#61 | Link |
_
![]() Join Date: Jan 2002
Hey, onesoul! For you, anything.
![]() Here is DGMPGDec 1.3.1b6. The following changes are made: * The process priority can now be changed in DGIndex during a Save Project operation. * A bug in the PAT/PMT parser was repaired that could cause DGIndex to erroneously think that a PAT/PMT is not present. * Added the .vro and .mpv file types to the DGIndex open dialog. * Fixed the broken Reference IDCT (type 4). Changes by jackei, derived from his latest DVD2AVI version. http://neuron2.net/dgmpgdec/dgmpgdec131b6.zip |
#62 | Link |
miau
Thank you neuron2
, your work is much appreciated.
"... but where are those missing pieces of eternal soul, I can feel them but I can't reach them with my vision" Petition for a software patent free Europe Another vision of what happened at 9/11
#64 | Link |
@neuron2
could you implement an indicator for dgindex beeing in pause-mode, because the only hint for hybernate ist the time elapsed/remain not running. a little PAUSE would be more user friendly, i think. i dont know if my examples are just picky, but for me dgindex only shows the status of the first two audio stream of a vob, even when there are more present. is this a common behaviour or belonging to my files? keep up the good work! |
#65 | Link | ||
_
#66 | Link | ||
![]() is dgindex working right now or just stopped by pressing space bar? you cant tell, because there is no message which indicates the current state of operation. i would like to see a simple PAUSE or STOPPED in den "Info"-field. Quote:
#67 | Link | ||
_
#68 | Link |
_
OK, never mind, I was able to use the file even though the video was garbage. I found the bug and it will be fixed in the next beta. Thank you for pointing it put. The bug causes a maximum of only two tracks to be shown, when it should be eight.
#69 | Link | |||
thank you for fixing!
#70 | Link | |
_
Try beta 7 for the fix to the audio track info: http://neuron2.net/dgmpgdec/dgmpgdec131b7.zip |
#71 | Link |
Brazilian Anime Ripper
Is possible to decode MPA audio directly to WAV? I need to convert MPA to WAV with Besweet to load in WAVSource() avisynth filter. If DGIndex do this convert, I need less steps to create my final video.
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
#72 | Link | |
![]() Join Date: Nov 2002
#73 | Link |
Why remove features instead add more options to already exists features?
#74 | Link | ||
#75 | Link | |
#76 | Link | |
That would solve the indicator issue, and I'd use it. |
#77 | Link |
_
Here is MPEG1 support in DGIndex
Here is the first stage beta for MPEG1 support. So far, only DGIndex has been modified. Do not try to load an MPEG1 D2V in DGDecode. Your CPU will overheat and melt, maybe even explode, if you do. You have been warned! This beta is to get some decoding exposure for the MPEG1 support in DGIndex. Note that the Info dialog works and the D2V file is generated. Again, do not try to load an MPEG1 D2V with DGDecode (MPEG2 is fine). That will be done in the second stage beta. Also note that this beta bumps the D2V file version to add an MPEG type field.
Please give me your feedback on the MPEG1 support in DGIndex. I also need to know if I have broken anything in the existing MPEG2 support. Thank you. http://neuron2.net/dgmpgdec/dgmpgdec131b8.zip Last edited by neuron2; 2nd June 2005 at 06:21. |
#78 | Link |
Author of avi.NET rip.NET
Hi, you are a busy man........
Right, when you say MPEG1 support do you mean 'normal' MPEG1 or/and VideoCD MPEG1 files? Anyway, I just tried 2 different VCD mpg's, one PAL the other NTSC. The one loaded in, but when I went to preview, or save, it said: No data. Check your PIDS. The other file, during load sort of locked up the program, apart from the titlebar it all went white... Wee-hee...... my 100th post
| Thread Tools | |
| Display Modes | |
