#361 | Link |
It seems that MeGUI doesn't abort properly from a paused encode. This line:
this.pauseButton.Image = (Image)this.pauseImage; Code:
paused = false; Code:
if (this.paused) // aborting directly causes problems so prevent it 1. Start an encode. 2. Press pause. 3. Press abort. 4. Press start. 5. Press pause. This will cause it to crash, because when it was aborted, MeGUI still believed the current encode was paused. Also, perhaps the priority dropdown in ProgressWindow should have a DropDownList DropDownStyle, so that it isn't editable? Obviously, nothing serious, but I think it looks better that way, since it makes no sense to edit the Priority names anyway. |
#362 | Link |
clueless n00b
![]() Join Date: Oct 2001
thanks for those fixes.. I've integrated them into the latest build
#363 | Link |
clueless n00b
I just posted a few more todo things that I meant to have done before I left for my holidays, but couldn't because I got sick.
#364 | Link |
Mr. Sandman
x264CLI has new switches.
VUI is not so important (--sar was an old option) but "mixed references" is. Maybe it's worth adding it in the "to do" list.
#365 | Link |
I've implemented some of the things on the todo list, as well as fixed some bugs. Rather than list all of the changes here, I've uploaded the updated source code, as well as new compiles. If it turns out that Doom9 has made other changes, I have kept a log of all the changes, so I can list them in the style I normally do.
Bugfixes: -The OneClickWindow doesn't crash when trying to use 'Don't Encode Audio' -DGIndex doesn't crash when aborting jobs -MeGUI won't let you try to open the Process Window when running DGIndex, which would lead to a crash. -root directory bug discussed with haubrija in main MeGUI thread Cosmetics: -MeGUI will give a message if there are jobs queued, but not waiting (eg done or postponed, etc) -Better managing of 'Don't Encode Audio' with the container format dropdown New features: -load simple DGIndex jobs -add '--mixed-refs' option for x264 @edit: removed attachments -- update in next post. Last edited by berrinam; 9th October 2005 at 23:27. |
#366 | Link |
Mr. Sandman
new Adaptive Quantization switches.
they're not in the SVN yet but the AQ patch is included in my builds. Code:
--aq Adaptive quantization
--aq-strength <float> Amount to adjust QP by AQ: 0.0 => no AQ,
1.1 => strong AQ [0.50]
--aq-sensitivity <float> Degree of "flatness" of the MB when AQ starts
to work:
5 => works for almost all blocks,
22 => only flat ones [15.0]
#367 | Link |
Ok, this is the same as last time, but with x264 AQ options.
Anyone know which AVC profile AQ falls under? @edit: Main MeGUI program removed from here, as a new version can be found here Last edited by berrinam; 15th October 2005 at 01:07. |
#368 | Link |
![]() Join Date: Nov 2001
doom9, i found a glitch in meguis x264 settings:
ticking p4x4 mb size should only be allowed when p8x8 is ticked too, cause p4x4 without p8x8 isnt possible
#369 | Link |
Hello!
I'm encoding TV captures in the following steps: 1st step (VirtualDubMod) Encoding captured .avi (mjpeg) via .avs to lossless huffyuv .avi file 2nd step (MeGUI) XVID 1st pass (huffyuv .avi) 3rd step (MeGUI) XVID 2nd step (huffyuv .avi) This give me 20-30% faster TOTAL encoding time. QUESTION: I'm wondering if we can combine the 1st and the 2nd step as described in http://forum.doom9.org/showthread.php?t=84924 and implement this into MeGUI. Example from http://students.washington.edu/loren...synth/avs2yuv/ Concurrent huffyuv and 2 pass encoding (Windows): Warning: this is new and may be buggy. avs2yuv foo.avs -hfyu huffyuv.avi -o - | mencoder - -o NUL: -ovc xvid -xvidencopts pass=1 mencoder huffyuv.avi -o pass2.avi -ovc xvid -xvidencopts pass=2:bitrate=1000 That will probably increase 2-pass XVID encoding when using slow .avs scripts for 20-40%. Maybe this method will be suitable for other codecs (x264...). Any suggestions are welcome. Thanks. |
#370 | Link | ||
http://forum.doom9.org/showthread.ph...554#post720554 But you give it a good try and let us know how faster it compared to avs method (probably same for x264 too). However, the trade off is the lossless huffyuv method might full up the hard disk space very quickly! It only suits for ppl who need to convert videos in limited time with enough of hard disk space. Quote:
#371 | Link | |
TomsMoComp(1,5,1) crop(...) lancsozresize(...) usually I don't get the good result (captured .avi have symptoms like frames were dropped althought VVCR report 0 dropped frames; high CPU or dropped frames is not an issue here). That is the reason why I capture to 768x576, interlaced, MJPEG or HUFFYUV codec with very good final results. I came to idea to encode to filtered HUFFYUV first when exerimenting to capture directly to filtered HUFFYUV when I got an excelent XVID encoding time. Unfortunatelly direct capture to filtered HUFFYUV is not an option for me and for the others (at least for some). |
#372 | Link |
I have problem with MEGUI 0.2.2.6a.
I have set the desired output size with the AutoEncode button to 2CD (1400MB) and the film lenght is 1.50; in the first pass the bitrate is set to "--bitrate -163". What's the mess? I exspect 1500-1800 for the bitrate cos the audio compression takes 128MB This is the log: Generating jobs. Desired size: 1433600 bytes Setting desired size of video to 1433600 bytes Next job job1-1 is an audio job. besweet commandline: "C:\DVD Tools\AAC\BeSweet.exe" -core( -input "C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.AC3" -output "C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.mp4" -logfile C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.besweet.log ) -azid( -s stereo -c normal -L -3db ) -dimzon( -dllname bse_FAAC.dll -q 120 ) -ota( -d 16 -g max ) successfully set up audio encoder and callbacks for job job1-1 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 besweet: "C:\DVD Tools\AAC\BeSweet.exe" -core( -input "C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.AC3" -output "C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.mp4" -logfile C:\Scambio\Elaborazione Video\Febbre\VTS_01_1 - 0x80 - Audio - AC3 - 6ch - 48kHz - DRC - Italiano - DELAY 16ms.besweet.log ) -azid( -s stereo -c normal -L -3db ) -dimzon( -dllname bse_FAAC.dll -q 120 ) -ota( -d 16 -g max ) BeSweet v1.5b31 by DSPguru. -------------------------- [00:00:00:000] Initializing... [00:00:00:000] -- Initializing... [01:50:42:496] | [00:00:00:016] Adding silence.. [01:50:42:512] Finalizing... [01:50:42:512] Conversion Completed ! Visit DSPguru's Homepage at : http://DSPguru.doom9.net/ ---------------------------------------------------------------------------------------------------------- job job1-1 has been processed. This job is linked to the next job: job1-2 this series of jobs starts with an audio job and is followed by regular twopass video jobs The audio job is named job1-1 the first pass job1-2 and the second pass job1-3 The second pass job has a desired final output size of 1433600 bytes and video bitrate of 700 kbit/s The size of the first audio track is 135051582 bytes Desired video size after substracting audio size is -132172Setting the desired bitrate of the subsequent video jobs to -163 kbit/s Next job job1-2 is a video job. encoder commandline: "C:\Programmi\x264\x264.exe" --pass 1 --bitrate -163 --stats "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.stats" --ref 5 --mixed-refs --bframes 3 --subme 6 --weightb --analyse all --8x8dct --me umh --threads 2 --cqmfile "C:\Programmi\x264\eqm_avc_hr.cfg" --progress --no-psnr --output NUL "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.avs" successfully set up video encoder and callbacks for job job1-2 |
#373 | Link |
I have tried another time but in my opinion there is a problem:
Generating jobs. Desired size: 1433600 bytes The second pass job has a desired final output size of 1433600 bytes and video bitrate of 1637 kbit/s The size of the first audio track is 135051582 bytes Desired video size after substracting audio size is -132172Setting the desired bitrate of the subsequent video jobs to -163 kbit/s Next job job1-2 is a video job. encoder commandline: "C:\Programmi\x264\x264.exe" --pass 1 --bitrate -163 --stats "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.stats" --ref 5 --mixed-refs --bframes 3 --subme 6 --weightb --analyse all --8x8dct --me umh --threads 2 --cqmfile "C:\Programmi\x264\eqm_avc_hr.cfg" --progress --no-psnr --output NUL "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.avs" successfully set up video encoder and callbacks for job job1-2 |
#374 | Link |
MEGUI 0.2.2.5 has no problem. I don't understand the sense of this phrase "The size of the first audio track is 135051582 bytes", infact compressed audio track has a size of 128 MB. I suppose that from 0.2.2.6 there is some bug in substracting compressed audio track size from desired movie size in the code of the autoencode button.
#376 | Link | |
I set 1400 MB for the final video size Perhaps the problem is here: 0.2.2.6 10/06/2005 new: dgindex processing is now handled as a regular job. This allows queueing of multiple dgindex jobs, and thus the one click mode can process multiple movies after another, including the dgindex phase. changed: desired size in the autoencode window has been changed to MBs instead of KBs changed: .sub input has been replaced by .idx input for Subtitle muxing into mkv bugfix: aborting paused jobs and restarting them no longer causes a crash bugfix: moving jobs up/down works properly again Last edited by max-holz; 13th October 2005 at 20:27. |
#378 | Link | |
Program avs2yuv.exe version 0.24 is not compatible with the new version of mencoder. We must change the line in avs2yuv.cpp Code:
sprintf(cmd, "mencoder - -o \"%s\" -quiet -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-1:pred=2:context=1", hfyufile); Code:
sprintf(cmd, "mencoder - -o \"%s\" -quiet -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-2:pred=2:context=1", hfyufile); Code:
vstrict=-1 --> vstrict=-2 The following lines are fully working (mencoder.exe 2005-10-09 and avs2yuv.exe 0.24.01 (modified version) must be in the system path (example SETPATH=c:\mplayer\)) ![]() Code:
avs2yuv foo.avs -hfyu huffyuv.avi -o - | mencoder - -o NUL: -ovc xvid -xvidencopts pass=1:<other_settings> mencoder huffyuv.avi -o pass2.avi -ovc xvid -xvidencopts pass=2: <other_settings> What is the context=1 switch? Adaptive Huffman tables? I can't find anywhere what is this switch. Is it faster to read huffyuv .avi file with or without avi-index if we read .avi with mencoder only from the beginning to the end (frame 1,2,3…x)? Is this command line in avs2yuv.cpp Code:
mencoder foo.avs -o foo.avi -quiet -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-1:pred=2:context=1" My next mission is to test 2-pass XVID encoding speed difference between standard .avs+mencoder encoding and avs2yuv+.avs+huffyuv+mencoder encoding when the source is 768x576, interlaced and the final result is 512x384, deinterlaced source. TEST case source Code:
trimmed SouthPark cartoon 7501 frames 768x576 interlaced MJPEG (Q=19) Code:
TomsMoComp(1,15,1) crop(8,6,752,564) Lanczos4Resize(512,384) Code:
mencoder "sp.avs" -ovc xvid -o NUL: -passlogfile "sp.stats" -xvidencopts pass=1:bitrate=1360:max_key_interval=300:packed:vhq=1:qpel:chroma_me:trellis:min_iquant=1:min_pquant=1:min_bquant=1:keyframe_boost=100:kfthreshold=1:kfreduction=20 mencoder "sp.avs" -ovc xvid -passlogfile "sp.stats" -xvidencopts pass=2:bitrate=1360:max_key_interval=300:packed:vhq=1:qpel:chroma_me:trellis:min_iquant=1:min_pquant=1:min_bquant=1:keyframe_boost=100:kfthreshold=1:kfreduction=20 -o "sp_xvid.avi" -of avi -ffourcc XVID XviD 1st pass = 523s (14.34 fps) XviD 2nd pass = 969s (7.74 fps) TOTAL = 1492s Code:
avs2yuv "sp.avs" -hfyu "sp_hfyu.avi" -o - | mencoder - -ovc xvid -o NUL: -passlogfile "sp.stats" -xvidencopts pass=1:bitrate=1360:max_key_interval=300:packed:vhq=1:qpel:chroma_me:trellis:min_iquant=1:min_pquant=1:min_bquant=1:keyframe_boost=100:kfthreshold=1:kfreduction=20 mencoder "sp_hfyu.avi" -ovc xvid -passlogfile "sp.stats" -xvidencopts pass=2:bitrate=1360:max_key_interval=300:packed:vhq=1:qpel:chroma_me:trellis:min_iquant=1:min_pquant=1:min_bquant=1:keyframe_boost=100:kfthreshold=1:kfreduction=20 -o "sp_xvid.avi" -of avi -ffourcc XVID XviD 1st pass = 660s (11.37 fps) XviD 2nd pass = 581s (12.91 fps) TOTAL = 1241s Code:
The 2nd method is 251s (17%) faster. This should be an alternative option in future MeGUI version. It could improve (slow) encoding time for other codecs too.
#379 | Link | |
@zajc: While this may be interesting, it is not exactly related to MeGUI, is it?
Also, as Doom9 has said here, Quote:
| Tags |
| development, megui, not a help thread |
| Thread Tools | |
| Display Modes | |
