Old 20th November 2007, 21:38   #741  |  Link
tsp
tsp's Avatar
some more test, same source as before:
setmtmode(2)
AVISource("D:\simH264.avi")
changefps(last,last,true)
94 sec (106 fps)
(so just as good as with no multithreading)
MT("fft3dfilter()",2,8)
521 sec (19,2 fps) slightly better than using setmtmode(2) but still fft3dfilter doesn't scales to well.
532 sec (18,8 fps) slightly slower. No surprise as MT() split the frame in two and process each part in a separate thread so it is sequential access even without changefps (same story for fft3dfilter(ncpu=2))
setmtmode(5)
setmtmode(2)
fft3dfilter()
548 sec (18,2 fps) without changefps() 536 sec (18,7 fps). Again slower with changefps() and still slower than mt() (probably due to fft3dfilters intertal fft cache).
and now for a medium weight filter spline16resize
Spline16Resize(640,480)
154 sec (64,9 fps)
setmtmode(2)
172 sec (58,1 fps) slower than without multithreading due to non sequential access.
setmtmode(5)
setmtmode(2)
357 sec! (28 fps) ouch even worse, so always using mode=5 for avisource is not a good idea.
setmtmode(5)
setmtmode(2)
117 sec (85,5 fps) large improvement suggesting that non-sequential access is the culprit.
setmtmode(2)
105 sec (95,2 fps) fastest time.
so changefps(last,last,true) is most efficient when used with fast scripts while it makes the script slower in slow scripts.
Also I noticed that changefps made the largest difference in script where the fps was very unstable.
Get my avisynth filters @ http://www.avisynth.org/tsp/
tsp is offline   Reply With Quote
Old 20th November 2007, 23:12   #742  |  Link
IanB
Avisynth Developer
Hmm, there is something else going on here, ChangeFPS should be a zero cost filter, all it does is enforce sequential access within a 10 frame range forwards. It should never make things worse. Maybe the Cache behind it is not strong enough and is faulting, negating the sequential access protection. Hmmmmm
IanB is offline   Reply With Quote
Old 21st November 2007, 18:30   #743  |  Link
tsp
tsp's Avatar
repeated the test with setmemorymax(1500). The difference between AVISource("D:\simH264.avi").changefps(last,last,true).MT("fft3dfilter()",2,2) and AVISource("D:\simH264.avi").MT("fft3dfilter()",2,2) is down to 2-3 sec. So more or less insignificant.
Old 22nd November 2007, 04:42   #744  |  Link
IanB
Avisynth Developer
@tsp,
Are 2 and 5 the best modes to use here with changefps(last,last,true) and are we putting them in the right place? We just want to ensure the AviSource filter gets hit strictly in order. We do not want any incidental interlocking on the cache between changefps and avisource.
If the request order into changefps is 2, 1, 0, 5, 4, 3, ... the expected request order into the next cache should be 0, 1, 2, 1*, 0*, 1*, 2*, 3, 4, 5, 4*, 3*, ... where the entries marked with * should be cache hits. thus the request order into avisource should be 0, 1, 2, 3, 4, 5, ...
Old 23rd November 2007, 08:58   #745  |  Link
Delerue
tsp and Fizick, I'm trying to use MVFlowFPS script (from MVTools 1.8.5.1) with this code inside the FFDShow (v. 1620) Avisynth tab:
LoadPlugin("C:\Arquivos de programas\AviSynth\plugins\MT.dll")
source=ffdshow_source()
SetMTMode(2)
LoadPlugin("C:\arquivos de programas\avisynth\plugins\mvtools.dll")
backward_vec = source.MVAnalyse(blksize=16, isb = true,  pel=2, search=2, idx=1)
forward_vec = source.MVAnalyse(blksize=16, isb = false, pel=2, search=2, idx=1)
source.MVFlowFps(backward_vec, forward_vec, num=2*FramerateNumerator(source), \
   den=FramerateDenominator(source), mask=1, idx=1)
Although it works, I mean, it doubles the FPS, the second CPU/thread still inactive (I'm using an Allendale E4300 running at 3 GHz).
I also tried this (from Fizick website, just to test), but I got a script error (invalid arguments to function 'MT', last line):
global idx1 = 10  # global hint by IanB
MT("""
idx1 = idx1 + 1
# different threads for top and bottom half of frame must have different idx (trick by Foxishadis)
backward_vec2 = MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = idx1)
backward_vec1 = MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = idx1)
forward_vec1 = MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = idx1)
forward_vec2 = MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = idx1)
last.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400,idx=idx1)
""",2) # two threads
I copied the 'avisynth.dll' to the 'system32' folder, and the 'MT.dll' to the 'AviSynth\plugins' folder, inside the 'program files' folder. Any idea?
Thanks!
P.S.: Fizick, as you can see, your latest MVTools can finally works using the 'num=2*FramerateNumerator(source)' command with FFDShow.
Delerue is offline   Reply With Quote
Old 23rd November 2007, 18:38   #746  |  Link
tsp
tsp's Avatar
Delerue: Try this version:
SetMtmode(5)
SetMTMode(2)
distributor()
and this:
function MVD(clip c)
idx1 = idx1 + 1
backward_vec2 = c.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = idx1)
backward_vec1 = c.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = idx1)
forward_vec1 = c.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = idx1)
forward_vec2 = c.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = idx1)
return c.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400,idx=idx1)
MT("""MVD(source)""",2) # two threads
put please note that using MVTools with MT() is not always good as MT() split the frame in two parts and process each part in a separate thread so MVTools can't motion compensate if the motion occurs from one part of the frame to the other part.
It is better to use SetMTmode(2)
IanB: mode=5 should be the best but my speed test indicate otherwise. I will repeat them to see if it is just random variation.
Old 23rd November 2007, 19:53   #747  |  Link
Delerue
[code1]
put please note that using MVTools with MT() is not always good as MT() split the frame in two parts and process each part in a separate thread so MVTools can't motion compensate if the motion occurs from one part of the frame to the other part. It is better to use SetMTmode(2)
Thanks, man! It works, but there's something strange. Although the second thread is activated now, the total CPU usage rarely goes beyond 50% and never beyond 60%, so forbidding the script to actually double the FPS in some heavy videos. It seems that the 'job division' isn't good enough, or something like this. I tried to play with other modes, but didn't help. Do you have a faster dual-core CPU to test this script?
Also, I want to congratulate you and Fizick once more. You're making an amazing job, and the 24 FPS movies problem are going soon even with HD videos.
Old 23rd November 2007, 20:19   #748  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
source=...
Please be correct. It is NOT exact script from my website (original works well).
"source" is not used by you.
tsp, sorry for many mvtools staff in your thread
Old 23rd November 2007, 21:02   #749  |  Link
Delerue
Well, I used source in this line 'source=ffdshow_source()'. I only adapted to use with FFDShow. I can't see what you're talking. Anyway, the second tsp script doesn't work either.
Well, we're talking about MT plugin as well.
Old 24th November 2007, 21:47   #750  |  Link
tsp
tsp's Avatar
Yes with two threads it looks like it hits a limit about 60 % cpu utilization. Just double the number of threads will fix that (at least it did for me from 60% to 90 %).
try this version:
SetMtmode(2,4)
source=changefps(source,source,true)
distributor()
What is the problem with the second script? Try SetMtmode(2) instead of MT()
Old 25th November 2007, 00:46   #751  |  Link
Delerue
try this version:
[code]
Wow! That's for real! I tried with your script and the CPU usage indeed goes beyond 90%. But there is some problems with four threads here when the CPU usage is high (but still not 100%). I noticed some stutter, glitches and other weird things, specially in scenes with too much camera movements. So I tried 5 threads, and it worked perfectly.
About the other script, I'll try later.
Thanks once more.
Old 26th November 2007, 20:11   #752  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Livesms from russian forum post report about artifactes with script:
SetMTmode(2)
AviSource("TV.avi")
AssumeTFF()
MVDegrain2i(4,0,1)
TomsMoComp(-1,15,1)
Crop(8,6,-8,-6).Lanczos4Resize(512,384)
FadeIO(25)
function MVDegrain2i(clip "source", int "overlap", int "dct", int "idx")
	overlap=default(overlap,0) 		# величина перекрытия value (от 0 до 4 для blksize=8)
	dct=default(dct,0) 			# используйте dct=1 для клиров с некоторыми мерцаниями
	idx=default(idx,1)			# используйте различные idx для разных источников в том же скрипте
	fields=source.SeparateFields() 	# разделим на поля
	backward_vec2 = fields.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=overlap, idx = idx,dct=dct)
	forward_vec2 = fields.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=overlap, idx = idx,dct=dct)
	backward_vec4 = fields.MVAnalyse(isb = true, delta = 4, pel = 2, overlap=overlap, idx = idx,dct=dct)
	forward_vec4 = fields.MVAnalyse(isb = false, delta = 4, pel = 2, overlap=overlap, idx = idx,dct=dct)
	fields.MVDegrain2(backward_vec2,forward_vec2,backward_vec4,forward_vec4,thSAD=400,idx=idx)
	Weave()
around 96 frame at:
http://dump.ru/files/n/n53176759/
press "Скачать" button near center under this link
Old 26th November 2007, 20:45   #753  |  Link
tsp
tsp's Avatar
Fizick: Is the sample the result of the above script or the source for the script?
IanB: After some more test the most optimal mode appears to be:
setmtmode(5)
setmtmode(2)
even with a MJPEG encoded file.
Old 26th November 2007, 22:51   #754  |  Link
IanB
Avisynth Developer
@tsp,
So this will results in multiple instances of ChangeFPS all individually asserting linear access apon a gate5 cache into an interlocked AviSource. The gate5 cache will probably be thrashed very hard but it's all pointer shuffling without much bulk data copying, so its okay.
Old 26th November 2007, 23:14   #755  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
tsp,
it is result.
does TomsMoComp(-1,15,1) work with setmtmode?
Old 27th November 2007, 06:47   #756  |  Link
Livesms
Livesms's Avatar
tsp
I'll try to upload original video and encoded.
This night I left my Core2Duo E6600 encoding two more video.
I'll check it in a hour...
Livesms is offline   Reply With Quote
Old 27th November 2007, 13:33   #757  |  Link
Livesms
Livesms's Avatar
Original video is too huge for my GPRS internet connection.
I've done some test and found SetMTMode(2) to work incorrectly with MVDegrain2 script for MVTools documentation.
Simple one thread MVDegrain2 (without MT), MVDegrain2 with SetMTMode(4) and MVDegrain2 with SetMTMode(5) produce output video without any artifacts, while SetMTMode(2) + MVDegrain2 and SetMTMode(5) + AviSource + SetMTMode(2) + MVDegrain2 do have some problems.
So I tried to look closely to SetMTMode(4) and MTi(). Here is the results:
 Source:
  * FourCC: YV12
  * Frames: 1003
  * Resolution: 512x384
  * Frame rate: 25.000 FPS
SetMTMode(2)
Destination:
  * Pass 1/1: Finished in 00:02:44.819 (6.09 FPS)
  * Frames: 1003 (1003 keyframes)
  * Memory: 121 788 MB
SetMTMode(4)
Destination:
  * Pass 1/1: Finished in 00:02:48.024 (5.97 FPS)
  * Memory: 144 252 MB
MTi()
Destination:
  * Pass 1/1: Finished in 00:02:57.276 (5.66 FPS)
  * Memory: 160 340 MB
So MTi() uses more memory than any of script using SetMTMode() and gives no speed increase comparing to SetMTMode(2) or SetMTMode(4)
SetMTMode(4) is 2% slower than SetMTMode(2) in my test. 1000 frames clips denoise time increased with 795ms. SetMTMode(4) uses more memory than SetMTMode(2) – 144252MB comparing to 121788MB.
Allowing 2% speed decrease and 15% more memory usage (comparing to SetMTMode(2)), it is necessary to check SetMTMode(4) + MVDegrain2().
In the moment my PC is encoding two more video (2pass xvid) with SetMTMode(2) and SetMTMode(4) in search of errors...
Old 27th November 2007, 20:51   #758  |  Link
IanB
Avisynth Developer
@Livesms,
Do you have base timings for the above script i.e. without MT?
It is important to know how much boost you are getting. i.e. 3fps to 6fps would be fantastic, 5.9fps to 6.0fps indicates some development work is still needed.
Old 27th November 2007, 22:19   #759  |  Link
tsp
tsp's Avatar
Livesms: Is it the same script Fizick posted?
Fizick: From ToMoComp's source code it looks like it should be compatible with SetMtMode(2) (No non-const global/static variables. Not like the evil Dust filter)
IanB: Even if the cache instance in front of avisource is hit by two thread it is still faster than one thread stalling in front of changefps (that would happend if SetMtMode(5) was placed after changeFPS). I wonder if it would be faster to implement the linear access requirement in the cache instead as it has better track on the last accessed frame (as the two instances of ChangeFPS doesn't share the lastframe variable).
Old 27th November 2007, 23:09   #760  |  Link
IanB
Avisynth Developer
@tsp,
Yes ChangeFPS is a hack proof of concept. And it seems to be somewhat successful when abused appropriately.
And yes a proper implementation would probably need to involve the cache or actually be a special case of cache.
Better still AviSource, et el, probably should be internally defending against out of order access. Some time ago I changed code to just reuse the same VFB, the original grabbed a stack of new VFB's as it seeked forwards from a Keyframe, it didn't remember them so it was a wasted effort that just generally trashed the cache. In hindsight a better fix would have been to add code to remember the VFB's. Hmmm!
I don't think always enforcing linear access would be a good idea, however as an optional weapon in the arsenal it's gonna be worthwhile.
Think SelectEven into a huffyuv file versus an Xvid file. With linear access you force the huffyuv to read all the disk blocks instead of just half. With the Xvid file you have to read all the disk blocks regardless and the out of order penalty can be extreme.
