#1 | Link |
Announcement: New open source DV codec (VfW)
Cedocida DV Codec
=================== *** Current version is 0.2.0 (2007-Aug-07) *** Source code is available here (official Homepage): Cedocida DV Codec A Binary version can be downloaded from here: http://neuron2.net/misc/cedocida020.zip (Big thanks to neuron2 for providing the binary!) Features: - supported formats for in- and output: RGB, YUY2, YV12 (PAL-DV / MPEG2-I / MPEG2-P) - direct YUV-4:2:0 output when using "YV12 PAL-DV" option - optional forcing of selected input and output format - settings for picture quality and compression methods New in Version 0.2.0: - fixed multithreading issues - ported to Visual Studio 2005 (Express) - fixed bugs in inf file and added install/uninstall support for x64 systems - and other minor changes Last edited by cedocida; 19th August 2007 at 17:25. Reason: new version is out! |
#5 | Link |
Cant get it to install. Right click > Install on the cedocida_DVSD in the Release folder throws up an error:
"Setup cannot copy the file Cedocida.dll" and "Ensure that the location specified below is correct, or change it and insert 'Cedocida DV Video Codec' in the drive you specify" I dont understand this statement. The auto-selected path was "C:\Program Files\cedocida_0.1.5\Release" and I cant see a Cedocida.dll file elswhere in the directory. Also, if I do manage to install it, can I assume that it will be possible to disable the codedc and swap it for other DV codecs using VCSwap? Thanks. |
#6 | Link | ||
@neuron2
@communist Quote:
@WorBry Do you have compiled the source? The file cedocida.dll is not part of the zip-file and will be created if you compile the sourcecode. The installation is the same as by the panasonic-codec. If you can swap this one, it should also work with cedocida-codec. |
#8 | Link |
_
![]() Join Date: Jan 2002
neuron2 to the rescue! Here's the compiled DLL and an INF file:
http://neuron2.net/misc/cedocida015.zip I tested it just a little but it appears to be working. Last edited by neuron2; 15th May 2005 at 21:12. |
#10 | Link |
Thanks Neuron2. First impressions with a few Pal Type II DV test clips - good quality decoding and appears to be free from the slight "color bleed" that I have observed with every other DV software codec bar Matrox and Sony. My main interest is in compressibility on (filtered) conversion to MPEG4 (DivX Fusion, mostly)and VP6. Until now the Sony DV codec has been my preferred decoder but it upsamples to RGB and requires luma shift adjustment after conversion to YUV color space. I'll run some bitrate vs quality metric comparisons with Cedocida as decompressor when I have a moment. Thanks again A.Dittrich and Neuron2. Where would us users be without your inventiveness.
PS - confirmed that Cedocida can swapped with other DV codecs without any problems using VCSwap. Last edited by WorBry; 16th May 2005 at 13:26. |
#11 | Link |
First of all thanks for the great codec
![]() Works fine here - except YV12-Output via AviSynth. Wether keeping the default or forcing the codec to output YV12 (PAL-DV and both MPEG variants) gives me weird colors. Can anyone confirm this? Adding SwapUV() corrects the problem. Forcing other colorspaces works fine with AviSynth and Info() reports them as such correctly. /Edit here is sample of the file I'm trying to frame-serve Last edited by communist; 17th May 2005 at 19:42. |
#12 | Link |
Communist,
Yes, I can confirm the weird colors (blue hue) you describe when frame serving Pal Type II DV clips loaded in AVISynth as AVISource, but only with the default codec settings. Selecting "force output format" corrects this, irrespective of the selected color space (RGB, YUY2 or YV12). |
#13 | Link |
Your right, i also can confirm this bug.
As you allready said, it's a color swap of U and V component. It should only affect the YV12 output modes. I will release a fix at the weekend. Thanks for your reports and to Neuron2 for providing the binary. |
#14 | Link |
How does it compare to the ffdshow DV decoder?
I reencoded something to mpeg2 (avisource was type II dv) for a DVD and the filesize was slightly smaller with this new codec. 1768679 instead of 1770134 KB. The quality looks great on my PC's monitor. I still have to see how it looks on my tv.
PC specs for bug reports: Athlon 64-bit FX-62 2.8Ghz Win7/XP Pro/Linux multiboot PCI express NVIDIA GTX 285 graphics card http://twitter.com/cwebdesign |
#15 | Link |
*** released new version 0.1.6 with NTSC support ***
now it's a fully working DV Codec. Sourcecode available here: Cedocida DV Codec (sourcecode) changes: - add: encoding and decoding of NTSC video - fixed: bug concerning U-V-color-swap of YV12 encoding/decoding some remarks on "YV12 (DV)" input/output option in combination with NTSC video: this format is direct data to or from the compression algorithm and will not be converted, shifted or interpolated. Because NTSC DV uses a 4:1:1 sampling grid, you will see weird color when viewed with a normal YV12 program which assumes 4:2:0 - this is no bug. If you need YV12 format, use the option "YV12 (MPEG2 *)". - Andreas - |
#17 | Link | |
Life looks better in HDTV
What do you think of this new codec? Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#19 | Link |
Hello!
Your codec is really nice, we really needed a good open-source DV Codec.. The only thing I noticied is that it creates more artifacts than the Canopus codec, for instance (even in the high quality mode). It's just me, or did you noticied it too? |
#20 | Link |
I found the quality to be very good. Thanks to Andreas and to Neuron2 for the compile!
My experience is with PAL, I created a high quality DVD (KDVD actually) from my DV footage. The final filesize was slightly smaller than when I used the ffdshow dv codec, I noticed. I didn't see any more artifacts than with ffdshow - I didn't see any actually.
| Thread Tools | |
| Display Modes | |
