full version will confuse/scare the end user with all the supported codecs, options, softwares etc. while the MeGUI-x264 is perfect and it is related to x264 CLI (only) as encoder.
Old 13th January 2006, 16:21   #1219  |  Link
max-holz
What is it xvid_encraw.exe?
Old 13th January 2006, 16:22   #1220  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
the xvid command line encoder.
development, megui, not a help thread
