Old 12th September 2007, 16:51   #3001  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Sorry but...what is the relationship between MediaInfo(wrapper) and the avs preview ? because I'm pretty sure that the lib doesn't have an avs parser.
@nk : Vista 32 or 64 bits ?
Old 12th September 2007, 17:23   #3002  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Originally Posted by bob0r View Post
Hmm cool, maybe better to remove ANY spaces on SVN for any file or dir, for my auto scripts its very annoying
http://megui.svn.sourceforge.net/vie...gui/Installer/
Old 13th September 2007, 13:58   #3003  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
    - (Sharktooth) New MeGUI icons and installer fixes
    - (Kurtnoise) [JobQueue] : scrollbar fix (#1793456)
    - (Kurtnoise) [AudioEncoder] : fix mp2 bitrate command line for the new FFmpeg builds.
    - (Kurtnoise) Better label names for some encoders.
    - (Kurtnoise) Cosmetic : added m2ts extension.
    - (Kurtnoise) Removed resize event.
Old 13th September 2007, 14:48   #3004  |  Link
Kurtnoise
Kurtnoise's Avatar
you should wait before to submit new release dude...
coz, bugs tickets 1677527, 1749803, 1791912, 1793313 can be closed now.
btw, Vista issues suck...I need to reinstall this OS to debug the GUI. blahhhhh.
Old 13th September 2007, 15:04   #3005  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
get some virtualization software.
im also thinking to install vista to test megui issues... just for that...
however ill release a new build later...
Old 13th September 2007, 15:21   #3006  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
here we go:
    - (Kurtnoise) [MainForm] fixed minimize to tray (#1749803)
http://sourceforge.net/project/showf...kage_id=244469
Old 13th September 2007, 16:49   #3007  |  Link
Kurtnoise
Kurtnoise's Avatar
I don't like very much virtualization tools to debug applications but this is an other story.
Questions for you:
  • About yadif : we should add it in the server and/or Update Window Form or not ?
  • If I add Aften, should I drop the FFmeg AC3 part/code or not ?
Old 13th September 2007, 16:54   #3008  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yadif is already in the autoupdate and the updatewindow has an entry for it. are you having problems getting it from the autoupdate?
I would keep both Aften and ffmpeg AC3. we have even 3 AAC encoders...
Old 13th September 2007, 17:02   #3009  |  Link
Kurtnoise
Kurtnoise's Avatar
well...it's not in the ListView for me.
About Aften : it uses the same encoder engine. That's why I ask...
Old 13th September 2007, 17:05   #3010  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Its not in the listview coz its not in the avisynth filters section. since it's a C-Plugin its treated (and shown in the listview) as an external program.
about aften... i think ffmpeg is safer to "mantain"... i mean, aften is a small project and one day it may die, while ffmpeg is a solid project...
Old 13th September 2007, 17:20   #3011  |  Link
Kurtnoise
Kurtnoise's Avatar
well...the problem is outwhere I think. I can't see it when I select the 1st node in the TreeView (the complete list).
Old 13th September 2007, 17:34   #3012  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm... try deleting the settings.xml file inside the megui installation folder
if it doesnt still show up delete also the autoupdate.xml file
or just reinstall megui in another dir
Old 13th September 2007, 17:43   #3013  |  Link
Kurtnoise
Kurtnoise's Avatar
same problem...this link (http://mewiki.project357.com/auto/) is the correct one for the development ?
coz I can't select the web link...
whereas they are listed in settings.xml. Weird...:s
next discussion about this issue here.
Old 13th September 2007, 17:51   #3014  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
no.. the autoupdate is located at http://megui.org/auto/ (dev) and http://megui.org/auto/stable/ (stable)
... however i cant see the servers too... but it updates regularly... damn bugs...
Old 13th September 2007, 20:54   #3015  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Yadif goes to the Avisynth plugin directory for me and then when there is a new update I get a message telling me that the path is incorrectly set for yadif.dll until I set it manually.
saint-francis is offline   Reply With Quote
Old 14th September 2007, 13:50   #3016  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yadif should not go to the avs plugin dir... nowhere in the code nor in the autoupdate there's something that tells megui to place it there...
Old 14th September 2007, 15:12   #3017  |  Link
bob0r
Pain and suffering
bob0r's Avatar
This is the dev server:
Trying server: http://mewiki.project357.com/auto/
Retrieving update file from server...
After restart:
Trying server: http://megui.org/auto/
Nothing shows any update to yadif09.zip
Not even 0.2.6.1014
bob0r is offline   Reply With Quote
Old 14th September 2007, 15:14   #3018  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yeah... the mewiki is having troubles though...
Old 14th September 2007, 19:00   #3019  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Why not? It doesn't hurt anything, you just won't be able to autoload it. (Unless you also create an avsi to go alongside it that does nothing but load it.)
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 14th September 2007, 22:02   #3020  |  Link
saint-francis
too much lurking
Then where should it go?
development, megui, not a help thread
