19th June 2005, 02:47 | #41 | Link | |
19th June 2005, 02:55 | #42 | Link |
clueless n00b
It calls the files as follows:
projectname <audio format> <track> <channel_format> <bitrate>bps DELAY <delay>ms.extension basically track is important (T01, T02, T03). So, I'd do a directory lookup (Directory.something) to get files that contain the track identifier and project name.. I think that should get you enough info to find the actual file.
19th June 2005, 04:32 | #43 | Link | |
I don't completely understand what you want with the languages thing. I've never worked with DVDs before but I do have a full list of every DVD language if you want it. From what I could tell from your to-do list you already have a language selection (because you said instead of checkboxes)? What is the language used for? .ifo files? What do I do once I know what language the user has chosen?
Did you get around to thoroughly testing the MP4Box progress bar? I just don't know what to do with the subtitles you sent me...I'm real inexperienced with DVDs. I understand what vob,ifo files are I just don't know what's in the ifo files and where/how subtitles are stored. I read the doom9 dvd newbie guide on it but it didn't really explain the subtitles for me. Quote:
Hey, BTW I love the new interface on the latest MeGUI! Last edited by xtknight; 19th June 2005 at 04:55. |
19th June 2005, 08:27 | #44 | Link |
Can more than 2 audio tracks be put into mp4? Is there a reason that MeGUI limits it to two?
I'm asking because I want to know what should happen when the user chooses more than two audio tracks -- which ones get put into the inputs? Also, about zones in the new interface: it doesn't seem very practical. Where do you get the frame numbers from for the zones? I would presume from the avspreview window. But this is inaccessible while the zones window is open. Also, setting credit start doesn't appear to be adding a zone at the end. |
19th June 2005, 11:05 | #45 | Link | |||||
clueless n00b
Then once you have created the dgindex project and close the window, the two audio tracks (if they match the languages from the preferences take those two, if there's only one match, take that and the first "other".. if there's no match take the first two, or if it's only one you only take one) and plug them into the audioFiles array in the main GUI. Quote:
mp4box -add video.264 -add audio1.mp4;lang=eng -add audio2.mp4;lang=ger -add subtitle1.srt;lang=eng -add subtitle2.srt;lang=ger -add subtitle3.srt;lang=fre -chap chapters.txt -spf 23.976 -new output.mp4 And no, I haven't gotten around to testing it. Quote:
19th June 2005, 13:35 | #46 | Link |
clueless n00b
I've added a few design studies for some of the features on the todo list.
19th June 2005, 23:07 | #47 | Link | |
clueless n00b
encoded 43 frames, 22.02 fps, 1095.94 kb/s from that you can get the actual video bitrate (without container overhead) and put into the log (you can also get the container overhead from this of course... ). mencoder writes something similar. It's really no big deal, just a little commandline parsing. If you're working on the d2v creator, make sure you use the latest sources.. the language selections in the settings can finally be made.
19th June 2005, 23:18 | #49 | Link |
clueless n00b
and there's another one if you're already working on that class.. run dgindex minimized.. the solution can be either found in the development forum or the avi.net thread.. I'm a participant in both discussions. Or perhaps it's in the old megui thread. Either way the solution is aready around, and it's a real easy fix
20th June 2005, 08:30 | #50 | Link |
In case someone did not yet notice: Microsofts default Windows filters (after a fresh install) don't convert YV12 in general, planar video formats are rather unusual. But DivX 5 or XviD - once installed - take this job, and I even got some ATI codecs some long time ago.
ffdshow's raw video conversion is just another way to go. Who knows how many more filters or codecs can be used as "helpers"... |
20th June 2005, 09:15 | #51 | Link |
clueless n00b
@Ligh: though that doesn't seem to be the problem here as he can play the file in a media player. But if you can, then we know the filters are available.. it's just that AVIFile works differently.. I really wished I could reproduce this somehow because right now I'm rather clueless... I know which call fails but I have no idea why.. I guess I need to read into the AVIFile API after all - unfortunately it's the one class I didn't write by myself and except for a small change to expose the video framerate I have never touched it.
But first... x264 custom matrices.
20th June 2005, 09:27 | #52 | Link |
Before you get crazy about it - first we should try to find out if the reason is the 'CPAE'* bug.
The second idea: If you are often testing many different setups, a virtual PC might be the perfect solution; install, backup the harddisk file, check out... Some even support temporary disk operations which are discarded when the emulator closes, if I remember right. BOCHS is a free solution, but maybe a bit slow, I'm afraid? __ * CPAE: "Codec Packs Are Evil" |
20th June 2005, 10:31 | #53 | Link |
clueless n00b
what is 'CPAE'*?
ahh.. saw it in your signature. Obviously I don't have time for 20 different setups so basically we need to compare configurations of cases where it fails to find out some common ground. And before I forget, custom matrices are actually already supported since I have added a field to the x264 configuration where you can plug in additional commandline parameters.. just plug in a valid matrix configuration there and you're all set. And those settings are even saved in profiles
20th June 2005, 12:08 | #55 | Link | |
http://www.planetdvb.net/AVSEdit_1.1.1.3.exe there is a reg key where you can define which yv12 decoder to use, it's described in the AVSEdit topic
20th June 2005, 12:24 | #56 | Link |
clueless n00b
@stax: what did you change in the avi opening routines in between the last release where this problem was reported and the last release?
GetFrameOpen certainly seems to point to a decoder problem. And I'm wondering why the problem does not ocurr in VDub.. could it be that it's using homebrewn routines rather than standard VfW ones, at least for certain tasks? I did some more reading and found this: http://www.gamedev.net/reference/pro...file/page4.asp Makes me think the conversion to 24bit could be the culprit. http://www.shrinkwrapvb.com/avihelp/avihlp_3.htmseems to confirm that converting to 24 bit can be problematic.
20th June 2005, 13:12 | #57 | Link | |
there were a couple of different things that could cause trouble, color space, yv12 decoder, color depth and iirc even screen resolution. The functions taking care of it are:
string GetFourCC(int value) { byte[] bytes = BitConverter.GetBytes(value); char[] chars = new char[4]; for (int i = 0; i < bytes.Length; i++) chars[i] = Convert.ToChar(bytes[i]); return new String(chars); } public void Open(string fileName) { try { AVIFileInit(); int OF_SHARE_DENY_WRITE = 32; int result = AVIFileOpen(ref AviFile, fileName, OF_SHARE_DENY_WRITE, 0); if (result != 0) throw new Exception("AVIFileOpen failed"); result = AVIFileGetStream(AviFile, out AviStream, 1935960438 /*FourCC for vids*/, 0); if (result != 0) throw new Exception("AVIFileGetStream failed"); FrameCountValue = AVIStreamLength(AviStream.ToInt32()); StreamInfo = new AVISTREAMINFO(); result = AVIStreamInfo(AviStream.ToInt32(), ref StreamInfo, Marshal.SizeOf(StreamInfo)); if (result != 0) throw new Exception("AVIStreamInfo failed"); if (GetFourCC(Convert.ToInt32(StreamInfo.fccHandler)) == "YV12") FrameObject = AVIStreamGetFrameOpen(AviStream, 1); else FrameObject = AVIStreamGetFrameOpen(AviStream, 0); if (FrameObject == IntPtr.Zero) throw new Exception("AVIStreamGetFrameOpen failed"); } catch (Exception ex) { MessageBox.Show("An error occurred. Maybe no YV12 decoder available, installing XviD, DivX or ffdshow might help.\r\n\r\n" + ex.ToString(), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error); } } Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 20th June 2005 at 13:17. |
20th June 2005, 14:12 | #58 | Link |
clueless n00b
thanks
20th June 2005, 19:54 | #59 | Link |
clueless n00b
@xtknight: I managed to kill your muxer with my test scenarios And I scrapped everything but the idea of starting two threads besides the main processing thread.. but that seems to work as desired, even though mp4box still "runs away".. but at least I get the stdout, and when I'm not debugging I expect the GUI to stay on top of the mp4box process. Now it's time to turn that status window back alive.
21st June 2005, 01:39 | #60 | Link | ||
http://forum.doom9.org/showthread.php?t=94578 Quote:
--------------------- By the way, about that AVIStreamGetFrameOpen open problem..umm..I got that error with MeGUI when I was opening a file with a broken version of AVISynth. Could that be the problem? To catch the errors you must open a new thread because the AVIFile API will crash your main program thread without returning anything IIRC. Last edited by xtknight; 21st June 2005 at 01:46. |
development, megui, not a help thread |
