Old 10th September 2007, 15:26   #2981  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Uhm, you are the author?
former x264 installer script?
bob0r is offline   Reply With Quote
Old 10th September 2007, 15:30   #2982  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Uhm, on the update server, isn't it a bad thing to use old LIBS for 0.2.6.1010+ ? Won't this create conflicts?
Old 10th September 2007, 15:38   #2983  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
LOL! ok.
however the libs are fine. there will be no conflict.
Old 10th September 2007, 15:44   #2984  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Hmm, ok, good to know, 0.2.6.1010 added to x264.nl with new installer and some files removed that were no longer used!
Please fix the New Updates Available Pop-UP popping up behind the main window issue... it has annoyed me from day one
..... now all we need is a: MEGUI LOGO!
Old 10th September 2007, 15:55   #2985  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
eh...
Old 10th September 2007, 16:52   #2986  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
AviSource won't open Avis with MJPEG compression, MPEG2 and so on. In case of error MeGUI should switch to DirectShowSource()
Old 10th September 2007, 16:55   #2987  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
That's tricky... however it will be able to do that if you have the respective VFW decoders installed and working (in ffdshow VFW config enable MPEG in AVI and MJPEG)
Old 10th September 2007, 16:58   #2988  |  Link
Atak_Snajpera
I've already fixed that in my GUI but I use Delphi so I cannot help you further
Old 10th September 2007, 16:59   #2989  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it's not necessary. also it's tricky coz megui workflow codebase is more complex.
Old 10th September 2007, 18:01   #2990  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
    - (Sharktooth) [OneClick] Audio Track 2 is disabled by default unless "Show Advanced Options" is checked.
    - (Sharktooth) [Autoupdate] Check if yadif.dll path was set before trying to update it...
also available here: http://sourceforge.net/project/showf...roup_id=156112
Old 11th September 2007, 14:12   #2991  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i've put the latest CD's build in the auto-update (dev) server. Please test if it works correctly.
Old 11th September 2007, 15:42   #2992  |  Link
bob0r
Pain and suffering
bob0r's Avatar
0.2.6.1011
1: you put start menu shortcut to point to: "C:\Program Files\trunk\dist\bigdist\megui.exe"
2: The Updates Available pop-up still pop ups behind the main window.
3: you cannot set yadif.dll path, because when you browse for it, you need the actual file.
Just set one default path for all none set program files?
%installdir%/tools would be a good place to dumb stuff
- Muxer/avimux_gui.exe also has no path set
- Audio/neroAacEnc.exe also has no path set
- Audio/besplit.exe also has no path set
Maybe just set default path to C:\Program Files\megui\tools\
Or C:\Program Files\megui\tools\<program name>\ for each .dll or .exe
icon for installer:
http://x264.nl/x264.ico (you already have it seems)
http://x264.nl/x264.bmp the logo inside the installer, use for dimensions to create your own! (now it looks ugly/weird)
Old 11th September 2007, 16:11   #2993  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
installer should be fixed.
i will put a new build up...
however i dont really know why the autoupdate pop-up just pops "under"...
Old 11th September 2007, 16:19   #2994  |  Link
nk
MediaInfoWrapper.dll
I can't see preview with new version of MeGUI)0.2.6.1011), becase of MediaInfoWrapper.dll.
If I use old version of MediaInfoWrapper.dll, I can see preview.
nk is offline   Reply With Quote
Old 11th September 2007, 16:34   #2995  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
    - (Sharktooth) [Autoupdate] Removed yadif.dll path check since it was impossible to set the path without already having yadif.
    - (Sharktooth) Various Installer fixes.
@bobor: the installer stuff is located here: http://megui.svn.sourceforge.net/vie...ller%20script/
Old 11th September 2007, 16:34   #2996  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
are you sure? it works pretty well here.
are you on XP or Vista?
Old 11th September 2007, 18:06   #2997  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Hmm cool, maybe better to remove ANY spaces on SVN for any file or dir, for my auto scripts its very annoying
Just add _ or . or just remove spaces
I have added 0.2.6.1012 to x264.nl, if developement will be continuous again, ill have a script auto update once a day.
The more testers the better!
Old 11th September 2007, 22:54   #2998  |  Link
nk
Vista. If it happens only on my environment, maybe something wrong with my envirnment.
This problem also happend at old version (I forgot version number, but not recent).
Additional Information:
MediaInfoWrapper(0.7.5.3 maybe latest version) does not properly work on my environment.
0,7.4.4 works fine.
If I open some avs file for video, an error dialog pops. It says wrong color space. But avs file's
color space is YV12.comverttoyv12() does not help me
Old 12th September 2007, 02:36   #2999  |  Link
MarcioAB
MarcioAB's Avatar
Is there any chance to see adaptive Q parms (--aq-strength and --aq-sensitivity) on MeGUI ?
Who knows why "adaptive Q" is not official in x264 (IMHO it should be) but anyway: it works great (at least for me).
It deserves a much better space in "Quantizers" Advanced tag than a "Custom Commandline Options" in Zones tag.
Thank you.
MarcioAB is offline   Reply With Quote
Old 12th September 2007, 14:03   #3000  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@MarcioAB: NO. i already explained it in another thread and i also explained how to use those options with megui.
http://forum.doom9.org/showthread.php?t=129813
please dont crosspost.
@nk: thanks, i'll try to investigate the problem but i havent vista for testing...
development, megui, not a help thread
