Old 22nd March 2006, 07:47   #2001  |  Link
berrinam
berrinam's Avatar
0.2.3.2115 22 March 2006
Commit by berrinam:
  - Source Detection now runs with the priority specified by the settings.
  - Script Generation window is now smaller through the use of tabs.
berrinam is offline   Reply With Quote
Old 22nd March 2006, 12:29   #2002  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
0.2.3.2116 22 March 2006
Commit by dimzon:
  - New tab - Changelog.txt.
dimzon is offline   Reply With Quote
Old 22nd March 2006, 14:13   #2003  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
CVS Update:
Updated compile.bat. It now creates a "Dist" directory and will copy all the necessary files for MeGUI binaries distribuition.
SF binaries are up to date too.
Old 22nd March 2006, 16:56   #2004  |  Link
IMOON
solution for the shutdown problem
I think the prblem is in the "UpdateGUIStatus" function.
You dont check if next job was started or not, you only check if the current complete job has an error or if the queue was stoped.
here my solution, I have tested it and seems to work.
code from form1.cs in the UpdateGUIStatus function.
private void UpdateGUIStatus(StatusUpdate su)
	    int nextJobStart = 0;
                if (continueStatus <= 2 && this.queueEncoding)
		nextJobStart = startNextJobInQueue(); //new with the return value to check if there was another job
		else
			nextJobStart=2;
		if (nextJobStart == 2) {	//new test if this was the last job or a job was stoped
			this.isEncoding = false;	//moved out the else before
			this.queueEncoding = false;
			this.startStopButton.Text = "Start";
			this.abortButton.Enabled = false;
			this.shutdown();
IMOON is offline   Reply With Quote
Old 22nd March 2006, 18:21   #2005  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
great job. it works.
ChronoCross is offline   Reply With Quote
Old 22nd March 2006, 18:45   #2006  |  Link
Doom9
clueless n00b
Question for you guys: since at the moment I just can't get myself to finish the work started, is anybody willing to look at the half-finished code? Mainly what's missing is a "codec" -> outputtype finder that goes along with the outputtype -> container finder and then integrate this into the autoencode and one click guis, and creating the proper mux jobs. It's not quite trivial but it's probably better if somebody else has a crack at it or this will loom over our heads for some time to come.. the work situation is going to get any better for the foreeable future.
Doom9 is offline   Reply With Quote
Old 22nd March 2006, 18:49   #2007  |  Link
dimzon
dimzon's Avatar
I can take look @ it
Old 22nd March 2006, 20:06   #2008  |  Link
max-holz
But cvs is working? No update in the public one for version 2115 and 2116
max-holz is offline   Reply With Quote
Old 22nd March 2006, 20:07   #2009  |  Link
ChronoCross
they only updated it this morning. it can take up to 8 hours for it to update. Be patient. I already posted another build.
Old 22nd March 2006, 20:41   #2010  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
CVS Update:
0.2.3.2117 22 March 2006
Commit by Sharx1976:
- Fixed the shutdown problem (patch by IMOON).
Old 22nd March 2006, 20:45   #2011  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
you can always find updated sources here:
http://files.x264.nl/Sharktooth/?dir=./megui/Sources
Old 23rd March 2006, 10:03   #2012  |  Link
berrinam
berrinam's Avatar
Thinking about the current system we have for AR signalling, I realised just how unreliable it is -- it only sets the AR if you encode the script immediately after creating it. This means that the unsuspecting user might create the script, then encode it some days later, and be surprised to discover that the AR turned out wrongly. I remembered dimzon's idea from back here and I wanted to see what the conclusion on that was. Turns out, after an initial no by Doom9* and a yes by Sharktooth, it seems to just have been forgotten. I want to say now that I also think this is a good idea, and from a design viewpoint, it also makes sense; information about the source file should be contained in the source file, and since AviSynth can't signal AR, then it is up to us to create some form of compromise (unless there is a way to communicate directly with avisynth.dll so that the filters can keep track of the AR, but I suspect that would be too complex).
Just for reference, here is the suggestion that dimzon made:
Originally Posted by dimzon
Maybe we can add some magic macros to avs script? Something like
bla bla bla
bla bla bla
# $MeGUI_SAR(1.34)
and analyze avs when opening?
*Doom9 initially said no, but he was away for a while after dimzon's explanation of why, so I wanted to bring this up again. What do you think?
Old 23rd March 2006, 10:40   #2013  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
you know i like it and a lot of useful things can be done thru "macros".
for example you can even set codecs and their settings (usefull for debugging)...
Old 23rd March 2006, 14:57   #2014  |  Link
sysKin
sysKin's Avatar
At least in my case, I first create a script and then load a codec profile, which effectively ruins all AR calculations every time.
The only solution I can see is to redesign whole AR thing - it's not a codec setting at all, it's a picture setting.
Unfortunately I have no good ideas how to do that properly
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 23rd March 2006, 18:57   #2015  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
@berrinam - I would prefer to see us read it from a "magic variable" instead of a "magic comment." That way we can use the Avisynth scripting language to calculate the AR for us. For example, I often use this function:
function ResizeAR(clip c, int "dest_x", int "dest_y", string "ar")
	Assert(!ar.Defined || ar.LCase == "sar" || ar.LCase == "dar",
			\ "rb-ResizeAR: If defined, 'print' must be 'sar' or 'dar'.")
	dest_x = default(dest_x, c.width)
	dest_y = default(dest_y, c.height)
	dest_ar = float(dest_x)/dest_y
	dar = (float(c.width)/c.height) * (4320./4739)
	sar = dar / dest_ar
	out = c.LimitedSharpen(dest_x = dest_x, dest_y = dest_y)
	return !ar.Defined ? out : out.SubTitle(ar + ": " + string(eval(ar)))
It would be great if instead of printing the AR on the screen for manually typing into MeGUI, I could just stick the result into a magic variable.
Richard Berg is offline   Reply With Quote
Old 23rd March 2006, 23:07   #2016  |  Link
berrinam
berrinam's Avatar
I like that idea. While it is easier to calculate dars with floats, integers are used by most encoders. I propose that AviSynth scripts with AR signalling have two globals: outputDARX and outputDARY. MeGUI could read those globals and pass them directly on. We can then make two AviSynth script functions to manage that: SignalFloatDAR(float DAR) and SignalDAR(int x, int y), the first of which would convert the float to a fraction, and the second of which would just save x and y as outputDARX and outputDARY respectively.
Old 24th March 2006, 17:37   #2017  |  Link
ChronoCross
@devs
I did some work this week with mencoder compiling and finally managed to make a good working version specifically for megui using a MingW workaround for largefiles from the mplayer mailing list. It has xvid 1.1 final and libavcodec only everything else is disabled. This works well since megui only uses it for xvid and huffy.
I played around with the commandline for pre-rendering. Here's what I found.
"D:\OFFICE_SPACE\VIDEO_TS\Office.avs" -o "D:\OFFICE_SPACE\VIDEO_TS\hfyu_Office.avi" -of avi -forceidx -noodml -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-2:pred=2:context=1
Works only for lossless under 4GB(approx a single episode of an anime 24-25Mins). Once it hits the 4GB barrier it no longer produces a valid avi file. However the following command line works for all sizes.
"D:\OFFICE_SPACE\VIDEO_TS\Office.avs" -o "D:\OFFICE_SPACE\VIDEO_TS\hfyu_Office.avi" -of avi -forceidx -ovc lavc -lavcopts vcodec=ffvhuff:vstrict=-2:pred=2:context=1
I think the second one should be used. I will be posting the mencoder I built for megui later today. It's just a matter of removing the -noodml switch.
Old 24th March 2006, 17:46   #2018  |  Link
Doom9
clueless n00b
@ChronoCross: mencoder for xvid encoding is at a dead end.. the next stable version won't support it anymore.
Old 24th March 2006, 17:59   #2019  |  Link
ChronoCross
Understood. In the current megui it's actually the method I prefer. With xvid_encraw not being totally stable yet(I'll do some tests later to try it out more) I think the important thing is the large file support for lossless in huffy. I can remove the xvid compilation at any time.
Old 24th March 2006, 18:15   #2020  |  Link
dimzon
dimzon's Avatar
So it's time to change project name, isn't it?
development, megui, not a help thread
